05-24-2018, 03:15 PM | #351 |
Re: CRGRS 66 – Winter Build Thread
I did the lines on my truck. I have done to big tubes on the garbage trucks, but generally the guys do these.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
05-28-2018, 09:56 AM | #352 |
Nice job they look good.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
06-06-2018, 05:04 PM | #353 |
Senior Enthusiast
Beautiful tubing work! Congrats!!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
07-09-2019, 03:14 PM | #354 |
Update!
The last work that I did on the truck was the brake lines, haven't touched it in forever. So, she is for sale, and just like that, it is sold to one of my closest friends. Steve will be taking over from here. I will live vicariously through him from here on. We are actually moving the truck to his place tonight. I will sign in and catch up on all of you guys from time to time. Cheers to all!
08-01-2019, 12:09 PM | #355 |
Well, I'm the Steve that bought the truck from Craig and will be picking up where he left off. I know I have a long road ahead of me but I'm looking forward to having this baby rolling someday.
I've been peeling through everyone's builds and see a lot of impressive work and I'm sponging it all up. I'll be sharing progress through this thread since it holds the beginning of the truck's restoration life. There's still a ways to go and it all seems daunting at times but to paraphrase a line from Johnny Cash, I'll do it one piece at a time. Cheers fellas, I look forward to contributing to the board. To start things off, here is where she currently rests:
Check out my 66 C10 build here: http://67-72chevytrucks.com/vboard/s...d.php?t=546694 Look here, I also built a canoe: http://stevescedarstripcanoe.blogspot.com/ |
08-06-2019, 10:13 AM | #356 |
Best of luck
08-19-2019, 09:54 AM | #357 |
An ever so small amount of progress this weekend.... I previously extracted a broken bolt from the nose of the crankshaft and this weekend I reassembled a few items. After ordering a harmonic balancer install tool from Amazon (since no stores in town had one to rent or buy) I was able to reinstall the harmonic balancer and then continue with the crank pulley, the fan, and the belts including adding anti-seize to the metal to metal connections.
One question I do have is, how close can the belts be to other items? I'm a bit concerned with the clearance between the belt coming from the alternator and one of the bolt heads for the power steering pump bracket as there is only about 1/16" clearance.
08-19-2019, 11:36 PM | #358 |
60-66 Nut
Yeah a 1/16" is a bit close. Most of the time on a long belt like that the movement will be up and down, but they can move a little side to side. About all you could do if there is contact is remove that PS pump bracket, counter sink that hole and install a allen socket flat head bolt.
08-20-2019, 07:04 AM | #359 | |
08-20-2019, 09:54 AM | #360 | |
09-02-2019, 12:57 PM | #361 |
Getting frustrated and could use some advice....
I'm trying to install the new rag joint and it does not seem to want to fit on to the shaft of the power steering gearbox.....am I missing something here or should I use a hammer and smack it on? They look like the same number of splines but it's hard to tell for sure and impossible to count on the rag joint.
09-02-2019, 03:48 PM | #362 |
I think I figured it out....the PO picked up the wrong rag joint coupling. Just ordered a Dorman 31015 to fit the 13/16 x 36 spline shaft.
09-11-2019, 05:20 PM | #363 |
Glad to see you keeping this thread alive.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
09-11-2019, 07:05 PM | #364 |
Thanks! Got the new rag joint and installed it...fit like a glove - glad I didn't try and smash the other one on! Just sorting out the steering column and associated parts now..... gotta say, it's a hell of a disadvantage not being a mechanic or having the knowledge from disassembling the parts! No worries though, I'll figure it out
09-12-2019, 09:30 AM | #365 |
One piece at a time.
09-21-2019, 07:00 AM | #366 |
Moderator
Any progress?
I'm interested to learn what size fan (p/n?) and fan clutch you used?
09-23-2019, 09:01 AM | #367 | |
As for the fan size, I'll have to get back to you on that but I'm 99% sure the fan clutch is this one: https://www.summitracing.com/int/par...make/chevrolet Sept. 24th edit: Measured the fan last night, it's 19" diameter 6 blade.....don't have a part number unfortunately but hope that helps.
Check out my 66 C10 build here: http://67-72chevytrucks.com/vboard/s...d.php?t=546694 Look here, I also built a canoe: http://stevescedarstripcanoe.blogspot.com/ Last edited by 66c10Steve; 09-24-2019 at 07:43 AM. |
06-08-2020, 04:47 PM | #368 |
Well, I hadn't touched the old girl since September last year but the itch has been there lately to get back to it.
So, I finally got around to addressing the power steering bracket bolts using Captainfab and Robert's suggestion - drilled out the bracket with a countersink bit and installed 3/8"-16 x 3 1/2" long socket flat heads and it looks much better now. I've also ordered a chrome steering column with tilt from ebay and next plan to order this seat cover in Black/White from USA 1 Industries: http://www.usa1industries.com/1960-6...ntal-band.html I've debated for a while what colour scheme to go with on the interior but I think I'm settled on white with black & chrome/polished steel accents here and there. I'm kind of all over the place with the order of what to do next but I think I'm going to tackle the conundrum that is the clutch linkage issue Craig brought up on post #334 on page 14....
06-08-2020, 07:01 PM | #369 |
Hi Steve!
I'm happy to see that you're continuing on Craig's "many winters build thread". I haven't been active on here for quite a while, but I'm hoping to get something happening again soon. We should meet up some time if it's ever safe to do so. lol Re: your clutch pivot ball issue. I think you probably need something like this: https://sdparts.com/i-24074894-sdpc-...nd-trucks.html https://www.jegs.com/i/JEGS/555/601026/10002/-1
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
06-08-2020, 07:29 PM | #370 | |
Thanks for the links - will look closer at them to make sure they'll work for the sbc. In the meantime, I'd love to pick your brain to help me figure out a build plan....I'll wear a mask even to ensure adequate anti-COVID requirements. Shoot me a message and I'll send you my cell number so we can make plans.
06-11-2020, 11:09 AM | #371 |
2 questions for you gents today:
1. Does anybody have a recommendation for the Ivory-Off White exterior colour in rattle can form? I searched the site and came across two, one said Rustoleum Gloss White and another said Krylon Gloss Ivory. Just wondering if someone could confirm those or offer something else that they successfully matched up with. 2. Looking for suggestions on how to fill a bunch of holes that used to be from a tonneau cover.....was thinking of drilling them out using a countersink bit and then filling with JB weld but maybe there is a better method. Here's a pic of the holes that go all the way around the bed:
06-11-2020, 09:32 PM | #372 |
60-66 Nut
The correct way to fill those holes is to weld them up, sand them down, a skim coat of filler, prime and paint
06-12-2020, 05:37 PM | #373 |
I agree. weld them up.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
06-15-2020, 08:06 AM | #374 |
Thanks guys - I do have a mig welder so it sounds like I'll be putting it to use. Found This YouTube Video for a technique....hopefully this is right, will definitely practice on a scrap piece of metal.
Side question, do you guys know what gauge steel the body panels are made from on our trucks? Did a search on here and it sounds like people say between 18-20 gauge.....
06-15-2020, 09:27 AM | #375 |
Most of the original metal was 19 gauge. That's also what a lot of the patch panels are
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
