Closed Thread
Old 03-26-2012, 08:59 AM   #3726
Redleg
Redleg's Avatar
Re: What did you do to your truck today!
Cleaned her up and went cruising!
Joel
Originally Posted by prostreetC-10 View Post
Some trucks in the air, some layin' frame.
some are super cool, and some kinda lame.
Some kinda slow, and some really fast.
some run on 110,and some on pump gas!
Redleg is offline
Old 03-26-2012, 12:11 PM   #3727
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Originally Posted by shawno72 View Post
Finished reassembling my freshly rebuilt tranny.
did you get all your balls in the right place?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 03-26-2012, 12:33 PM   #3728
shawno72
C/10 junkie
shawno72's Avatar
I don't know let me ask my wife
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 03-26-2012, 12:45 PM   #3729
jchav62
1962 C-10
jchav62's Avatar
Scored a tailgate for $50.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline
Old 03-26-2012, 12:52 PM   #3730
shawno72
C/10 junkie
shawno72's Avatar
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 03-26-2012, 10:29 PM   #3731
70C10Toejam
Hellasick
70C10Toejam's Avatar
Since I haven't been on for a while...
Saturday changed the oil and greased front end. Two plugged zerks on control arms and broke one on a ball joint that ended up having a couple cuts in the boot too.
Today, hauled 1086 lbs steel and 224 lbs copper to scrap yard.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline
Old 03-26-2012, 10:57 PM   #3732
npoe2982
drove the old thing to work threw some stuff in the back and drove it home. i goosed it a couple of times, and got annoyed at the squealing caliper. best of all i dug a trench for a french drain in my yard and returned time and again to deposit and with draw empty and full cans of beer. good day.
npoe2982 is offline
Old 03-26-2012, 11:04 PM   #3733
mud.man.rj
mud.man.rj's Avatar
Got frustrated trying to change my drivers door, the truck just had new cab corners and rockers installed before I bought it and installed a bit high are the rockers, so cutting them off tomorrow night then refitting it myself, some people just don't pay enough attention to detail do they. Oh well, just take a bit longer to get doors on.
mud.man.rj is offline
Old 03-27-2012, 01:51 AM   #3734
Stevo427
Swapped the whole front grill. Repainted and polished my front badge. Put my grill trim in also painted my eyelids black.
Stevo427 is offline
Old 03-27-2012, 05:04 AM   #3735
LakeAnna
LakeAnna's Avatar
Thumbs up Re: What did you do to your truck today!
Wet sanding...
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline
Old 03-27-2012, 07:11 AM   #3736
JointTech
JointTech's Avatar
pulled the diff cover off. found out I have a 14 bolt out of some later year. Need to check ratio tomorrow.
Also discovered my carrier bearing is completely shot abd the drive shaft looks to far out on the spline. Good thing is the carrier is probably my weird wobble when just taking off.
Also discovered I have a TH400 not TH350 so I had to update my sig.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline
Old 03-27-2012, 08:00 AM   #3737
wrwelton
wrwelton's Avatar
Glove box went in. Putting in rubber boots around floor shifters next.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 03-27-2012, 08:15 AM   #3738
KyFarm
KyFarm's Avatar
Got the seat back from the upholstery shop and in it went. Should have been a straight swap but the seat I got from what was supposed to be a '72 was the same dimensions for the cover but had totally different rails and bolting pattern. And of course the new holes I had to drill hit just about half a hole in the support member. A little grinding and a little dremel tool and in it went.
Also put 3 point seat belts in
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline
Old 03-27-2012, 10:49 AM   #3739
MrSchaeferPants
MrSchaeferPants's Avatar
Last night, but I went to bed right after so no posty
Tailgate hinges and brackets finished in Sail Blue
Tailgate stripped, and barely a coat of primer on it
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline
Old 03-28-2012, 08:31 AM   #3740
wrwelton
wrwelton's Avatar
I decided to put the seats in my truck to see what they will look like. They came out of a 2006 suburban. I found them at a junk yard last week. Iam most happy
wrwelton is offline
Old 03-28-2012, 06:19 PM   #3741
mud.man.rj
mud.man.rj's Avatar
Really like those seats a lot, do they fit good for lenghth and also with the t.case shifter. Jealous, would be nice in my 71 4x4. Someday I may score as good as you did.
Old 03-28-2012, 08:07 PM   #3742
mmmBoost
Bought some temp seats for the truck for $50 from a friend Honda Prelude. They'll work till I can find the seats I really want
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 03-29-2012, 01:01 AM   #3743
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Threw a 10ft aluminum brake in the back to deliver to my cousin. Gonna suck the gas down like a whiskey sour on a hot day, but it will give me the same smile driving it.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 03-29-2012, 01:07 AM   #3744
JointTech
JointTech's Avatar
Changed the tranny filter.
Put the Diff cover back on and filled it up.
Pulled out the driveshafts to replace the ujoints and carrier bearing.
shes almost roadworthy.
72 C20 Long Bed
Old 03-29-2012, 05:46 AM   #3745
norske
New Tunes.
norske is offline
Old 03-29-2012, 08:03 AM   #3746
wrwelton
wrwelton's Avatar
I have not bolted them down yet, but I did sit in it and it seems like it is going to work just fine. I paid $100.00 for them. I am not sure Iam going to keep the center console. i am thinking of building one that will give me some storage space and a couple of speakers.
wrwelton is offline
Old 03-29-2012, 05:31 PM   #3747
Rob H.
Rob H.'s Avatar
This is actually a what I did in the last 4 days post LOL! Monday evening I pulled the driveshaft and the 3 speed tranny to replace the clutch. Replaced it Tuesday night with the 12 inch clutch and heavy duty pressure plate that came with my 70 burb parts truck. Then I decided I'd put the 4 speed out of the burb in my truck. So Wednesday night I did this!
Today after my bus route I pulled this from the burb frame, sure wish I'd got the 402 that used to sit in front of it!
Then I slid it under the truck after checking it out, I rigged this up to lift it up into place, yea looks a little redneck, but it worked great and sure alot less lifting for me!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 03-29-2012, 06:06 PM   #3748
shawno72
C/10 junkie
shawno72's Avatar
That is totally genius.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 03-29-2012, 06:13 PM   #3749
JointTech
JointTech's Avatar
dropped my driveshaft at the shop to have the end cut off and a new one put on, balance and put in new ujoints.
72 C20 Long Bed
Old 03-29-2012, 07:12 PM   #3750
Scott Webster
Sheetmetal Psycho
2x! definitely something I would do!
Closed Thread
