11-10-2011, 07:33 AM | #1 |
Re: What did you do to your truck today?
forgot to add. If this all squares up, hitting the frame shop to double check dimensions and alignment, then will gladly pass along the measurements. It's nothing that hasn't been done before, just wanted to try it Certain amount of pride in doing it yourself. Crossmember is all 1 1/2 tubing 1/8" wall thickness from a chassis shop. It bolts in to stock frame holes,upper control arm only moved forward 5/8" and added 3 degrees more antidive. Only set up for air ride, but if it works correctly, will make a version for coil springs or coil overs.
11-11-2011, 12:52 AM | #2 |
Today i threw away the crappy pepboys brake lights that came on my truck and installed some quality BROTHERS cans.
It would've been pretty easy except for the having to solder a ground to the brake lights bulb housing. This made them WAY brighter. I also ran my own wires and used heat shrink and nylon wire dressing in place of the cheesy plastic that came with them. This is only 1 out of 200 on my list of things to do.
X24 1964 chevy c10 step side 230ci straight six Auto power glide |
11-11-2011, 01:00 AM | #3 |
i forgot to add images for everyone.
11-11-2011, 01:17 AM | #4 |
11-12-2011, 12:04 AM | #5 |
Bout ready to fire it up, need to put the column in, clean up several grounds on the frame, wire up the radio install the kick panels, bought a set with some good pioneer speakers test fit good
11-12-2011, 08:33 AM | #6 |
Installed a Craftec tonneau cover on my 66 gmc swb fleetside.....it has gas shocks and is reasonably priced.....will post pictures later today...
11-12-2011, 08:54 AM | #7 |
Here is a picture of the truck during trial fittting, rear corners do not have all components installed yet so that is why they are sticking up, it went pretty easy for a initial prototype install.
Here is the only modification we had to make to install a Craftec cover on a 66 short wide (at the rear corners this small gussett had to be cut down) Very high quality would be very easy to install after doing one, and if we had read the directions and followed them it would have been easier still. Kieth |
11-12-2011, 07:51 PM | #8 |
Today, I threw out my B&M Unimatic floor shifter and took a page from Delmo's "Great big book of mods and tricks" and converted my E-brake handle to work as an automatic shifter handle. The floor shifter worked, but was really loud and clunky and whenever anyone rode in the buddy bucket, the shifter handle rubbed the back of their knee the whole time. And then, I'd get strange looks from them while reaching under their leg trying to go from reverse to drive or vice-versa. Haha.
Sam |
11-12-2011, 08:15 PM | #9 |
Pictures SAM!
11-12-2011, 08:56 PM | #10 |
Sorry, Awbrown. Here ya go. E-brake shifter handle. Works so much more gooder than the floor shifter i took out.
Sam |
11-12-2011, 09:05 PM | #11 |
You must dim your lights with your knee??? Wheres park all the way up or down ? is it faster than your b&m?? lol
11-12-2011, 09:11 PM | #12 |
As far as what I did today , well I found my bench again ..I put a lot of shelves up and a cabinet that I got out of my friends garage when he moved , sure makes a difference as far as keeping things neat.. I also am working on emtying my 63's bed out because that is where the rest of the stuff from my friends garage ended up..........
11-12-2011, 09:25 PM | #13 |
I have no idea why that dimmer is there. It isn't hooked up to anything. I guess just lazy on my part. I have a switch in the floor that works as intended, so i never thought about removing the other one till today. (Still haven't done it) Faster - HAHA. Nah, I just liked that it cleaned up the floor a bit. It will definitely be a conversation piece!!
11-12-2011, 10:11 PM | #14 |
Set the Cab on the Caprice frame to mock up the mounts. Tacked in the rear cab mounts and started making the front cab mounts. Channeled the front cab supports..
11-12-2011, 10:18 PM | #15 |
Put my CPP column in, used a flaming river joint, lokar linkage, two thumbs up, easy install, still working on the wiring getting close
11-13-2011, 01:23 AM | #16 |
That linkage is sharp looking.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
11-13-2011, 10:28 AM | #17 |
Spent all day yesterday on the gauge surround. Bead blasted first than started sanding 500 1200 1500 grit than buffed and buffed than the gauge plate it had scratches 1200 and 1500 than buff buff and a little more buffing . I'm going to have the painter clear coat it
11-13-2011, 09:30 PM | #18 |
very nice.....it looks better than new!
11-14-2011, 03:53 PM | #19 | |
I have pics of mine on this same thread (page 167)
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
11-14-2011, 04:09 PM | #20 |
I SCORED today. I picked up a 1 1/4" Sway bar for my 64 pickup. It came from a 1 ton Dually - a 77 I think. It cost me a meager $20.30. What can I say I'm CHEAP! Now tonight I'll bead blast it and paint it. Working graveyard does have its advantages. I'm the only mechanic on graveyard so as long as there's no major break downs I have plenty of time ot work on my own stuff. As long as I don't get caught I'm good.
11-15-2011, 12:07 AM | #21 | |
I had scouted that one out last week and dropped by there today at lunch to grab it and a steering link for my stepson. Imagine my surprise when it was gone. Grats! There will be more, before I'm actually ready to install it.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
11-14-2011, 11:36 PM | #22 | |
11-13-2011, 12:08 AM | #23 |
I bought it!!
Posted via Mobile Device |
11-13-2011, 01:21 AM | #24 |
Patched the frame, broke down the rearend.
11-13-2011, 10:39 PM | #25 |
Got sooo much done this weekend.
Fan Relay Installed Headlight harness + Relay upgrade Taillights installed Radio Installed SP wires installed Split Brake Lines + new Impala Master Cylinder Seatbelts installed Front coils cut for a nice little rake Wheels cleaned, prepped, and painted black and most importantly.... Fired her up for the first time in a year!! A lil video... |
