Re: What did you do yo your truck today??
ill have to get some pic to put up.
plan to love her, keep her, fix the broken driver side window if if find out whats wrong with it. lowered already which is a plus. missed my 94 short bed. got lucky and found a 91 shorty. 94 was blue. this ones reddish. |
Replaced my door ajar switch on my 91 sierra 1500, the old one was WORE OUT. It wouldn't even turn the lights off and the new one is significantly more tactile. Now, I'm waiting for the passenger side to go out.
![]() Not much goes wrong anymore, really need to invest on getting my rear sliding window sealed up, all the seals have dry rotted and I've been using RTV to keep it from rattling. haha |
Picked up a decent frame for my 1994 Chev ext cab shortbox 2WD. It came off a low mileage(47K) 1998 that had a dash fire that ruined the cab. Friend of mine bought it for the 5.7 engine and the mint box and I got the rolling chassis from him for cheap. Frame is really rusty on my truck and this one only started to show some color after I power washed it. Once I get it pickled in POR-15 it should even outlast me LOL. That hunk of rust in front of the rear wheel is the spare tire carrier that fell off my truck a few months ago so you can imagine what the rest of my truck's frame looks like.
http://www.maritimedragracing.com Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information. |
installed an under hood factory storage box, factory retractable work light. working on the air horn mod from a Grumman's 5.7 vortec.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
i just picked this 98 GMC up this weekend. belltech spindles and c-notch. i'll be changing out the 265's in rear for sure. they are way to big. probably go to a 235/75/15 on the 8" rears since the front has 225/75/15 on 7" fronts. i think that will give it a better, more level stance.
roll pan rear with hidden receiver.
1207 ,that looks nice .
Very nice, I like the wheels. I am old school and like the 15" rims better than the big wheel little tire.
Canadian Trucker
Picked up a set of brand new take off General Grabber APT's for $600, going on the true as soon as this white Shlt goes away...
![]() 2020 Silverado Trail Boss - 6.2/10spd |
thanks guys!! got a set of 235/75r15 put on the rear. took dash out and replaced a burned out check engine light. failed emissions due to that and a p0420 code. cleared code out and drove it maybe 10 miles and probably 12 start/run/shut off cycles trying to get computer to reset. no check engine light as of yet.
Test fitted my new to me wheels.
Of course needs a drop And slightly bigger tires But day dreaming of seeing that come already lol
1997 GMC SIERRA STEPSIDE 1986 CHEVY C10 1968 CHEVY C20 -JOSH IG:bopper702 |
new catalytic converter, cleaned mas, passed emissions, got new tags !! 4.3 200k+
Heard a snap this AM when I backed the truck out of the yard and now the body lines don't match up any more. Officially off the road now until I can get the frame swapped. Fortunately we have an identical low mileage frame in really good shape. Lots of work but well worth the effort.
#13 |
e3 plugs, summit performance coil and put mags on for the summer with a used set of 265 70 r17 goodyear dura tracs. scored the tires for $140.00 for 5 tires.
#14 |
Replacement frame is in the garage and ready for wire brushing and paint. Big job swapping frames but the end result is worth the effort.
![]() A quick test with a wire wheel in the cordless drill on a small section found black paint underneath all the mud and crud which sort of changes my plans for the choice of paint. I've been told POR-15 won't stick to painted surfaces so I'll have to go with good old Tremclad or Rustoleum.
#15 |
I have had no luck getting POR 15 to stick to anything except rust or sandblasted metal. I would us an oil rich paint such as rustoleum . It takes days to dry though. I have done many frame swaps over the years, pull the cab and bed,then motor /trans set both frames next to each other and switch things over.Don't put the motor back till all brake and fuel lines are in. Suspension parts are easier to switch with the motor in for the weight.
#16 |
here, just not logged in
Been fixing wiring for a week. PO hacked it up, and tried to fix it with duct tape. I'm fixing all the breaks by twisted, crimped, soldered, heat shrieked, and all new flex loom.
#17 |
Getting ready to replace dash harness and maybe swap to a newer style dash if I can find a good write up
#18 |
#19 |
#20 |
![]() ![]() Join Date: Jul 2002
That is a clean looking truck. I would have never guessed frame rot associated to it..
#21 |
PO was an over the road trucker. He didn't have a garage so put it in one of those canvas shelters with a dirt floor. I think between the moisture coming up from the ground and not getting drivin often enough to dry it out helped it's demise. Funny thing is the bottom pinch weld of the tailgate is rust free yet door bottoms are gone. I can break pieces of the frame off by hand from A pillar back to rear axle . All 4 wheels are new and upper control arms within last two years due to rust.
#22 |
Still plugging away at the frame swap on my blue truck but now there's no pressure to finish it anytime soon. Picked up another truck last week - a 1994 Silverado 2500 with a 350, 14 bolt rear and every option known to man. No rust Alberta truck with only 160,000 kms - just needs a few new front end parts and a new windshield. Should tow a lot better than my old blue 1994 1/2 ton with a worn out 305.
#23 |
This thread is looking a little stagnant so I will post my new change. I had installed aux. backup lights a couple years ago to allow me to see while launching and retrieving my boats at night. I used regular tractor lights that were common at any parts store. Recently the left side bulb burned out ,it is three years old but has an hr. of time on it at best. I decided to upgrade to some LED'S off E-Bay and can't believe how much brighter they are. This shows the difference I did change both.
#24 |
That is some serious lighting. I like how everyone around you has the typical (for today) black/dark vehicle, while you stand out within the crowd.
#25 |
My daughter has the blacked out Silverado and the Jeep is my wife's winter ride. She has a silver Mustang convert for nice weather. The new color is different enough to get attention wherever I go these days.
| Bookmarks |
