Old 04-29-2018, 02:29 PM   #351
ibrown50
ibrown50's Avatar
Re: Ian's Tennessee Honey '64 Short Box Step-side - England
Well it’s just no good (as my mum would say) I’ve not really had much truck time for the last 6 months and the other UK contributors to this forum have been fairly quiet (from a truck building point of view) too.
Luckily for me there are many threads on here which provide the necessary inspiration when needed, I’ve just re-read Rocknrods 64 stepper thread (that truck is soooo clean) and Bill is almost finished his C3 so it’s time to crack on.
My next job is the last of my rust repairs and I’ve been putting it off for longer than I ought to, so this weekend I’ve completed the tear down. With this truck I have learned to expect that beneath every tiny paint blister is 7lbs of bondo and a rusty hole.
This is what it looked like when I began
Name:  body left2.jpg
I hoped that the drivers side would be better than the passenger side, passenger sides are often worse as they are "in the gutter" but if anything it's actually worse
Name:  sill off 2.jpg
And when I was finished
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 04-29-2018, 02:38 PM   #352
ibrown50
ibrown50's Avatar
The inner footwell was another "work of art" beautifully crafted from bondo and fibreglass
Name:  footwell bodge.jpg
It's in the trash now
Name:  footwell cut out.jpg
One of the floor supports needed a repair but I have a section that got from Martin so that was a relatively quick fix
Name:  repair piece.jpg
Name:  outrigger repaired.jpg
I have the fender to strip next, once I know how bad it is I'll decide whether to repair or replace.
Still not a bad days work
Old 04-29-2018, 04:29 PM   #353
Grizz1963
Grizz1963's Avatar
Ian, at this point my silence indicates only my respect for the members of this forum.
Inside my head the Pirate is swearing at the artists of your repairs.
You are a brave man, but we know it will be good.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 04-29-2018, 05:07 PM   #354
MacQuigley
We having a race to the finish line now we have both started again? :-) :-) :-)
Would be the longest race in history!
MacQuigley is offline   Reply With Quote
Old 04-29-2018, 06:42 PM   #355
Glad to see you back at it. Love seeing your quality work.
Old 05-06-2018, 01:27 PM   #356
ibrown50
ibrown50's Avatar
Thanks Rian, I don't know about brave, more probably too dumb to know any better
Yes Bill I agree, most races need a stop watch, our need calendars
Thanks Bill, that's very kind of you to say so, like most of us on here we do our best with the skills we have
Old 05-06-2018, 01:33 PM   #357
ibrown50
ibrown50's Avatar
Progress update,
On first fitting I discovered the floor / inner rocker repair panel had been mis-hit, it looked as though there had been in-sufficient set on the finish die so effectively it was too short on one corner, this meant the floor would not line up, it wasn’t a lot, but it was enough to be a problem. The simplest fix was to “stretch” it, so I cut it with a plasma disc, pulled it apart slightly and then welded up the gap.
Name:  Floor inner tweak.jpg
Name:  Floor inner tweak done.jpg
With this done the floor fit was remarkably good and it was soon clamped and then tacked in place,
Name:  floor inner1.jpg
Name:  Floor inner welds1.jpg
I have to replace the bottom 6 inches of the A post which is welded to the inner footwell. I find it useful sometimes to trial fit parts (especially re-pops) as a process of elimination. I trial fitted the inner footwell before I cut off the remainder of the A post. It fits perfectly so now if there are any fit-up problems after I repair the A post, I know it’s not this panel.
Name:  footwell trial fit.jpg
Old 05-06-2018, 06:58 PM   #358
Great looking work Ian!
Old 05-07-2018, 02:28 PM   #359
ibrown50
ibrown50's Avatar
Thanks Bill
Onwards and upwards (as they say). Today was a national holiday in the UK so I took the opportunity to make a bit more progress, the bottom of the A post was completely rusted out. I would normally try to replace below the swage for the outer rocker to preserve the original position, however, although it wasn’t rusted through it was so thin you couldn’t have welded it.
Name:  Pillar repair.jpg
First job was to remove the hinge, I marked the hinge and bolt positions so that when I re-fit it, it’s going to be broadly in the right place.
Name:  Mark hinge.jpg
Next job was to mark and cut the pillar, my preferred method is masking tape and a pencil. You can see from the picture below just how crooked the crop was on the repair panel I had to grind it square before using it, don't forget the two spot welds that hold the cage for the hinge plate
the fit was quite poor too, I had to tack the best fit areas and then work the others before welding them. Top tip use a hinge bolt to keep the cage drawn up tight against the pillar, it's impossible to weld up otherwise
Old 05-07-2018, 02:36 PM   #360
ibrown50
ibrown50's Avatar
After that it was just a case of working the panel to improve the fit and then tack, grind - repeat,
When doing this kind of job it's easy to get weld spatter in the hinge threads and to weld up the hinge plate so it doesn't move (not good when it comes to fitting the door) take your time and put a couple of old bolts in the threads if you have them
I got the spot welds from the pillar to the footwell done too,
there's still some finishing off to do on the welds but I'll leave that until I've
done a test fit on the door and outer rocker. This is definitely one of those jobs that take hours and looks like next to nothing when it's finished
Old 05-07-2018, 03:46 PM   #361
jchav62
1962 C-10
jchav62's Avatar
Great work!!!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-13-2018, 04:57 AM   #362
ibrown50
ibrown50's Avatar
Originally Posted by jchav62 View Post
Great work!!!!
Thank you Joseph, that's much appreciated.
