#3826 |
Re: What did you do to your truck today? Chapter II
#3827 |
![]() Join Date: Dec 2012
Was wet sanding some, but man it is 95 here, so I am off until evening.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#3828 |
I installed my new gauge cluster housing now sporting a full compliment of factory style gauges. I only had to pull it back out once, the damn printed circuit had a bad spot and one strip short circuited and melted. I was able to fix it with a bypass but I shouldn't have to with a brand new part. Anyway, finally got everything working. Then I started in on my Digi-Tails LED tails install. Egad they make it complicated, more complicated than it needs to be I think. And then they have an error in their instructions about the size of mounting holes to drill. This caused a good hour's extra work to compensate once the holes were drilled. For the price they charge, their instructions should at least be accurate.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#3829 |
#3830 |
Yesterday I pretty much completed the install of LED lights all around. I started a separate thread with a link to a Youtube video if anyone is interested.
#3831 | |
#3832 | |
![]() Quote:
As I said , I like and prefer fixing things .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#3833 |
Lace painted the roof, and painted the logo on the doors of my shop truck today.
Quite satisfied to be honest. ![]() ![]() ![]() ![]() And I had to do something about the result of a lousy painter who did the paint and prep work for the previous owner. ![]() ![]()
Driver carries no cash. He's married. '67 Chevrolet C10 SWB - 350 Vortec/TH700R4 Backyard Engineering Last edited by C-10 Norway; 06-08-2016 at 06:54 PM. Reason: Adding a picture |
#3834 |
I installed dome light switches and courtesy lights. Can't believe they built so many of these without door activated dome lights. It got too dark as I was working so I left it until tomorrow to tidy up the wiring and better attach it up under the dash.
#3835 |
Old member
I got the bed cover alarm switch installed to go with the rest of it. I have a nice working system with shock senor and doors hood and bed cover triggers.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3836 |
drove it up and down the street for the first time.
#3837 |
That's funny, I couldn't wait to drive mine just like that. No windshield hood or bed. But man it was a since of accomplishment. Good for you.
#3838 |
Finished installing the courtesy lights. Found some pre-existing holes in the bottom of the dash so I didn't even have to drill any extra holes! Love when that happens.
#3839 |
With the help of a great guy Thanks Adam My new to me 72.
#3840 |
Your 72 looks like mine. Mine is fairly new to me. You can see it on my build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
#3841 | |
Re: Original Air Cleaner
Right when I had decided to paint them in gloss (after painting this piece in Mar Hyde satin), I looked under my hood at all my other rusted engine parts and realized.....no matter what I do, this part will look out of place. LOL |
#3842 |
Today I made a huge advance! Not to my truck, all I did to it was to rust treat some rusty screw holes.....but I helped the freight truck driver load up the two crates I built for the fellow member in Canada! I had to get those out of the garage so I could get the room to get back on my truck. Seeing that box truck leave caused me to almost jump for joy!
#3843 | |
Yuo're correct ~
It's supposed to be glossy black . Agreed it'll look out of place for a while but that's normal in regular Service and Repair . I still don't know if it's oil bath or paper element typ.... -Nate Quote:
#3844 |
I loaded some stuff in the bed and scratched the heck out of the new paint and Its still not drive able yet =8-^ .
C'est la Vie , it _IS_ my Shop Truck .
#3845 |
This the first trail fit with all the boards and bars. Looks great and with it being composite it is finished once I screw it down. I need to trim a little off some edges but that's it.
#3846 |
A member on here told me mine was a dry air cleaner. When I mentioned how oily it was, he explained that was due to how badly worn out the engine it came off was.
#3847 |
I finished installing my door glass and regulators, looks like I'm gonna be buying a new set of regulators though, seems they are very hard to operate,the passenger side more than the driver side.
First impressions of my new electric vacuum pump set up for my brakes was well worth the money I spent in setting it up.you can barely hear the pump when it's running and I never had any problems braking,whatsoever. I still need to get an alignment, I can hear my tires squalling going into turns. But other than that, I guess I'm almost ready to graduate ![]() Pictures to come later. Have a great weekend! Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
#3848 |
![]() Join Date: Sep 2015
Drilled and bolted my front 4 link brackets after cleaning and priming the mating surfaces that will get missed by powder coat so far. The No Limit stuff is really nice. I plan to finish up the upper coilover mounts as well today and get things aligned in the rear. Then it's on to the "cross" member placement and I can finish cutting out the old cross members and boxing the frame. Then I'll get it all welded up.
#3849 |
![]() Join Date: Oct 2014
This was done Thursday actually. I took advantage of a calm morning and got the white sprayed on the top. I added some flattener to the paint, don't want it to look too new and shiney.
#3850 |
That's a great looking truck! And I see already rolling on rally wheels!
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
