04-02-2012, 09:15 AM | #3776 |
Re: What did you do to your truck today!
04-02-2012, 11:26 PM | #3777 |
Found out why more horn was blowing last night, horn button popped off....found it on the seat this morning...
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
04-03-2012, 01:48 AM | #3778 |
finally replaced the dash bulbs today....boy what a difference at night now....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
04-03-2012, 10:20 AM | #3779 |
I haven't done much, still taking parts off as opposed to putting them on. So I took pics. My plan is to pressure wash it this weekend.
1968 Chevy C/10 LWB V8 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
04-03-2012, 10:30 AM | #3780 |
Junior Member
I went out to the garage and looked at the rust damage on my '67 cab which is located under the cowl and just shook my head and left confused. This is nothing unusual for me since this is the first truck I have tried to fix with so much rust.
Decided what the heck, might as well go to my son's house and see how he was doing on restoring the '68 GMC swb fleet and to have the evening meal with them. When I got there he was just getting back from test driving the truck, it was not running right so I watched him adjust the carb. After eating we decided what the heck, might as well put the hood on since it was the last piece of the sheetmetal to go on after painting. I had never adjusted one myself so I learned it takes time, patience and a lot of adjusting if you have taken a truck all the way apart and painted each piece individually.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-03-2012, 10:38 AM | #3781 | |
Junior Member
Most people probably would have just got another cab, but since I wanted to learn how to repair rust we cut out rust and put on at least 12 repair pieces. I am lucky because my frame was cleaned by a PO who never finished the build. All I have to clean up is the front cradle and firewall.
04-03-2012, 12:25 PM | #3782 |
finally got the 5" tach installed
04-03-2012, 04:55 PM | #3783 |
bbadfred
I am a day late but yesterday I DROVE mine for the first time since 2000!!!!! Today worked on the kick panels and speaker wiring
04-03-2012, 11:56 PM | #3784 |
Junior Member
Here is a few pictures of the '67 swb GMC I helped my son put the hood on yesterday.
My son is in the background of one of the pictures taking a picture with his cell phone.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. Last edited by Shyguy; 04-04-2012 at 12:12 AM. Reason: add more pictures |
04-05-2012, 08:20 AM | #3785 |
Well its time to work on the grill. I removed the center and coated it with oven cleaner. Wow that stuff works great. I have sanded it down with 600 grit where scratches were bad and now I am sanding it with 800 grit, wet sanding the whole way. I think I will go with 1000 grit and see how it looks. I am putting the windshield and slider in this weekend. Should be stasrring the truck next week.
I know I can! I know i can! 72 K20 Restoration |
04-05-2012, 08:35 AM | #3786 |
Guess I did not know you could sand the grill to shine like that by wet sanding using 800 to 1000 sand paper....looks nice good job.
04-05-2012, 06:18 PM | #3787 |
It still needs to be buffed. I painted around headlights today and working on plastic grill. Anyone know if I should paint leading edge of plastic grill.
04-05-2012, 08:43 PM | #3788 |
upper and lower radiator hoses, replace radiator, water pump,thermostat, wire harness from fuse block
trying to get the temp gauge to work picked this up monday
WITNESS Dont be like me be better than me |
04-05-2012, 08:47 PM | #3789 |
67-68 original chevy blue steering wheel
04-05-2012, 10:16 PM | #3790 |
The driver side lock mechanism was stuck so I lubed everything and found a broken spring in the door handle. The lock & handle work fine now even with the busted spring.
Next up is a headlight warning buzzer (NAPA 7821637).
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
04-05-2012, 11:58 PM | #3791 |
Fun Stuff
Congrats, must feel good!
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
04-06-2012, 09:13 PM | #3792 |
installed new front 2 1/2 drop spindles , zinc coated drilled and slotted rotors,new ball joints,tie rod ends,pitman arm , ect.new motor mounts and trans cross member
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
04-06-2012, 11:07 PM | #3793 |
67cheby
Nice
Posted via Mobile Device |
04-07-2012, 12:55 AM | #3794 |
Cleaned her up good for the first show of the year.I'll take some pics of what is there and post them.
Where do you post pics of the shows? Here or somewhere else? |
04-07-2012, 08:03 AM | #3795 |
Decided it was time to tackle some tranny leaks! I have been working on these trucks for years but transmissions are one place I'm very weak at , that said I'm very happy with the result. The truck is a 71 C-20 402/400 , leak at the modulator so I pulled it and when I called the local parts store they had one in stock and it was $6 so that was a no brainer! Next came the speedo assembly, I managed to remove it without breaking anything, brought the whole thing to a tranny shop where they put all new seals in it right there and charged me $10, so both leaks were repaired the same day for under $30 without breaking anything! I know this is long winded but seldom do things go this smooth.
04-07-2012, 09:44 AM | #3796 |
Wasnt today... but Thursday night I dropped in the motor and trans!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
04-07-2012, 10:12 AM | #3797 |
Wow! Looks like thats going to be one hot little 6.
Brad handshoe |
04-07-2012, 11:07 AM | #3798 |
Truck and auto performance nut
yesterday I completed 90% of the new efi fuel system. I had to add a return and make some fitting/end changes, which ultimately wound up in my removing all the 1/2" aluminum tube and -8 AN fittings and s.s. hose...and replacing with -6 AN s.s. hose and fittings.
today..finish the fuel system, install a few sensors...and on to wiring!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-07-2012, 11:25 AM | #3799 |
found a plug wire resting on the header...... nice burnt wire so I replaced with a longer set that can actually route better..... running pretty good so wonder how long that was going on!!!!!!!!!!!!!
04-07-2012, 11:28 AM | #3800 |
Who's got steelies?
Finished testing my modified speedometer.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
