05-06-2016, 01:17 PM | #3876 |
Post Whore
Re: Restoring Rusty
sure enough my old radiator cap leaks like a sieve, does not hold pressure at all
05-06-2016, 01:22 PM | #3877 |
Post Whore
Re: Restoring Rusty
so bought a new one, $5 bucks
tested it as we test all parts new or old here at Suburbs Garage Inc. and it tests good took the truck for a test drive with the new cap, and results: no change, truck runs just as hot remember all the cap does is increase the boiling point do to the added pressure, it does not effect how hot your engine runs, so the result was expected, but its still good to have a proper working cap |
05-06-2016, 01:23 PM | #3878 |
Post Whore
Re: Restoring Rusty
side by side for prosperity
the new cap was designed by someone who actually owned and operated a vehicle cause it has two edges for you to grasp whilst screwing or unscrewing it, unlike the original which was perfectly round and nothing to hold on to, win, win |
05-06-2016, 09:02 PM | #3879 |
Re: Restoring Rusty
I know in our race cars we only ran water. Then sometimes we'd run Water Wetter which did help especially on the fifty lap races of stop and go. Eventually we went to an electric fan from a Volvo and that cooled the engine nicely. As for the bypass hose if you can't find one start looking at 3500 trucks with the 454 engines in them. I had to replace that stinking hose on our work truck. Good luck and get to cracking.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
05-07-2016, 07:56 AM | #3880 | ||
Re: Restoring Rusty
Ok, so I'm really unenlightened when it comes to this stuff. I have a couple of questions - what is it that I'm trying to scratch and how do I know when the panels are ready to accept the paint? I took the panels off of my truck, cleaned at least one of them up really well with Simple Green because it was what I already had in the garage. In those areas where the panel, the one that I cleaned, is NOT chalky, my fingernail doesn't leave any sort of mark. But in the chalky areas, YUP! I do leave a mark. When I clean it a second or third time, there is no difference. What's up with this? Can you help? |
05-07-2016, 09:27 AM | #3881 | |
Post Whore
Re: Restoring Rusty
05-07-2016, 09:37 AM | #3882 |
Post Whore
Re: Restoring Rusty
pressure tested the cooling system next, and heard a hissing sound by the inlet hose (top driver side) there appears to be a tiny crack/leak there and another tiny one somewhere towards the passenger side on the bottom, not show stoppers, but this do place the radiator on the Parts Replacement List
05-07-2016, 09:42 AM | #3883 |
Post Whore
Re: Restoring Rusty
Gentlemen I'll be brief:
NO THERMOSTAT NO PROBLEM DISCLAIMER: We are not going to run without one, this is just a great clue. Last edited by Gregski; 05-07-2016 at 10:24 AM. |
05-07-2016, 10:08 AM | #3884 |
Re: Restoring Rusty
did you try a high flow thermostat yet?
05-07-2016, 10:27 AM | #3885 |
Post Whore
Re: Restoring Rusty
05-07-2016, 10:46 AM | #3886 |
Re: Restoring Rusty
It has a larger area for the water to flow through so is not so constricted,they are a little pricey $15 or so
05-07-2016, 09:27 PM | #3887 |
Re: Restoring Rusty
After seeing that, I for one, would condemn the Duralast Thermostat. If the engine is that cool without a thermostat, I would have to think the AutoZombie part is not working correctly. It may be opening enough to not overheat, but not opening enough to get the temp where it needs to be.
I would try a better part. Maybe a Stant? Maybe a 160 or 185 degree just for some wiggle room.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
05-07-2016, 09:32 PM | #3888 |
Re: Restoring Rusty
Get a 180º AC-Delco thermostat.
05-07-2016, 09:46 PM | #3889 |
Re: Restoring Rusty
Stick with the stock 195, but get a quality unit. You want the engine to come up to normal operating temp. This helps a bunch of things, among them lubrication.
