Old 05-28-2007, 12:55 AM   #376
1969k10stepside
Re: Its the shortbed's turn "Project Junkyard Resurrection"
Originally Posted by GREASEMONKEY72 View Post
hurry up and get that engine in there already
Hopefully it's in in the next 2 weeks.The only thing slowing me down is brake lines and motor mounts.Now I have both,just to get them on.
Originally Posted by BurnoutNova View Post
damb, you guys always get so much done... i get sidetracked all the time and never get anything done... ive been parting out 2 trucks and tryig to help a friend with his blazer so i havnt made any progress on my 71 at all
You will get to it eventually.Hopefully,he will come help you since you helped him with his.
1969k10stepside is offline   Reply With Quote
Old 05-28-2007, 02:41 AM   #377
GREASEMONKEY72
GREASEMONKEY72's Avatar
i bet the brake line will be fun
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-30-2007, 12:44 AM   #378
1969k10stepside
Tonight...I took some stuff like headers,intake,carb,etc back off the motor in preperation for the motor going in.I also nearly got the rear axles brake lines bent and ran.Just one more bend and the rear axle lines are done...Next is the lines through the frame...which shouldnt be that hard
Old 05-30-2007, 07:21 AM   #379
msgross
msgross's Avatar
you need to get a new camera Dustin!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-30-2007, 03:04 PM   #380
1969k10stepside
Yeah...I know.
Here is some pics I don't think I ever posted.....The front clip is sitting un level because I didnt have the correct mounts
Old 06-03-2007, 09:22 PM   #381
1969k10stepside
Well,I was trying to figure out the motor mounts today.I have the mounts that mount on the block with 3 bolts,I was also thinking there was more "rubber" that went on the bottom of the crossmember.I,after cleaning out my parts shed looking for some,decided to go back to the chassis and look at things again.I got a old mount,a bolt,and a washer and bolted the mount down to the crossmember as it would be with the motor attached.That's when I came to the conclusion that the only mounts for the motor were the ones that bolt,with 3 bolts,to the block.So,now that the situation has been solved the motor is ready to go in.I never up till this afteroon had the oil pan on.So,I got the gaskets and bolts and bolted the pan down.The motor,still not all done is ready to atleast be set in the chassis where it can be finished.I'm hoping the motor is in by the weekend.I still have to finish running front brake lines first.
As for the motor,I just need to install the intake,carb,valve covers,harmonic ballancer,HEI,headers,etc.Stuff that can be done with the motor in the chassis
Old 06-03-2007, 09:52 PM   #382
mattsz
mattsz's Avatar
Your getting there .
mattsz is offline   Reply With Quote
Old 06-04-2007, 11:24 PM   #383
1969k10stepside
Yeah...sorta.11 months ownership now! I got the motor off the stand and attached to the hoist.Its sitting on a block of wood now but is still attached to the hoist.Tomorrow the motor goes in! I got out the flywheel and cleaned it up so tomorrow the flywheel goes on,the convertor,the tranny gets bolted on,then it all goes in.I slide the O ring in between the t case and tranny,bolt the tranny to the t case lower the motor in a bit more and then bolt the motor down....so,11 months into ownership the motor will be going in.
Now,11 months may seem like a long time to get this far but I really didnt work on it till Late October or Early November.I think I did good considering the chassis was blasted and painted,the axles were rebuilt,the motor was rebuilt,the lift was installed...and who did all the work?...me! 95 % of the work was done right in my little 30x40 shop.The only outside the shop work was having the block bored,and having the tires put on the rims.
I'm just a little ashamed to say whats in it for being close to running,but not actually running...
Old 06-05-2007, 12:52 AM   #384
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Why be ashamed Dustin are you not proud of what you have accomplished cause I sure am and I think it is well worth it IMHO.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 06-05-2007, 10:14 AM   #385
1969k10stepside
I'm just ashamed there is nearly 6 grand in a truck that doesnt even run... I will be happy when it runs though,thats one of the pay-offs
Old 06-05-2007, 10:21 AM   #386
estig70
estig70's Avatar
at least you know what you have though, a brand new old truck.
Eric
estig70 is offline   Reply With Quote
Old 06-05-2007, 10:27 AM   #387
1969k10stepside
Eric
Eric,you're about half right..Cept only about 40% is new.The only new stuff on the truck is the lift,shocks,bushings,all the motor parts with the exception of the block and crank.The lugnuts,the lockouts,bearings and seals.Brake lines.So far all the rest was original.Which I did want.95% of the body is original which is a plus when it comes to gaps and body lines.But,the build wasnt about buying new stuff,its about buying stuff from junkyards and bringing it up from the dead back to life.
