Closed Thread
Old 04-09-2012, 07:51 PM   #3826
Rob H.
Rob H.'s Avatar
Re: What did you do to your truck today!
I finished up my 4 speed swap Saturday, knowing I'd have to pull the driveshaft again to replace the U joints, I had to make the rear section of the driveshaft to mate it to the 10 bolt. I spent a couple hours at the junkyard trying to find one the length I needed with no luck so some work with the grinder and chopsaw and welder and I was in business. The carrier bearing looked to be pretty decent still so wasn't too worried about it. Drove it to church yesterday morning then out to eat and to the parts store to pick up the U joints and rear brake shoes. Dropped my wife off at the grocery store and ran to get gas, that's when it happened, the carrier bearing seized and spun the rubber out of it. Limped it to home as it wasn't slapping around too much till later. Took it out and beat off the old bearing and called it a day. After my morning class today I stopped and picked up a new carrier bearing. Got in this afternoon from my bus route and got the new front U joint in and the new carrier bearing on and put in the front section of driveshaft. Hopefully tomorrow I'll get the the other two U joints in and the rear shaft back in the truck. I love the truck with the 4 speed now! Next is replacing the rear brakes. Then I'll move onto new rockers and cab corners!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 04-09-2012, 11:15 PM   #3827
Hotrob72
Hotrob72's Avatar
New steering wheel
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline
Old 04-09-2012, 11:43 PM   #3828
72peace
72peace's Avatar
Man, you make me feel like a slacker, i just took off the bed...
72peace is offline
Old 04-10-2012, 12:48 AM   #3829
ItsRandy
ItsRandy's Avatar
I got my radiator support and radiator installed today. I bought an Entropy radiator with 1.25" tubes...man, that sucker is huge. It just fit (tightly) into the 4 row core radiator brackets. My truck is starting to look like a truck again.
ItsRandy is offline
Old 04-11-2012, 07:14 AM   #3830
wrwelton
wrwelton's Avatar
Battery is in, fuses are in , radiator pressure is good. Just sent out bumpers to be painted, get them back tomorrow. Start engine on friday!!! Need to install innnerfenders, bolt down seats and connect fuel line to gas tank. Ordering reese hitch today,. Still waiting for some chrome parts but it won't stop me. First car show April 22. I will be there hell or high water. Say a prayer for me.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 04-11-2012, 02:39 PM   #3831
Redleg
Redleg's Avatar
As of 4pm today she will be sold! back to the original owner! going to miss her! but hopefully something better awaits!
Joel
Originally Posted by prostreetC-10 View Post
Some trucks in the air, some layin' frame.
some are super cool, and some kinda lame.
Some kinda slow, and some really fast.
some run on 110,and some on pump gas!
Redleg is offline
Old 04-11-2012, 06:26 PM   #3832
Shyguy
Junior Member
Shyguy's Avatar
A local guy that restores these old trucks stopped by for a while. We went over to the shop and looked at my '67 cab on a swb '69 frame and talked about how I can fix some rust issues.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 04-11-2012, 06:42 PM   #3833
Dunenutt
Newbee
Dunenutt's Avatar
Yesterday I took the truck for a little cruise. I quickly found out that it has become a fair weather pansy! After about 20 miles in 95* weather things got a little heated. 215 on the motor, and 210 on the trans. This simply will not fly!
I came home a little irritated, removed the grille, and installed two plate style tranny coolers.
Today, I ordered a high volume water pump, a 6 blade 19'' fan, super duty fan clutch, and a build it yourself aluminum fan shroud. I added to the order, a selection of high flow thermostats.
This truck will be able to cruise in 118* with the air on full blast! If this won't fix it, I am building a new motor, that is not .060 over!
Dunenutt is offline
Old 04-11-2012, 10:13 PM   #3834
Tomahawk30
Tomahawk30's Avatar
Added power steering to my 70 C10. A previous owner had installed a 350 out of a van and it still had the power steering pump, so I just had to get the correct hoses and a gearbox. Picked up the gearbox over the weekend when I went to pick up a pair of CST doors that I found on Craigslist. Surprisingly easy conversion! Now I just have to figure out how to get my steering wheel to sit straight when the wheels are centered....
