Old 12-13-2016, 10:14 AM   #351
jjzepplin
jjzepplin's Avatar
Re: Softop installation no Holes
Pop-up? Do Tell!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 12-13-2016, 01:11 PM   #352
solo72
solo72's Avatar
Does anyone have a picture of the header with a bikini top? I am thinking about buying a header for a bikini top.
solo72 is offline   Reply With Quote
Old 12-15-2016, 03:39 AM   #353
robs71k5
K5drive
robs71k5's Avatar
Yes the pop up I'm building keeps the roll bar installation intack and it utilizes the Headers I produce to add support . The whole unit is sumbrella and the pop up will have to same look as the original popups. I have the top frame section section finished just need to finish the supports over the quarter panels and then start sewing the sumbrella and windows in. My version will gain access to the pop up straight up from the drivers seat and passenger seat. Don't want to sell the farm completely just so hope to get busy on it on the next couple weeks if the weather permits LOL .
robs71k5 is offline   Reply With Quote
Old 12-15-2016, 07:00 PM   #354
Vegetta
Vegetta's Avatar
Do you have to drill both holes or will the hole that holds the L-bracket be enough support. Thanks Mickey Name:  Header.jpg
Vegetta is offline   Reply With Quote
Old 12-15-2016, 07:51 PM   #355
Vegetta
Vegetta's Avatar
Also do you use button head bolts for the sun visor holes. If so do they eventually wear into the soft topper fabric. Thanks again Mickey
Old 12-15-2016, 11:30 PM   #356
robs71k5
K5drive
robs71k5's Avatar
I used all the original bolts that where part of my Blazer i.e. The sun visor bolts are a He same bolts for the hard top
Old 12-15-2016, 11:34 PM   #357
robs71k5
K5drive
robs71k5's Avatar
Also you only need to drill into he holes you into ntend to use i.e. I only drilled one hole in each center bracket and the obvious sun visor holes . Unless you are installing the "bracket" for the bracket that will seal the driver/door passenger door . Hope that answered your question Regards Rob
Old 05-21-2017, 07:29 AM   #358
american revolution
american revolution's Avatar
Still interested....these available?
american revolution is offline   Reply With Quote
Old 06-01-2017, 06:11 PM   #359
robs71k5
K5drive
robs71k5's Avatar
Finally had time to finish my header to the fashion I was expecting and it came out pretty good but my take another shot at it because I can LoL
Old 06-01-2017, 06:15 PM   #360
robs71k5
K5drive
robs71k5's Avatar
Attaching pictures has changed
Old 06-01-2017, 06:17 PM   #361
robs71k5
K5drive
robs71k5's Avatar
Gel coat color matched nearly perfect
Old 06-01-2017, 06:20 PM   #362
robs71k5
K5drive
robs71k5's Avatar
Just need to add the last two missing snaps and it's done. Notice the profile is low and when the softopper is on its virtually undetectable
Old 06-01-2017, 06:24 PM   #363
robs71k5
K5drive
robs71k5's Avatar
Carving or sculpting around the door swing path (vent window) is important to keep close. I will try to get closer picture
Old 06-01-2017, 06:35 PM   #364
robs71k5
K5drive
robs71k5's Avatar
Before sculpting around door swing and after sculpting
Old 06-01-2017, 06:49 PM   #365
robs71k5
K5drive
robs71k5's Avatar
To get good clean lines your installation may need to be trimmed to the shape of your truck at each end breaking sharp edges around the door and window seals and again along the rain gutter. Provide adequate clearance to prevent chafing . Door Seals seem to have variations and preferences . First place the Header on top of the windshield . Gently push down at each end simultaneously until the Header bottoms out at the mounting locations (each visor location). Briefly check that the two center brackets are also at the correct side to side you may be able to shift it side to side for best location . Then go drill the 5/16 holes holes and drop the bolts into each hole at each sun visor then proceed to drill the center bracket holes by pushing down on the Header till It bottoms square to the two center bracket locations. (I used one hole in each bracket) When Header is bolted down there should be no gaps under either of the four bolt down locations and should be squarely seated to he top of the windshield .
Refer to the softopper installation instructions for the softop installation of the 17 snaps . I personally used snaps that came with screws , marked the hole locations as accurately as possible with ink pen ,drilled the holes in the Header and tapped with self tapping screws . I then removed the screw and ground down the screw so it did not pertrude into the inside of the Header ,then installed the snap/ screw with locktite . Once you have drilled the location of the snaps you should gel coat the Header to your color match or finish to your own specs per normal auto body practices . I have personally gel coated twice sanding between each application and then painted on final or final gel coat .
Once the Header is installed it should present with little to no visibility which my insurance company had no problems with as far as collector plates after understanding the delema of drilling holes in the mast . Hope your project comes out as expected and then some.
I will be happy if I can be available during your install for questions . As far as I'm concerned this was a no brainer installation requirement for my Blazer and the applications this Header has in Making a custom chalet really helps knock the project into reality while trying to mentally invision what your trying to build. See my post for custom Chalet as that build progresses.
Old 07-20-2017, 09:29 AM   #366
PSYCHO_OUTLAW
Talking Re: Softop installation no Holes
I seen in some of the original post that these were going for $260. is that still the case? I have been doing some research on running a soft top year round and its looking more like a possibility. Anyone else run theirs year round in snow and rain? how is the protection? does it stay warm inside?
PSYCHO_OUTLAW is offline   Reply With Quote
Old 07-20-2017, 06:29 PM   #367
PGG
I dont have a soft top but I can tell you from other convertibles if you are in cold weather it will be cold!
Still need to get one! PG
PGG is offline   Reply With Quote
Old 07-24-2017, 08:42 AM   #368
The taxidermist
robs71k5- can i get one?
The taxidermist is offline   Reply With Quote
Old 07-31-2017, 11:14 PM   #369
robs71k5
K5drive
robs71k5's Avatar
Taxidermist check your in box
Old 07-31-2017, 11:21 PM   #370
robs71k5
K5drive
robs71k5's Avatar
If your serious about purchasing this header please email me at srpenner@hotmail.com . I don't check this site as often as Id like to and winding down production
Old 07-31-2017, 11:35 PM   #371
The taxidermist
There's nothing there
Old 08-03-2017, 05:54 AM   #372
The taxidermist
10-4
Old 08-03-2017, 03:59 PM   #373
jjzepplin
jjzepplin's Avatar
Please don't get discouraged. A lot of us still want them and are just hoping to find the funds. I was saving to get a hood but I cannot find one. Maybe I should just pull the trigger on this as you seem to be discontinuing the product. Reviews seem to be good and it appears to be a quality piece that not everyone would recognize. Truly custom. Hmm.
Old 08-03-2017, 08:15 PM   #374
robs71k5
K5drive
robs71k5's Avatar
JJzepplin no worries I got you covered .
Old 08-03-2017, 10:33 PM   #375
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Ive removed the bickering here. it needs to stop. Taxidermist youre new here this kind of stuff will get you banned and Robs71k5 if youre selling parts here regularly you need to be a vendor. Ive forwarded this to the parties that handle this if there is any more garbage posting threads locked suspensions handed out
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
