Old 07-31-2016, 09:56 PM   #351
knomadd
knomadd's Avatar
Re: Blood Sweat and Tears.. 67 Build Thread
Nice score with the wheels!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-12-2016, 12:58 PM   #352
Possmguts
Possmguts's Avatar
Home again and working on that bed side... now that the bed is apart and I can put the side on my stands its much easier to work on... Ive got the tin canning out and have been using the hammers and dolly on it and have it about as close as I can get it now... I did have to cut a big chunk of the inner wall out so I could get at the outer shell more gooder from the inside, but its coming along better than I thought it was going to when I started on it... Ill post some pics later... On another note.. why am I only able to find a lower rear patch for the long bed and not one for the short bed???
Lotta trouble to go through to save a few bucks, but Im getting some experience out of the deal.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 08-13-2016, 12:58 PM   #353
Possmguts
Possmguts's Avatar
Working out all the kinks in this pass side bed side... I think Im gonna go ahead and pull the inside wall off so I can get inside and get it coated and worked out more gooder... That inside wall needs some work too. Ive already had to cut a chunk out of the inside to be able to work out the heat stressed area on the outside where I welded a thousand holes shut from where they had about 5000 lbs of bondo...
Old 08-13-2016, 06:51 PM   #354
flashed
Looks good ,I need to get busy on one of my trucks and find it a new home .
flashed is offline   Reply With Quote
Old 08-14-2016, 06:07 PM   #355
Possmguts
Possmguts's Avatar
Before and after shots on the worst and biggest section of that bed side...
Old 08-14-2016, 06:50 PM   #356
Advanced Design
Advanced Design's Avatar
Big improvement...that came out really well!
Advanced Design is offline   Reply With Quote
Old 08-14-2016, 08:24 PM   #357
Possmguts
Possmguts's Avatar
Thank you sir... few more areas on that side and then patching up the inside wall and then back to the drivers side... saving money to make the rest of the bed parts order... And then trying to figure out how to do the fuel fill once its back together on the truck...
Not sure exactly what Im gonna do there just yet
Old 08-14-2016, 09:38 PM   #358
flashed
Looks much better ,staying tuned in for more.
Old 08-14-2016, 10:30 PM   #359
swamp rat
swamp rat's Avatar
Ok, how in the h... did you do that bodywork so damned fast??!!??!! I'm ready to punt... I'd be on that bedside for at least 3 months.. Did you stay away from the body line? or shape it? how many applications of mud? Long board or DA? I need to learn how to speed things up.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-15-2016, 01:19 AM   #360
jim-bob
...Ima Hanging
jim-bob is offline   Reply With Quote
Old 08-15-2016, 08:14 AM   #361
Possmguts
Possmguts's Avatar
lol.. there's only 2 thin layers of mud and a little glaze on it... I use a big piece of Plexiglas on big areas for spreading... It really helps speed it up... and then DA with 50 grit to get it down it down and then use like an 18 inch block with 80 grit to finish... and then use the high build with finer grit with the block...The body lines was not an issue on this spot.
Old 08-15-2016, 08:26 AM   #362
lower50's
lower50's's Avatar
That panel turned out amazing looks really nice and straight.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-15-2016, 12:41 PM   #363
swamp rat
swamp rat's Avatar
I have seen video's of people using Sheetrock mud blades to spread the mud. so you mixed a rather large amount of mudd, a couple cups per application? I'm using the 1'x1' onion brand paper stacked mixing board where you mix, apply then throw away the top sheet of paper, maybe i need to find a bunch of cardboard boxes and mix larger amounts..
Is your high build a quart can or spray can? brand?
I have been using 80 grit on my long board but following that with 180, It still takes many applications of my spray can high build to get everything filled.
In your pic is that high build Primer or is that K2?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-15-2016, 01:04 PM   #364
Possmguts
Possmguts's Avatar
I just mix about 1/2 to 3/4 fist size amounts at the most. Ill use a soft plastic blade to work it into the rough area and then go to the Plexiglas sheet I have to get a really wide, smooth swipe to get it close to the body shape and pull off the excess amount... what I mix on is a drywall mud plate with a handle on it and just clean it after each use. The high build Im using is in the gallon and I use a primmer gun to spray, but really dont have to use much.. maybe 2 or 3 good coats at first and then a light coat between sanding with different grits until I get to 150 grit. Ill later go over the whole truck with finner gits to get to the surface ready for color. The glaze I use is extremely workable and eliminates a lot of the high build... It flows really nice and thin.
I also go over the area getting filler with a 30 grit disk to really rough the metal up to get that grabby surface for a really strong hold.
This pic is basically my body kit... minus the welder... and the smaller and different shaped blocks
By the way... The pro grade bondo is much more workable than the regular
Old 08-15-2016, 04:39 PM   #365
swamp rat
swamp rat's Avatar
I appreciate the pic and explanation, I'm slowly getting better.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-05-2016, 01:55 PM   #366
Possmguts
Possmguts's Avatar
Not gonna be any real updates for a while.. I bought a new Kenworth and will be on the road a lot more for a while... Taking some of the c10 to paint jail tomorrow to drop off.
Old 09-05-2016, 02:06 PM   #367
Advanced Design
Congratulations on the new KW!
Old 09-05-2016, 03:43 PM   #368
ripper70
ripper70's Avatar
Nice Job! Its Like I tell everyone...Slowly but surely!My problem is I always seem to start another project...lol.
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 09-06-2016, 12:33 PM   #369
flashed
Show us a pic of the new ride ,would love to see it .
Old 09-06-2016, 04:08 PM   #370
Possmguts
Possmguts's Avatar
My latest bad decision lol...
Old 09-06-2016, 04:42 PM   #371
flashed
That is a nice rig ,are you an independent operator or lease to a company ?
Old 09-06-2016, 04:53 PM   #372
Possmguts
Possmguts's Avatar
I signed on with a Small company in North Dakota that a friend of mine also pulls for.
Old 09-09-2016, 11:46 AM   #373
RRR18
RRR18's Avatar
Well.....least I know who to ask when I need truck towed somewhere.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 09-11-2016, 02:15 PM   #374
Possmguts
Possmguts's Avatar
Went for a little imaginary cruise today... She ran like a champ and I smoked a couple mustangs and a few ricers...
Old 09-11-2016, 02:20 PM   #375
flashed
You look good behind the wheel .I used to always love riding in the big rig when our Lowboy driver had to deliver a trackhoe to an out of state jobsite and I had to go help him unload it ,miss the good old days .