A quick update,
Most of know that the universe is governed by certain laws, no not that Stephen Hawking physics stuff, the real laws. Things like why when you drop a piece of toast on the carpet it always lands buttered side down, (a phenomenon increased by a factor of 10 if there is peanut butter or jelly involved), or why when you’re in a traffic jam the other lane always moves more quickly, until you switch lanes and the one you were in starts moving more quickly and the law of repairing trucks……..why does the rot always go further than the repair panel.
Well such was the case with the inner rocker/floor repair panel, the rust went about 2” further.
Actually it's easy to fix as there's plenty of access,
I made a repair piece to match the existing panels as closely as possible (I do hate patches that look like patches.)
Name:  floor patcha.jpg
Name:  hole patch.jpg
and welded in place
Name:  hole filled.jpg
The inner welds need tidying up but should be fine once that's done
Next job is to put the door back on before I test fit the outer rocker
Old 05-13-2018, 07:11 AM   #363
realvc
realvc's Avatar
Very nice repair panel. Your metal skills are impressive. As a matter of fact your whole truck build is impressive.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 05-13-2018, 07:35 AM   #364
Great inspiration there. Wiser words have never been spoke. Great work Ian.
Old 05-13-2018, 07:47 PM   #365
89muscletruck
89muscletruck's Avatar
I just read through your whole thread. I gotta say that your dedication to correcting the *ahem* repairs of the previous owners and your searches for replacement parts in the UK is inspirational. Good job!
89muscletruck is offline   Reply With Quote
Old 05-14-2018, 01:04 AM   #366
Grizz1963
Grizz1963's Avatar
Great work Ian.
You are right about not making repair panels look right.
Your work always makes me smile in approval, not that you need my approval.
Old 05-14-2018, 02:43 AM   #367
MacQuigley
Wish Id done that Ian. I refit my rockers from the measurements Id taken rather than with the doors back on. That was partly because the doors were so bad I had no faith fitting them would give me any better a fit and don't get me wrong I don't thing I'm far out but I think Id have been batter repairing the doors first then the rockers.
Nice to see your getting back into the repairs though.
I hope your outer rockers are better made than the ones I bought. Ended up having to cope up the front on one and the front and back on the other just to get them to fit.
Old 05-19-2018, 02:32 PM   #368
ibrown50
ibrown50's Avatar
Thank you Vince
Thanks Bill
Thank you for your kind words, with this truck there's never a dull moment
Great work Ian.
Thanks Rain, I maybe don't need it but it's nice to get it all the same
You spoke to soon Bill the right hand one was fine but the left hand is diabolical
Old 05-19-2018, 02:58 PM   #369
ibrown50
ibrown50's Avatar
For anyone who has been on a different planet recently (and you would have to have missed this news) there was a wedding today in Windsor. Now I think it's great when folks get married, I'm married myself and very happy with it...........but I'd no great desire to watch the wedding on TV, my wife on the other hand was glued to the TV with box of Kleenex at the ready. This mean't only one thing.....Truck time
First job today was to refit the bottom of the B pillar. I'd removed it for 2 reasons, fiting the inner rocker is much easier with it out of the way and it needed a repair which was easier to do on the bench.
Name:  b pillar 2.jpg
Name:  b pillar done.jpg
Next job was to re-hang the door but I decided to strip it before hanging it, it makes it much lighter to handle and it's going to have to be stripped anyway to do the repairs (I can hardly wait to see what I find ) . I'd marked the bolt positions before I removed it so it went back pretty much in exactly the right position, door gap wise.
I made a gauge for the hole positions using a piece of aluminium angle bar, with a spring loaded punch this makes quick work of marking the holes.
Name:  outer rocker.jpg
They were pilot drilled at 1/8" and finish drilled at 1/4".
Name:  outer rocker1.jpg
After much grunting and cursing I have it fitting pretty good, the door gap is nice but there's a bit of work to do to get the inner part fitting as good as I want it to. It's in place with a couple of spot welds, next job is to take the door back off and finish fitting and welding
Name:  outer rocker3.jpg
A decent days work, I wish there was a Royal wedding every Saturday
Old 05-19-2018, 07:34 PM   #370
MacQuigley
Strangely enough it was the left hand one on mine that was the issue! It must be easier to make repo parts accurately than this!
Old 05-19-2018, 07:40 PM   #371
MacQuigley
Oh How I hear that Ian! My wife who hates driving more than 5 miles, drove the 100 miles to her sisters and the 100 miles back just to watch that damn wedding!
Now despite being a Scot, I guess I'm a Royalist (they may cost us a lot but I believe they bring us in more that the cost) but come on! And no I'm not just upset because she took my car and there is zero chance of me ever seeing the fuel replaced............
So Like you I chose to get on with some motoring tasks.
Much better use of our time if you ask me!
Old 05-20-2018, 09:39 PM   #372
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Very nice work!
Always nice to see a job being done well!
Modges'66 is offline   Reply With Quote
Old 06-03-2018, 12:15 AM   #373
mjh1965
mjh1965's Avatar
Looking good Ian . Looks like the race is back on , but you always seem to be a few steps ahead, with Bill a few steps behind. Mind you at least I won’t come last , as it’s now a three horse race . One of us ( you know who you are ) has put his back in the stable and put a blanket over it .
mjh1965 is offline   Reply With Quote
Old 06-03-2018, 01:14 AM   #374
Grizz1963
Grizz1963's Avatar
Impressive as always Ian.
Just headed out to a bootfair.
Feels like my life is coming back together.
Old 06-03-2018, 07:39 AM   #375
Very nice Ian
