#3801 |
Re: What did you do to your truck today? Chapter II
#3802 | |
Thanks!
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#3803 |
Happy day!
![]() ![]() ![]() Oh yeah, what I did this weekend! seat repaired from this ![]() to this ![]() then removed the bench seat, removed all of the fuses and took a drimel tool with a wire brush and cleaned the fuse panel clips and fuses, put bulb grease on all of the fuses then put them back in, then put the seats in ![]() I have made some repairs over the past few weeks also: ![]() ![]() I also removed the glove box button and fixed it (WD40 and worked it until it was easy to push in and out) ![]() I remember this thing not working from when I was a kid, we would be going down the road and all of the sudden WHAM! open glove box lid across the knees! I got it in and operated it a few times, then closed it, I went to put some screw from the bench seat into the box for safe keeping, I can't get it to open now! I'm waiting for me to be going down the road and it fall open on my wife's knees! |
#3804 |
Old member
Over the weekend I went from broke to new with brake light switch.
From this: To this: With this added to it:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3805 |
#3806 |
All I did today (yesterday) that was truck-related was to pump out the water from my derusting electrolysis tank. That greasy air cleaner left me an oil slick in the tank so I tried to get the water out without taking the oil with it (not a complete success).
#3807 |
![]() Join Date: Oct 2015
#3808 |
![]() Join Date: Dec 2015
I turned The Green Barge into a solar oven. lol
![]() Next door neighbor gave me 3 bags of Kale grown in all organic, grass-fed fertilized, screened soil from some sacred valley in Timbuktoo. Wife got Italian organic cold-pressed virgin non-GMO grass-fed Holy olive oil, added some Himalayan volcanic ash salt blessed by Tibetan monks smoking killer green bud. I then put on vintage cast iron pans, and put in the cab, for drying. Before I pulled any out, checked the temperature with the Ryobi (it's green color) infrared thermometer, 165°F was the highest reading. Now I can impress the Toyota Pious owners.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#3809 |
#3810 |
Yesterday I got a big ole box of goodies from Manes. New gauge cluster bezel, tach/vaccum gauge conversion, dome light harness (my truck is so basic the dome light isn't connected to door switches), courtesy light harness, new engine harness with HEI provisions and a new temp sending unit that will hopefully get the dash gauge back to reading properly (pretty sure I have the wrong sending unit in there).
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#3811 | |
![]() Quote:
#3812 |
Are those really gauges in your dash panel or printed cutouts? LOl maybe an optical illusion.
#3813 |
I got a little done today.
I tested my fan motor from the heater, it works great. I think testing it now was a better idea than putting it all back together and then testing it. ![]() I also scotch brite padded my heater box and washed it off. After a liberal use of ZEP Big Orange and lots of scraping and brushing, I was able to remove all the old gasket from the part of the heater box that has the big round rubber gasket. I'm hoping to put the heater box back together soon and get on with reassembly of my truck. |
#3814 |
![]() Join Date: Oct 2014
Back out under the beech tree paint booth, I got the top primered in preparation for seam sealing the drip edge.
#3815 |
Wife bought me a hammock for my birthday.
Found the PERFECT place to hang it! |
#3816 |
Swapped the old wore out seats for 2014 Tahoe 2nd row leather seats.
#3817 |
Solved my misfire problem in the HEI (bad rotor) and installed a new temp sending unit. My factory gauge now reads properly. I hope my near future upgrade projects all go as well. Can't wait to get that new gauge cluster in with a factory tach and vacuum gauge. Now that I have all the factory gauges working properly I'll probably take the aftermarket underdash gauges out.
#3818 |
How did you handle seatbelts?
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#3819 |
Next weekend project!
#3820 |
Truck came with these seat covers so decided to use them for now. Replaced trans pan gasket last weekend but put a little too much fluid. Got this harbour freight suction thing, worked great. Added clamps to it to keep hoses from coming loose, not bad for 6.99.
#3821 |
I finished detailing and putting my instrument cluster together.
#3822 |
Those seat covers look very nice indeed .
A word about recovering seats : the foam illustrated is shyte and partially the cause for early failure and always the cause of uncomfortable seats . Black or grey foam is *much* harder and gives vastly better support . oddly , Automotive Trim Supply Houses never seem to carry it . I go to Furniture Trim Shops , and be wary as the pricing can be all over the map , in a bad way . Once you use hard foam or (better) cotton batting , you'll never go back .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#3823 |
Painted the top Pure White this morning.
Brad handshoe |
#3824 |
![]() Join Date: Aug 2009
#3825 |
