Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 11-27-2014, 01:06 AM   #1
Hart_Rod
Hart_Rod's Avatar
DBW Gas Pedal Adpater bracket for truck/suv pedal
DBW mounting bracket for 03-07 Truck/SUV Pedal
$120 Shipped via USPS (**adjusted 10/4/2022)
Paypal: robhartley@aol.com, enter "TPB" in message block.
*** All purchases now include: USPS shipping in CONUS, paypal fees and all the necessary hardware to install the pedal bracket. ***
After receiving many of requests for pedal bracket that will work with the 03-07 truck pedal, I fabricated this pedal bracket. This is a bolt in bracket that uses the 03-07 truck/SUV DBW pedal (may fit others) for the 67-72 LS conversions. Let me know if you have any questions or suggestions.
GEN IV flat brackets for the 05+ Corvette Pedal can be found here: http://67-72chevytrucks.com/vboard/s...d.php?t=631165
**** PEDAL MOUNT INSTALL INSTRUCTIONS ****
1. Start by bolting your truck/SUV DBW pedal assembly to the mount bracket using the provided 3/4" 1/4-20 bolt. Do not tighten.
2. Next, loosely bolt the mount bracket to the firewall using the three nutserts in the firewall where the original pedal was mounted. You can do this by aligning the three pre-drilled holes on the right side of the mount bracket. Use three 3/4" 1/4-20 bolts to attach to the firewall that were included in your kit.
3. Next, align the left edge of the mount bracket with the raised vertical firewall brace. There are two pre-drilled holes on the top and bottom on the left edge that will be used as a guide to install the provided self-tapping bolts.
4. After you attach the left side of the mount bracket to the raised brace, you can tighten the three bolts on the right side of the bracket using a 7/16 socket.
5. When the pedal bracket is securely attached, you can adjust the pedal position as desired by moving the top of the DWB pedal assembly left or right. If necessary, there is also about 1/2" up or down adjustment from the slotted hole in the bottom of the DBW pedal assembly.
6. After you have the pedal in the position that you like, use a 7/16 socket to tighten the bottom bolt holding the DBW pedal assembly.
7. Next, you should actuate the pedal up and down to check for any interference in the movement. There shouldn't be any, but all the trucks are a little different so be sure to check. If there is any interference, loosen the bolt and adjust as necessary.
8. Once the DBW pedal assembly is adjusted, make sure the bottom bolt is tight and remove the mounting bracket and DBW pedal assembly from the firewall as one piece. This will hold the pedal in your desired position and allow you to drill the top hole to finish mounting the pedal assembly.
9. Next, mark the top pedal assembly hole using the DBW pedal assembly as a guide. Remove pedal assembly and then drill a 1/4" hole where previously marked. Re-install the pedal assembly with the provided 1/4" bolt and nut and tighten. This nut should be tacked in place, just like the one on the bottom, so that the DBW pedal assembly can be removed by itself without removing the entire pedal mount bracket.
NOTE: If you don't have a welder, you can just tighten the top bolt and leave the DBW pedal on the bracket for reassembly.
If you have any questions or suggestion about the installation, please let me know. Thanks for your purchase!
Hart_Rod is offline   Reply With Quote
Old 12-03-2014, 11:24 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Gas Pedal Adpater bracket for truck/suv pedal
bump
Old 11-21-2015, 04:21 PM   #3
CustomK5
Hello was wondering if these are still available doing a 5.3 swap out of a 05 in a 72 blazer
CustomK5 is offline   Reply With Quote
Old 11-21-2015, 07:32 PM   #4
Hart_Rod
Hart_Rod's Avatar
Yes sir! $100 paypal robhartley@aol.com. Thanks!
Old 01-26-2017, 10:22 PM   #5
ivanandjuri
Originally Posted by Hart_Rod View Post
bump
Do u still make these?
ivanandjuri is offline   Reply With Quote
Old 01-26-2017, 10:24 PM   #6
ivanandjuri
If so, I'll take one.
Old 01-27-2017, 07:14 AM   #7
Hart_Rod
Hart_Rod's Avatar
Re: DBW Gas Pedal Adpater bracket for truck/suv pedal
Yes I do! Price and PayPal info is in post #1.
Old 02-01-2017, 10:03 AM   #8
Hart_Rod
Hart_Rod's Avatar
$100 Shipped via USPS
Old 02-03-2017, 07:44 PM   #9
NC_John
NC_John's Avatar
Here's a bump for a solid little part. I had to notch mine to clearance for the back-half wiring plug but fits great. (I painted mine too)
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 12-05-2014, 10:09 AM   #10
Hart_Rod
Hart_Rod's Avatar
3 brackets sold. 9 left.
Old 12-09-2014, 10:40 AM   #11
Hart_Rod
Hart_Rod's Avatar
5 brackets sold. 7 left.
Old 12-12-2014, 09:50 AM   #12
Hart_Rod
Hart_Rod's Avatar
6 brackets sold, 6 left.
Old 12-12-2014, 11:55 AM   #13
Hart_Rod
Hart_Rod's Avatar
**** INSTALL INSTRUCTIONS ****
Pedal mount instructions:
Old 12-12-2014, 11:29 PM   #14
205harleyman
205harleyman's Avatar
I want one
205harleyman
1972 K5 Blazer
2002 5.3 ltr engine and transmission
Vintage Air
1999 tan leather bucket seats and console w/1999 back seat
20inch Torque Thrust Wheels
Corvette Madrid Red with Tan Top
Hope to be driving soon!!!
205harleyman is offline   Reply With Quote
Old 12-13-2014, 10:05 AM   #15
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 205harleyman View Post
I want one
Sweet! PayPal information is in the first post of the thread. Let me know so I can ship it today.
Old 12-14-2014, 02:49 PM   #16
Hart_Rod
Hart_Rod's Avatar
Originally Posted by smbrouss70 View Post
I want one Rob!
Shipped. THANKS!
I want one
Do u still want one?
Old 12-13-2014, 03:21 PM   #17
smbrouss70
smbrouss70's Avatar
I want one Rob!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-20-2014, 07:53 PM   #18
205harleyman
Sorry, I forgot about it, but just sent paypal
205harleyman
1972 K5 Blazer
Vintage Air
Old 12-23-2014, 01:04 PM   #19
Hart_Rod
Hart_Rod's Avatar
No worries! It shipped yesterday. Thanks again.
R
Old 01-04-2015, 12:33 AM   #20
dayj1
Bump for a great seller. The bracket installed easily and is a great time saver.
dayj1 is offline   Reply With Quote
Old 01-06-2015, 12:45 PM   #21
elimontfort
elimontfort's Avatar
hi I was wondering if you have any brackets left?
elimontfort is offline   Reply With Quote
Old 01-06-2015, 01:09 PM   #22
Hart_Rod
Hart_Rod's Avatar
Yes I do! The price is 100.00, Paypal is robhartley@aol.com. Thanks!
Thanks Jonathan!
Old 01-06-2015, 01:44 PM   #23
Roz
Just got your PM, I'll take one well!
Roz is offline   Reply With Quote
Old 01-06-2015, 01:50 PM   #24
Hart_Rod
Hart_Rod's Avatar
Thanks!
Old 01-06-2015, 02:06 PM   #25
Roz
Thanks!
PayPal sent!