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline
Old 04-12-2012, 01:17 AM   #3835
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Took my truck on a cruise for the 1st time since new years. Didn't realize how much I missed cruising the old truck till I took off from a stop sign and lit up the tires in 2nd, 3rd, and 4th gear and didn't straighten out until I was doing 60 MPH.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline
Old 04-12-2012, 02:05 AM   #3836
74baggedbug
Hated the wood grain steering wheel that came with the truck, and don't have the extra 450 for a billet steering wheel so I figured I'd give this a try and painted it the same color as the truck... Not to sure on how I feel about this
74baggedbug is offline
Old 04-12-2012, 08:33 AM   #3837
67cheby
67cheby
67cheby's Avatar
I like it painted
67cheby is offline
Old 04-12-2012, 08:40 AM   #3838
67c10rustbuket
67c10rustbuket's Avatar
Originally Posted by 67cheby View Post
I like it painted
X2, bug what color is that?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline
Old 04-12-2012, 08:51 AM   #3839
jjzepplin
jjzepplin's Avatar
I have the day off some I'm going in! Air conditioning-You will be mine!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline
Old 04-12-2012, 08:52 AM   #3840
RexDodge
Last night I worked on fabbing up my 3" exhaust (with an X pipe). Man I wish I had a lift. All that trial fitting, crawling under and out over and over. That 3" takes up alot of room but I got it all tacked together and pulled out to finish up the welds...and then ran out of wire! Grrrrrrr....
RexDodge is offline
Old 04-12-2012, 09:47 PM   #3841
74baggedbug
It's called cobalt blue met. It's a newer Chevy color, paint code wa855 if I remember correctly
Old 04-12-2012, 10:00 PM   #3842
buz48
I put the right door back on my 70 stepper all by my self with the help from a cheery picker.( necessity is the mother of invention)
buz48 is offline
Old 04-12-2012, 11:29 PM   #3843
74baggedbug
Put the steering wheel back in
Old 04-12-2012, 11:46 PM   #3844
Fatkid1983
Fatkid1983's Avatar
I really like it! Good choice
1971 chevy c10 cheyenne. Bagged. New paint and some other mods.
1999 ford f350 superduty 7.3 powerstroke everything banks
1975 c10 swb "parts runner" <----SOLD
NorthWest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Fatkid1983 is offline
Old 04-13-2012, 12:45 AM   #3845
mud.man.rj
mud.man.rj's Avatar
Wasn't sure on the picture of painted steering wheel, but installed it really fits in and isn't to much at all, good choice painting it.
mud.man.rj is offline
Old 04-13-2012, 04:07 AM   #3846
wrwelton
wrwelton's Avatar
I stopped by paint shop and he was painting my bumpers, I will be painting back side tomorrow and then bolting them on. Spent time glass beading my mag wheels and hope to have them mounted tomorrow. Painted inner fenders and bumper brackets today. I am still waiting for a shipment from LMC which will deliver the fuel sending unit and then I can start truck saturday morning. I grounded the bed , cab and radiator support andf fixed water leak on block. I think i will have it ready for car show on 22nd.
wrwelton is offline
Old 04-13-2012, 10:24 AM   #3847
Glorybound13
Junior Member
Glorybound13's Avatar
Got a parts truck for my '69 over the weekend, so I spent the other night taking the front end of that apart. Did a little spot welding to cover up the side marker lights on the right bedside. BTW 74baggedbug, love that color. Never was much a blue fan till lately, but that's a beautiful shade of it.
1969 CST-10 - "Glory Bound" - build in process (slow going)
1971 Cheyenne 10
2006 GMC Yukon XL Denali
Isaiah 46:4 - I will be your God through all your lifetime, yes, even when your hair is white with age. I made you and I will care for you. I will carry you along and be your Savior.
Glorybound13 is offline
Old 04-13-2012, 08:16 PM   #3848
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The old battlewagon has been sitting a lot lately. Gotta get it ready for firewood, had to charge the battery to fire it up. Brakes have been on & off mushy (pedal going down too far, have to pump to get good pedal -- just part of the time). So I recruited my wife's help and we bled the fronts. Didn't notice any air in the lines (bleeders were both plugged though). Took it for a short drive and it's about the same.
Siggghhhhh...... didn't really want to pull the rear axles to bleed the back brakes.
The MC is just a few years old so I *think* it should be okay.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline
Old 04-13-2012, 09:48 PM   #3849
70STOVEBOLT
70STOVEBOLT's Avatar
Well it wasn't today, but last Saturday I replaced a left rear wheel seal and the right rear wheel cylinder. Then on Tuesday the muffler blew apart. So it looks like this weekend's project will be exhaust work...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 04-13-2012, 10:15 PM   #3850
bollybib
bollybib's Avatar
Nothing.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Closed Thread
