02-22-2016, 06:56 PM | #351 |
Re: 67 GMC super custom build
The passenger side is complete except the wiring and switch. I finished the mechanism for the driver side as well. Here is the pass seat and the console mounted. the pass seat is a little bit higher now than the console cause of the 1" I raised it for the power tracks but should be ok. I cant raise the console because the Velcro strap wouldn't line up to keep it open but probably wouldn't anyway.
02-22-2016, 08:48 PM | #352 |
I think I'm going to lower the seat frame so that the seats sit level. The more I look at it the more I don't like them offset.
02-23-2016, 01:41 AM | #353 |
I agree the seats need to be level. Just another example of how you look at every detail of your build. Always tuning in just to see what you have come up with new. Great work!
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
02-23-2016, 09:32 PM | #354 |
Taking 1 1/4" out of the seat frame.
02-23-2016, 10:07 PM | #355 |
Moched up. Now you wont see the seat from the back window. I am glad I did this.
02-25-2016, 02:37 PM | #356 |
All tacked together
02-25-2016, 04:36 PM | #357 |
I may try to use my mosified cst horn button from my other wheel on my telescopic wheel. This may not be possible but it would look nice.
03-01-2016, 03:41 PM | #358 |
Here is a picture of the power seat switches i'll be using. it is hard to find a 2 way power seat switch. wow everything out there is a 6 way. from gm they had to come from a limo.Also I am toying with the idea of adding heated seats. I would be putting a new modern set up in the truck. 1966 Cadillac had heated seats optional and here is what the switch looks like. I am trying to have one made by someone with a cnc machine. If he can make it I will probably do it and mount the switch on the bottom of the dash beside the a/c vent. may just do driver seat but unsure.
03-04-2016, 05:53 PM | #359 |
James did an awesome job finishing up the seat frame. He lifted the back under the console so the stock jack can still be removed when needed. The seats sit nice now and the full use of the tilt telescopic wheel can be used!
03-08-2016, 12:40 PM | #360 |
This switch bezel is exactly the same as the seat heat switch. Here is where they will mount. Just it will be flush with the bottom of the dash so all you would see is the words. I think if the modern harness will work with these switches I will do this mod.
03-18-2016, 05:23 PM | #361 |
I made a filler strip to cover the tracks and mount my seat switch to for the passenger seat. Here is how it looks. not sure if I should polish up the aluminum, Paint it or cover it with the same color vinyl as the seat. the cars always had a surround on the edges of the seat that was polished aluminum so I might go that route.
03-18-2016, 05:26 PM | #362 |
the foam work on the bottom of those seats looks awfull. I may get the upholster guy to fix that when I bring them to get my seat heat pads in them.
03-18-2016, 07:31 PM | #363 |
And the driver side.
03-23-2016, 05:31 PM | #364 |
Got my seat heaters going now just to get the pads in the seats. Work perfect with the old style metal under dash switches.
03-23-2016, 07:26 PM | #365 |
Picked this up today for a decent price to. Guide matic. It auto dims your headlights. Why not I guess. It is cadillac period correct as well
03-31-2016, 11:20 AM | #366 |
I only skimmed the thread, but very cool build. My grandpa's '58 Caddy has auto dimming headlights and its pretty trick. Keep the pics coming.
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina 1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208 1970 GTO Judge, heads/cam LS1 & stalled 4L60e |
04-01-2016, 07:50 AM | #367 |
Amazing work....subscribed
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
04-03-2016, 12:29 AM | #368 |
Where did ya pick these up at? Thanks!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-03-2016, 09:52 AM | #369 |
04-03-2016, 04:12 PM | #370 |
Got pictures of my new horn center piece today. Telescopic wasn't available in anything gmc so I traded the bow tie out. One with raised letters and one with engraved letters. They look sharp.
04-05-2016, 10:28 AM | #371 |
I got the guide matic dial and reostat mounted. The back dial is the guide matic and the front is twilight sentinel. I also got the dials a bit closer to the gauge bezel.
04-05-2016, 10:43 AM | #372 |
GMC is the Cadillac of trucks yours will the be top of the line. If you make a window sticker with all the options that will be a big window sticker for sure.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
04-18-2016, 10:43 PM | #373 |
I got my horn center pieces tonight for my telescopic wheel. They look absolutely amazing!!
04-19-2016, 11:40 AM | #374 |
They both look amazing.
04-19-2016, 01:03 PM | #375 |
Thanks. I am super happy with these. Here is the full steering wheel.
