Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-19-2025, 11:42 AM   #3851
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
image by [url=https://www.flickr.com/photos/97391199@N06
Need to tie into backup lights and NSS Electrical is not my strong suit to say the least
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-19-2025, 12:18 PM   #3852
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
Does the Lokar have a switch for back up lights or just nss?
litebulblsc is offline   Reply With Quote
Old 03-19-2025, 10:54 PM   #3853
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Switch will accommodate one or the other, but not both
Yeah, that’s the problem, just one tang to activate the switch, just b/u lights or reverse lights
So I started to search and found a kit that has two tangs one each for each function NSS and B/U lights
It seems to be this part number BL1400U
But it mounts down on the shift rail problem averted sort of. How do I wire it up, sure wish Vet vett was around maybe I should drop down to the electrical forum
SAFETY FIRST
AS usual, off topic
Jim
Old 03-21-2025, 01:30 PM   #3854
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Used my impact/driver to pull my sheet metal screws out
Having the seal under the head of the screw helped with keeping the body panel adhesive off
Faster then cutting SS heads off
SAFETY FIRST
AS usual, off topic
Jim
Old 03-29-2025, 10:14 AM   #3855
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Letting body panel glue set up
SAFETY FIRST
AS usual, off topic
Jim
Old 03-30-2025, 08:14 PM   #3856
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well I have to admit this body panel adhesive is as strong as welding, problem with welding you can’t weld aluminum to steel
I’ve pushed and pulled on the cage nuts and they didn’t break free
So this was a win/win for me
image by image by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 03-30-2025, 08:43 PM   #3857
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
im all in on the Body Panel adhesive I used it on my rear roll pan on the last build welding would have meant ...repainting etc. great progress Jim
zicc1835 is offline   Reply With Quote
Old 04-01-2025, 09:53 AM   #3858
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for stopping by Jess, your interior is looking great on the Grand Thief Auto
I wonder how many other people have used panel adhesive not for intended purposes
Keep up the great work on your project, maybe see you soon?
Studs aren’t quite lining up so I’ll go back and get them all started, adjust as needed, repete, repete
SAFETY FIRST
AS usual, off topic
Jim
Old 04-08-2025, 11:32 AM   #3859
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
It’s always the last bolt that won’t cooperate….i even tried to chase it with a tap
Now the whole thing has to come apart
SAFETY FIRST
AS usual, off topic
Jim
Old 04-08-2025, 08:26 PM   #3860
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
[quote=jaros44sr;9379502]It’s always the last bolt that won’t cooperate….i even tried to chase it with a tap
hate that when it happens
ALWAYS the last one ...we should start with that one
image by [url=https://www.flickr.com/photos/97391199@N06[/quote]
Old 04-08-2025, 08:56 PM   #3861
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well at least you’re having success with your interior looks fantastic BTW
SAFETY FIRST
AS usual, off topic
Jim
Old 04-08-2025, 09:25 PM   #3862
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
thanks Jim weather breaks ill call and try to set up a visit drive him out by you
Old 04-14-2025, 12:14 PM   #3863
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
5-10 minutes 40gritwith DA knocked it down quick
Well ventilated as I didn’t read precautions dust mask wouldn’t hurt, it has a limited warranty, so that can’t be good
New DA $23 Chinese's
Filled pin holes in my crappie weld
SAFETY FIRST
AS usual, off topic
Jim
Old 04-17-2025, 09:08 AM   #3864
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Loud click, ignore or fix
Tighten set screw CLICK spray lubericate, loud click again thought I stripped the Allen drive, nope, turned the nut in the cage
Vise grip?
SAFETY FIRST
AS usual, off topic
Jim
Old 04-27-2025, 09:54 AM   #3865
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Seems an old v/ c grommet fits the bill
SAFETY FIRST
AS usual, off topic
Jim
Old 05-05-2025, 09:33 AM   #3866
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Spent some time chasing threads, at this point I don’t need a cross thread
And ran the studs down short
SAFETY FIRST
AS usual, off topic
Jim
Old 05-06-2025, 11:14 AM   #3867
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SAFETY FIRST
AS usual, off topic
Jim
Old 05-06-2025, 11:35 AM   #3868
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Putting everything on a tray, means I only have one thing to pick up
SAFETY FIRST
AS usual, off topic
Jim
Old 05-08-2025, 08:27 AM   #3869
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Don’t you just luv it when an idea in your head actually works out. So, panel bond does work for adhering aluminum to steel
SAFETY FIRST
AS usual, off topic
Jim
Old 05-13-2025, 09:57 AM   #3870
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Started to assemble my computers, found an ‘oh sh!t’ meter as well as a trans temp meter
SAFETY FIRST
AS usual, off topic
Jim
Old 05-16-2025, 09:30 AM   #3871
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Chips flying, need more room to gain access to the bolt
SAFETY FIRST
AS usual, off topic
Jim
Old 05-19-2025, 11:51 AM   #3872
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Finishing the balance of my relief cut, seems a 3flute cuts better or my 4flute was dull, but the 3flute clears chips better
SAFETY FIRST
AS usual, off topic
Jim
Old 05-23-2025, 02:49 PM   #3873
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Seems like a good time to try super glue and backing soda on the pvc plug
Drill bit didn’t want to cut rubber,maybe try the soldering iron
SAFETY FIRST
AS usual, off topic
Jim
Old 05-29-2025, 10:10 AM   #3874
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Wanted to cushion anodized cover from nuts, thinking about studs instead of bolts
5/16 washers on 1/4-20 studs
Black and white wires I want to hook up to the light on control panel
Fuse holder can mount on lip of dash to conceal extra holes from the Po’s handy work
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2025, 10:34 AM   #3875
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Chip’s flying again need clearance slots to access bottom studs
SAFETY FIRST
AS usual, off topic
Jim