Rich Weyand 1978 K10 RCSB DD. |
05-08-2016, 09:53 AM | #3890 |
Post Whore
Re: Restoring Rusty
first I plan to test mine
then I intend to step up to a name brand one, and test that one before even installing it next I think we may need to run a 180* or even a 160* F with the Vortec heads, only testing will tell and finally theres that high flowing thermostat option, who knew this little guy had so much impact, (what a control freak) ha ha as an FYI I will save drilling holes in the Thermostat as the last resort, lol |
05-08-2016, 12:04 PM | #3891 |
Re: Restoring Rusty
What kind of head gaskets did you use?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-08-2016, 12:19 PM | #3892 |
Moderator
Re: Restoring Rusty
High flow thermostats would be the units like the 195°F Stant 45359 SuperStat
To regulate coolant at roughly 195°F the thermostat needs to be fully open at 200°F and closed somewhere around 180°F. You don't want to run 160°F thermostats in a daily driver. Fuel mileage and engine longevity will suffer. Normal coolant temp should run between 200°F and 230°F. This will keep the engine oil above the boiling point of water to boil off any condensation and unburnt fuel to be exhausted out through the PCV system... These temps will still keep the oil below the temps where it'll start to burn and coke up the engine and the combustion chamber will run at a fairly efficient temp. The 1970's OEM temp gauge is a poorly calibrated guide at best. Only slightly better than a warning lamp because it gives you a heads up before you get to OMG IT'S TOO HOT. Most aftermarket gauges are little better. If you really want to know what temps the engine is running you'll need a good quality infrared thermometer. The $30 Lowes, Home Despot, and Horrible Fright units don't qualify. You're going to spend over $70 for a decent one. My old Fluke cost over $130 There really is no reason to trust a 42 year old nail head sender. If it's a new unit it's likely either badly matched to your gauge or, if it's a Letric Limited unit, defective.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-08-2016 at 12:29 PM. |
05-08-2016, 12:36 PM | #3893 |
Post Whore
Re: Restoring Rusty
these are the cylinder head gaskets I am using GM Chevrolet Performance part number 10105117 as per the GM turn key engine build specifications
05-08-2016, 01:23 PM | #3894 | |
Re: Restoring Rusty
The Harbor Freight infrared thermometer unit I have has actually been pretty accurate when checked against more substantial units. May vary unit to unit, but mine at least seems OK. Agreed also on the sender units with one exception. American Autowire makes a 1513321 correct substitute, with the resistance curve matched to the 1978 and earlier gauges. Any other substitute will not match the gauge.
05-08-2016, 06:21 PM | #3895 |
Re: Restoring Rusty
We used to use an infrared unit from HF while checking tire and rotor temps on the race car before switching to probes. The HF worked fine and was well calibrated against the probe long acre unit we used.
05-09-2016, 08:31 PM | #3896 | |
Moderator
Re: Restoring Rusty
The Fluke was pricy but It's been great since day one.
And please let us know if and how your repairs were successful. |
05-09-2016, 09:05 PM | #3897 |
Post Whore
Re: Restoring Rusty
so tested the 1999 Suburban Valucraft thermostat rated for 195* F
it also don't open until 205*F |
05-09-2016, 09:09 PM | #3898 |
Post Whore
Re: Restoring Rusty
more importantly gauges showed up, we got a brand new Summit brand water temp gauge in green and a matching oil pressure Summit gauge also in green (we'll deal with that one later)
naturally it came with a 1/2" NPT adapter (would it kill em to send the 3/8ths?) so it will be mounted in the water outlet initially than transplanted to the intake manifold driver side |
05-09-2016, 09:10 PM | #3899 |
Post Whore
Re: Restoring Rusty
What's in the big white box?
patience ODBI |
05-10-2016, 12:03 AM | #3900 |
Post Whore
Re: Restoring Rusty
alright so equipped with the brand new digital water temp gauge and sending unit it was time to go back to square one and install the 195* F thermostat back in to see how hot actually the truck runs, and so we did and guess what the guage never read above 199* F and we drove it hard for 30 minutes like we do in all our tests
by the way I love this new gauge it says a number and the word TEMP what more do you need, it is absolutely brilliant but wait does it show the display in 7 different poser colors, absolutely NOT, and we love it that much more for it the gauge took about 10 minutes to install and 9 of those minutes were spent looking for long enough cables to install it in the cabin, lol black to truck ground red to switched 12 volt power blue to sending unit purple (is a mickey mouse wire for dimming the gauges) no thanks for now so while driving ie moving we were reading 194* F and while stopped at a red light we were reading 197* F Last edited by Gregski; 05-10-2016 at 12:12 AM. |