Old 06-05-2007, 10:44 AM   #388
65-72 chevytoys
65-72 chevytoys's Avatar
Way to go that is something to be proud of. I sure would be and having fun while doing it. That is what this hobby is all about. I would rather have a truck like yours that I built myself than some trailer queen that I am afraid to drive.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 06-05-2007, 11:20 AM   #389
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
looks good..your oding good so far..the price is not to bad, if you had of had all of the work done at a shop, you would be into it for more than you are,,so id be proud..
billy
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 06-05-2007, 11:56 PM   #390
1969k10stepside
Motor is in! Got the motor and tranny bolted together and bolted to the transfer case tonight.Need to adjust the motor position a little and tighten it all down...Yet another mile stone...
Old 06-06-2007, 10:00 AM   #391
estig70
estig70's Avatar
thats what I meant. Not the fact that NEW stuff was bought but the truck itself is brought back alive. You basically have a NEW old truck and you can't go buy a NEW truck for what you have in yours nowadays. I'll stop now, ha ha ha!!! Can't wait for the finished product though, keep up the good work, by the way I have started on mine and I get alot of encouragement and motivation by your thread here, THANKS!!!
Eric
Old 06-06-2007, 10:29 AM   #392
Yukon Jack
Post Whore
Yukon Jack's Avatar
Congratulations! Awfully exciting when the motor is back where it belongs. How soon until you expect to be able to fire it up?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-06-2007, 10:34 AM   #393
1969k10stepside
Your Welcome
Eric
A few weeks at the earliest,I still have to adjust the rockers,install the intake,buy a smaller carb,buy a new distributor,buy a fuel pump,buy plugs and wires and some other small stuff and then the motor will be ready.I'm filling up the differentials today getting them ready for the road.I have the body back off so it would be easier to put the motor in so while its still off Im gonna fix the cab rust.Then its just bolting it all back together and wiring it.I figure it will be on the road by the end of summer but it will come back apart somewhat to be painted in the winter...I'm getting anxious though.I wanna hear it run! I started my motor work when you pulled the 400 from your k5.I just was post poned with this truck and didnt start again to nearly a year later.The motor for it now was originally planned to go in the other 4wd but things changed...
Old 06-07-2007, 10:23 PM   #394
1969k10stepside
Got the differentials topped-off with fluid.Motor,tranny,t case all tightened down.Going to *try* to fire it this weekend.Need to get a distributor,plugs,wires,water pump first.Then try to get the radiator hooked up and see if she runs!
Old 06-08-2007, 07:55 AM   #395
msgross
msgross's Avatar
you forgot one other item.... A CAMERA!
I finally started putting springs on mine, woohoo... I like doing "clean" work don't you...
The Garage:
Old 06-08-2007, 08:03 PM   #396
1969k10stepside
No hurry on the camera Actually one might be showing up soon,never know.I might just wait and buy one after the truck is together enough to move so the first new pics are of it stuck in a mud hole
So,you are running a 2" lift (add-a-leaf) in the rear and stock height in the front? Did you have the springs re-arched?That might bring the height back up some.The front springs were easy to put in on mine,but the back were a P.I.T.A. Mainly because of the arch of the lift springs.
Old 06-09-2007, 10:40 PM   #397
1969k10stepside
Well,today I got the transfer case and tranny filled up.I got the starter on.I bought a new water pump,plug wires,spark plugs,fuel pump,and some other stuff.Tomorrow I hope to fire the motor....let there be life....So,if you are driving through southern Indiana tomorrow and hear a noise its probably my lumpy cam'd open header'd small block getting broke in
Old 06-09-2007, 10:43 PM   #398
RACINJASON22
GEARHEAD
Nothing like a
It brings new life to the build when you reach this point also.
RJ22...
Old 06-10-2007, 02:47 AM   #399
GREASEMONKEY72
man i would looove to hear that
-steven
Alte Seele S.S.
Old 06-10-2007, 10:23 PM   #400
1969k10stepside
Well,I didnt get the motor fired...getting close though.One more chance at it and it should be ready.I got the fuel pump,water pump,and intake bolted on.I probably would have got the motor fired but I need to get the harmonic ballancer on.So,before the motor can start I need to....install carb,install distributor,install plugs and wires.Install exhaust.Fill motor up with oil.Hook up radiator and fill it up.Put on valve covers and then get it ready to rumble...Junkyard run tomorrow.2 hour one way drive,so I wont get any work done tomorrow..Hope to get some parts though!
