Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-21-2013, 12:31 AM   #376
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
Here is a helpful thread for those of you wanting to put power steering on your 4x4.
http://67-72chevytrucks.com/vboard/s...d.php?t=561288
Old 01-02-2014, 03:17 PM   #377
65 C20
Hello Captain.
I have a 65 C20 that needs power steering.
I would like to order a P/S box adapter and one of the tube and flange pieces.
I thought that you would be my first post but it went out looking for P/S pump brackets.
I know everyone wants pictures so will post later. Let me know payment details. Cal.
65 C20 is offline   Reply With Quote
Old 01-03-2014, 12:03 AM   #378
Captainfab
60-66 Nut
I'll send you a PM with payment details.
Originally Posted by 65 C20 View Post
Hello Captain.
Old 01-06-2014, 12:03 AM   #379
65 C20
PayPay sent. Please ship to the CA address.
I woulld just like to verify the process.
I have a 65 C20 . I will be installing a pre-76 P/S pump and box. Non metic.
Lets say 1974. So for P/S hoses I will order for a 74 truck ?
The pitman arm will also be for 74, does a Moog #6143 sound right.
The idler arm should be OK but if I wanted one it would be a Moog #K14 ?
I will change out the rag joint, to fit 74 box ?
I think thats it.
Did I miss anything ?
Just want all the ducks in a row when the time comes
Cal.
Old 01-06-2014, 01:01 AM   #380
Captainfab
60-66 Nut
I did receive your payment Cal, thanks
I will get your order shipped out tomorrow.
Are you going to be keeping the '65 C20 idler arm, or are you also converting to front disc brakes and the '74 steering linkage? As for the hoses, that will depend on what engine you have and whether it has the short or long water pump. If you have a small block with a short water pump, I think the '68-'72 hoses would work better. If you have a small block with a long water pump, then the '74 hoses should work.
I think thats it.
Cal.
Old 01-06-2014, 01:25 AM   #381
jlsanborn
jlsanborn's Avatar
That's customer service!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-06-2014, 01:49 AM   #382
65 C20
Hi John.
I will be keeping the 65 steering and drum brakes.
It has a 283 with short water pump.
Not sure what the water pump has to do with P/S hoses ?
Cal.
Old 01-06-2014, 02:04 AM   #383
Captainfab
60-66 Nut
The hoses are a different configuration and length since the PS pump mounts differently on a short water pump engine versus a long water pump engine. Assuming that you have the correct PS pump mounting brackets, I would go with the '68-'72 hoses.
Hi John.
Cal.
Old 01-06-2014, 02:05 AM   #384
Captainfab
60-66 Nut
I try and be quick about shipping when possible.
Old 01-06-2014, 11:10 PM   #385
65 C20
A big thank you John, Captainfab for all the uesful info.
I think now I have a handle on all that I need.
Thanks Cal.
Old 01-11-2014, 02:22 PM   #386
65 C20
Parts recieved in CA.
Will be here at the end of the month.
Thanks for the speedy service.
Cal.
Old 01-14-2014, 08:33 AM   #387
pdxhall
pdxhall's Avatar
Hey John, I guess I'm about ready to change out my steering gear so if you could PM me your info I'll get some money sent your way. If I get the adapter plate from you now can I get the rest, if needed later, for the $20? I'll be changing out the stock column for a tilt but I haven't got to that part, yet.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-15-2014, 12:09 AM   #388
Captainfab
60-66 Nut
PM coming your way
Old 01-15-2014, 05:52 PM   #389
earl84
PM sent for payment instructions and my address.
earl84 is offline   Reply With Quote
Old 01-16-2014, 12:34 AM   #390
Captainfab
60-66 Nut
PM replied to
Old 01-24-2014, 05:47 AM   #391
pdxhall
pdxhall's Avatar
The package arrived today. Thanks again.
Sanity'66
Old 01-28-2014, 03:15 AM   #392
Rickey-Lee
interested in the power steering adapter plate, could you P.M. me purchase instructions? thanks, Rickey-Lee
Rickey-Lee is offline   Reply With Quote
Old 01-28-2014, 11:33 AM   #393
Captainfab
60-66 Nut
PM sent
Old 01-28-2014, 11:42 AM   #394
Rickey-Lee
I saw a post that said modifications to steering linkage was necessary if there was a disc brake conversion? I have just finished installing the conversion, so what changes am I going to need to make to install the power steering setup?
Old 01-28-2014, 11:54 AM   #395
Captainfab
60-66 Nut
What steering linkage are you running? The power steering pitman arm will bolt up to either a '63-'66 or '71-'87 draglink.
Old 01-28-2014, 12:31 PM   #396
Rickey-Lee
stock '64 Suburban with the addition of the disc brakes which includes the dropped spindles and new tie rod ends ect.
Old 01-28-2014, 04:57 PM   #397
Bigru
Bigru's Avatar
Captainfab, I'm ready to add Power Steering to my 65. It has a 292 and Iv'e converted over to disk brakes, I bought the kit from CPP. I have no idea of what it will take to get this done but I'm sure you will get me headed in the right direction.
Bigru is offline   Reply With Quote
Old 01-29-2014, 01:00 AM   #398
Captainfab
60-66 Nut
The power steering pitman arm will bolt right up to your '64 draglink.
You're going to need a '68-'87 C series power steering box with the pitman arm, and my adapter plate to mount the box to the frame. If you are keeping the original steering column you may also consider the tube and flange, if you do not have access to a drill press and welder. Additionally you will need a power steering pump, brackets and hoses for your 292.
Old 01-29-2014, 01:48 AM   #399
Rickey-Lee
Thank you, I 'm going to have to fab something up for the pump. I'm not running the stock 292. I've got a performance 327 with the double hump heads, so no tapped holes to mount to. Had the same problem on the other side mounting the alternator, the center dump manifolds I am running don't have the cast mount. But a cool bracket from Summit, some steel and the two tapped holes in the block for forward motor mounts and it all worked out.LOL And I've got a drill press and welder, you made fabbing the flange easy with your photos. So just go to my PAYPAL account and send an even $50 to your email?
Old 01-29-2014, 02:20 AM   #400
Captainfab
60-66 Nut
My statement about the 292 was directed at member Bigru
It sounds like you're running a long water pump? If so, that's why you're having issues mounting your accessories. If you had the short water pump, everything would bolt up with factory parts.
The power steering box adapter plate is $60.00 with shipping.
