Old 02-03-2012, 02:40 AM   #3901
57truckguy
Re: Project Vitamin C-10
Here is the controler I used on my jeep to control the fan at all times. I really like it as it gives you adjustable temp control for the fan, compressor turn on for the fan, and run after ignition shuf off to cool the raditor and engine, and has only one wire to the engine and thats to the compressor. Very simple and very compact and very easy to install.. Only 79.95 plus shiping... Brian is an engineer and designed and builds these.. They will handle any fan you may wish to use even the heavy amp draw mark VIII fan many of us jeep owners install to cool the engines.
57truckguy is offline   Reply With Quote
Old 02-03-2012, 02:41 AM   #3902
57truckguy
Forgot to include the link here it is..
http://dccontrol.com/relay_controllers.htm
Check it out I think you will like it, its classy just like your build.
Old 02-03-2012, 10:40 PM   #3903
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by 57truckguy View Post
Alan , I just went to Napa an ask for a temp switch that turned on at 190, Real cheap and easy.
I figured that I wouldn't need the compressor switch since anytime the engine gets to 190 the fan would come on anyway.. Some add an additonal fan to come on when the ac compressor is on for the extra insurance to keep the engine cool during slow( parades,etc,) driving. May be needed may not. depends on how good your cooling system is setup.
I acually used the triary switch setup, a little more complated but a safer system for the ac..
If I had it to do over I would probably go with the binary system to give some protection to the compressor and keep the wiring simplar.
Thanks for all the help. Since I didn't plan on a trianary switch I'll run with out it. I might change my mind before I get the AC done. I'm going to get it running and on the road then do the AC. I'll check on the check temp switch for now.
I was able to spend about 6 hours on the hood today. I wiped it then guide coated it and used air tools to knock off the crust. Then I guide coated and blocked with 80. The top is done with 80. I still have to do the sides. Then i will guide coat and block with 120. If all is good I will buzz over with 180 and apply the slick sand.
Alan's Classic is offline   Reply With Quote
Old 02-03-2012, 10:48 PM   #3904
allaboutchevelles
allaboutchevelles's Avatar
Looking real good. I know its going to turn out perfect for you.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 02-03-2012, 11:03 PM   #3905
flips72
flips72's Avatar
hoods looking good, but i knew a man with your skills have no problem with that.
flips72 is offline   Reply With Quote
Old 02-04-2012, 03:44 AM   #3906
57truckguy
Alan, Sorry I thought that since you are south you would be running with an AC for sure... Since you aren't then go with the simplest diagram and be doen with it... Who needs more headackes... LOl
Old 02-04-2012, 01:55 PM   #3907
daverod
SSN 706
daverod's Avatar
You should make alittle movie of when you turn the key for the first time. Even if it does'nt start the first time. Be sure and get a close up of your face. Maybe a big fat chew in and a pinner hanging out.
daverod is offline   Reply With Quote
Old 02-04-2012, 09:42 PM   #3908
Alan's Classic
Thanks, I hope so. When it gets close to the end it's hard not to cut corners by saying that's good enough. I have to keep the integrity.
No need to be sorry, I will be running AC. It will be hooked up later. I'm still not sure where I will run my lines for the AC.
Sorry we missed the first expression. Believe me it was a look of concern. Wondering what was gonna leak, burn, blow up etc. lol
I filled the radiator with almost 4 gallons of 50/50 with my vac pump. I sucked the system down to make sure it would hold a vac.
Well, it is alive. Start up was pretty good. First the lines on the tranny were loose. Then the tranny cooler lines on the radiator leaked. After several times tightening down I thought something was wrong. My gut was right. After removeing the lines we discovered there weren't any flares in the radiator. I called Summitt and they said it's 1/4" NPT. Shannon and I spent 3-4 hours looking for a fitting. No luck so I just ran a bypass hose for now.
Line fittings are very confussing to me. It's a 5/16" OD line with inverted flare to 1/4" NPT. Correct like this one.
Here is a video of it running. I still have some tuning to do.
Old 02-04-2012, 09:51 PM   #3909
Cameron 1137
Cameron 1137's Avatar
man that sounds good!
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 02-04-2012, 10:04 PM   #3910
chad64chevy
chad64chevy's Avatar
man alan, when i clicked on the video and heard it running i just got a big grin on my face, lol!! great video, finding the leaks are just part of the progress! i think you'll be done before summer get here and the rate your going!! i think i got another year on mine before its road ready!! keep the videos coming, there better the pictures, lol!!
chad64chevy is offline   Reply With Quote
Old 02-04-2012, 10:34 PM   #3911
allaboutchevelles
sounds great. very nice
Old 02-04-2012, 11:08 PM   #3912
likaroc13
Rollin' Old Skool
already congratulated on Facebook, but i think it's worth another...so,
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 02-05-2012, 12:14 AM   #3913
greg65
greg65's Avatar
Sounds great Alan. It's all down hill from here.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 02-05-2012, 01:59 AM   #3914
66ChevyMax
66ChevyMax's Avatar
Sounds great, congrats.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 02-05-2012, 02:55 AM   #3915
57truckguy
Very well done... classy as always.
Old 02-05-2012, 09:41 AM   #3916
flips72
flips72's Avatar
sounds great as everyone else has said... now quit grinning and get back to work
Old 02-05-2012, 12:55 PM   #3917
daverod
SSN 706
daverod's Avatar
Congrats..... You need to find another project....Fast.
Old 02-06-2012, 12:31 AM   #3918
Jeff La
Glad you got it going, sounds good.
Jeff La is offline   Reply With Quote
Old 02-06-2012, 12:38 AM   #3919
Alan's Classic
Thanks for all the kind comments guys!! BTW, i'm still grinnin'
Dave, I can't afford to do another. If I do another it will be on someone elses dime.
I'm such a tard sometimes. When I fired it and it ran for a while I noticed the cooling fan didn't come on. I jumped it and later found that there wasn't any power coming from the fuse block to the relay on the radiator support. I wish I would have paid attention before, because the fuse panel has a fan relay built into it. In the schematic the right 2 terminals are for the for the fan relay. The green is the ground. At this point I'm going to ground the relay in the cab and just use the relay out front.
Since it can move under it's own power, I pulled it outside and gave it the first official bath. Of coarse I took some pics as well.
Old 02-06-2012, 12:48 AM   #3920
bubba327
HOW long until spring??
bubba327's Avatar
Alan I love the U-tube clip.. You have a driver!!!!!!!!!!!!!!!!!!!!!!!!!!! Congratulations we are all like a bunch of proud dads! way to go!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 02-06-2012, 01:15 AM   #3921
cjracing15
cjracing15's Avatar
Man! Alan you have something to be very proud of. That truck has turned out just awesome!!! I want to come and see it in person one these days. Makes me want a 64-66 BAD! Congratulations!
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 02-06-2012, 01:54 AM   #3922
C10LIFE
C10LIFE's Avatar
The 55 is way cool
C10LIFE is offline   Reply With Quote
Old 02-06-2012, 11:03 AM   #3923
66ChevyMax
66ChevyMax's Avatar
Alan that is one sweet looking truck, you have done some awesome work.
Craig
Old 02-06-2012, 05:25 PM   #3924
65Custom
I always seem late to the show but I agree with everyone else sounds awesome!!!!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 02-06-2012, 06:08 PM   #3925
protrash64
Resistance is Futile
protrash64's Avatar
Your truck looks great Alan; whats the ETA on the fenders?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
