Re: The '67 Burb Build Thread
greased the few things that needed it, put the wheels back on and dropped it back on the ground. aired it all the way up and let it all the way down, found out i need to trim a little off the bottom of the carrier bearing crossmember as it is holding it up a little and not letting it lay completely out. also found out i need to loosen up the core support bolts and shift it to the drivers side slightly.
still plenty of clearance
gonna fix the leaky rubber fuel line/glass fuel filter on the engine tomorrow that sprung a good sized leak before it catches fire or somthing. also might take a trip to brothers but not sure yet, maybe next week i will go instead of tomorrow. soon i will have the windshield in and the brakes will be blead. also waiting on my 1" wheel spacers as the 1.5" ones i have push the rear wheels out to close to the fenders for my liking
how you gonna mount your hood? porter built?
most likely(thats what i want) but will have to save up for it so it will be a while as that is not exactly a top priority lol. unless i find something else that will work for cheaper that will be what i buy
haha ya you have no chance of using the stock ones!
nope sure dont lol, that and i dont have them any more anyways, i traded them for that passanger fender
fixed the fuel leak by replacing the whole line with a metal hard line instead of rubber, replaced the fuel filter. found out i need to replace the power steering belt and might as well change the alternator belt while i am at it. also found out the money i had deposited in my bank account the 25th mysteriously vanished
![]() ![]() ![]() ![]() ![]() ![]() Last edited by project 67 sub; 02-27-2011 at 02:59 AM. |
Sorry to hear about the bank issue, but, if you have your receipt that will get worked out and credits coming your way if you have any over draft/return fees!
In regard to your hood, why not do a tilt forward, you could get all the mounting hardware from the junk yard, there are tons of the early 90's buicks and caddy that had this factory...would be a cool mod and solve the problem of original location for tire clearance. Man, would really like to come and check out your 'burb some time.. Adam |
thanks, and i have thought about that, but would have no idea how to do it and get it right, does it all bolt in minus the welding of some stuff to the hood, is it pretty easy?? if you wanna check it out, i plan on going to the cpp show if i can get this bank issue situated fast enough and have enough money to make it, or, you could come and swing by the pad if you are ever out this way. just give me some notice like the day before and we can exchange some #s and i can give you some directions on how to get here. what ever would work better for you.
rolled it partway out of the garage so i could take a pic of the chrome exhaust tips that i had installed a couple of weeks ago, installed the new black license frame and smoked lens on the rear plate and also the 2012 tag. took a few pics of each side of the front end through the engine compartment, then put it back in the garage and blead the brake system
nam great job on the suspension! i like the rear licsense plate and light!
#13 | |
dave
lookin good man u do good work son......added a picture of my forward tilt hood
check out my build "DIRTY BURB" ![]() |
#14 |
thanks, i like it better now too than when it had the spike frames. if you are wondering what the license plate light came from, it was from a late 80's early 90's nissan sentra if i remember right lol.
edit: also does anyone know why one front wheel (drivers side) sticks out farther (has always been this way since i have owned it)? the front sheet matal is all ligned up best as possible, and the very front is centered with the bumper, all suspension is tight, nothing loose or bent. any ideas would be greatly appreciated. thanks Last edited by project 67 sub; 02-28-2011 at 02:08 AM. |
#15 |
the frame rails are probably tweaked.... take it to an alignment shop
#16 |
thats the only thing i can think of as well because it has been wrecked before, somtime before my friend that i bought it from got it. if that is the problem hopefully it isnt to expensive to fix or it will have to wait a while.for it to be done. i wonder if it is possible that the body is not ligned up right on the frame?
#17 |
low n' slo
![]() Join Date: Mar 2009
you got any pics of the front end showing the wheel sticking out? just curious...im thinking its a tweaked frame as well, especially since you put new spindles on it than stock.
that tilt does look cool!
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#18 |
1sik7t2
thanks bro, and i try lol. thanks for the pic. was it easy to do the tilt hood, and do you think it would work with a front bumper?? kev2809 no, no pics, its out about an inch or so compared to the passanger side, and yes that tilt hood looks nice wonder if it would work with a bumper. |
#19 |
finally installed the arm rests, bought some stuff from brothers trucks, installed the glove box liner i bought at brothers trucks today, the screw holes dont line up for crap except the 4 bottom ones, and to make the side ones line up i had to put it in their a little crooked and then trim part of the box that stuck out past the dash
#20 | |
dave
likin those door panels, looks clean ...as far as the tilt hood with a bumper, yeah it should work, actually wish mine didnt come down so far, it hides my billet grille...the tilt came from a buick skylark or something like that,, beamers have them too u just have the extend the bar, ....was it easy??? i didnt do it myself (dont have those skills or that patience) the guy that did it didnt seem to ***** to much ...i can take pictures of the hinges and
![]() Quote:
#21 |
thanks lol. but they are just plain painted black steel panels. some day may get coverd or replacedd with home made ones then covered. haha ok yah that would be cool on the pics of the hinges. how much did the dude charge you to do it??
#22 |
dave
it was kinda a bro hook up....and he did them the same time he narrowed my control arms $ 800 bucks total i think the hood was $200 or something
#23 |
#24 |
#25 |
low n' slo
lookin good! what you could do is put stops on the top of the core support to keep the hinges from dropping all the way down, then it could work with a bumper. i say go for it..im thinking about it now lol. its a good alternative when you have tire clearance issues. something im about to figure out in the next couple of weeks when i start on my fenders.
