Old 12-19-2014, 11:15 AM   #351
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
This is something I wanted to share with you guys..
It is a tool I made for marking cut lines etc. When precise lines are required. It makes it very easy to adjust for thin trimming etc..
I used a block of steel 1/2 wide by 1/4 drilled a hole on both side so it can be rotated as needed. Then using welding rod,steel rod to fit the hole. it slides through and is welded to a collar with set screw. Then I used a piece of tungsten for the scribe. this is adjustable as is the length. then using the set screw on the top it locks it together.
Pic #2 showing how it works...you can use Dykem or even a marker..
Hope this helps the home or pro fabricator...
Mark...
reaper71 is offline   Reply With Quote
Old 12-19-2014, 11:19 AM   #352
reaper71
reaper71's Avatar
Here is some pics of the final layout of the gauges.
Old 12-19-2014, 11:28 AM   #353
reaper71
reaper71's Avatar
One more shot of gauge/dash..
Pic #2 I don't know how many of you guy's out there like door signage!
I want this truck to be used as a shop truck and daily driver (If I ever get it done lol) This was a design I came up with and had 2 stencils made and applied them to the doors, Then used my airbrush and sprayed the white paint and then using a paper towel and some reducer I started to age it (with stencil still on)
Then remove the stencil and let dry...After this I wet sanded it a bit to give it a better weathered look..
Till next time..
Mark...
Old 12-19-2014, 12:22 PM   #354
Advanced Design
Advanced Design's Avatar
Originally Posted by reaper71 View Post
Don't even sweat it Brother!! That thing is badass...
That being said, I have a few spray out's I have done to try and get a good perspective on what it might look like..
Pic #1 the panel on the far right was done with a DA sander with flat clear.
The middle was done with a sanding disk and flat, and the blue panel was used for contrast.
Pic #2 same panels diff angle..
I like the middle panel. Looks like metal and not too swirly on the sanding.
Great tip on the lay out scribe! Gauges look really good too. As does the lettering on the door.
Mark, you are really talented ...thank you for sharing the work and ideas. Does Jim help out in the shop?
Advanced Design is offline   Reply With Quote
Old 12-19-2014, 04:07 PM   #355
rusty76
rusty76's Avatar
I like all your ideas. You could go with a silver metal flake on the dash top and some accents. Then leave the others in bare metal too... You're doing a killer job and I absolutely like door art.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-19-2014, 08:10 PM   #356
reaper71
reaper71's Avatar
A.D. as always thank you very much for the compliments!!
I still am not sure what direction for the interior...I did one more spray out today with a gloss clear, It doesn't make it look cloudy like the eggshell...
Dad doesn't get out to the shop very much anymore He comes out and helps if I need him to be there. Health issues with Mom keep him sidelined..
Old 12-19-2014, 08:27 PM   #357
reaper71
reaper71's Avatar
rusty... That sounds pretty cool didn't think of that, thanks..
And again thank you for the compliment..
Old 12-19-2014, 08:35 PM   #358
rusty76
rusty76's Avatar
Yeah man, no prob. I'm full of ideas, if for nothing else....lol.
My build thread
Crossmembers CC
Old 12-23-2014, 12:40 AM   #359
99 to Life
99 to Life's Avatar
just found this, very nice work man.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-23-2014, 07:02 AM   #360
CURSED GEARS
I like your home made precision line marking tool thingie. May have to make one myself. Still won't cut it straight though. (Thank God for grinders!)
CURSED GEARS is offline   Reply With Quote
Old 12-23-2014, 11:21 AM   #361
reaper71
reaper71's Avatar
Thank's 99 I have been following your build for awhile now, you do nice work as well..
Old 12-23-2014, 11:22 AM   #362
reaper71
reaper71's Avatar
I'm right there with you!!
Thank's for checking out the build..
Old 12-23-2014, 08:05 PM   #363
reaper71
reaper71's Avatar
Here is A update...
My front moldings around the windshield are a bit of an eyesore...so I need to fix this issue..
Pic #1 shows the transition from molding to the dash, witch exposes a large gap between them.
Pic #2 shows from passenger side the gap between the molding and door.
Now the A pillar would normally have some sort of interior welting etc, but I have diff. plans for this later. So I will start on making extensions for the molding's.
This pic also shows a sneak peek of the finish on the door panel and door moldings! I am not happy with the look!! (in person it looks like painted surface)it is bare metal with clear..
Old 12-23-2014, 08:09 PM   #364
reaper71
reaper71's Avatar
Pic #1 Making a template of the shape for the molding extension. and transfer to metal..
Pic #2 the new piece tacked in....(aahh yes more welding and grinding )
Will need some trimming etc. to get it the way I want..
Mark..
Old 12-23-2014, 11:42 PM   #365
youngrodder
youngrodder's Avatar
Looks good. So when finished the extension will be welded to the window trim and it will be held on by screws.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-24-2014, 02:26 PM   #366
reaper71
reaper71's Avatar
Yes! It will basically be the new molding. the screws for the O.E. molding hold it nice and tight to the pillar..
Marc
Old 12-24-2014, 02:30 PM   #367
reaper71
reaper71's Avatar
Pic #1. showing how it will flow into the door molding.
Pic #2. here I have also tacked on round bar to the outer edge to finish it off a bit more. I used 1/8" for this.
Old 12-24-2014, 02:34 PM   #368
reaper71
reaper71's Avatar
Pic #1. the molding removed from vehicle and all welded, Time to grind and metal finish..
Pic #2. All metal finish done. (After seeing it all finished I didn't like how the corner looked being rounded so I will square it off )
Mark...
Old 12-25-2014, 09:16 AM   #369
RockinKees
RockinKees's Avatar
Man!!
That is looking real nice!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-25-2014, 09:33 AM   #370
hotrodelrod
hotrodelrod's Avatar
Nice work Reaper!
hotrodelrod is offline   Reply With Quote
Old 12-25-2014, 11:27 AM   #371
reaper71
reaper71's Avatar
Kees and Elrod thank's guys!!
Old 12-25-2014, 04:20 PM   #372
rusty76
rusty76's Avatar
Great job.!
My build thread
Crossmembers CC
Old 12-26-2014, 07:49 PM   #373
reaper71
reaper71's Avatar
Thank's again Rusty!!
Old 12-26-2014, 11:06 PM   #374
chev3600
chev3600's Avatar
Excellent work! Really like the work on the moldings, never would have thought of changing it like that.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 12-30-2014, 10:32 AM   #375
reaper71
reaper71's Avatar
Thank you!!
the moldings just didn't flow the way I wanted so they needed to be modified.
They turned out better than I thought they would
