04-16-2011, 09:26 AM | #376 |
Re: post your 67-72 4x4
you can definetely see how the axles are aligned more properly in the wheel wells...chassis and drive train were tweaked really well...
ted cruisin in my '67 K-20 '67 Custom Sport Truck '55 Chevrolet 3100 w/ 235 il6(Powermaster) '63 Chevrolet 1/2 ton 250 il6 '65 Chevrolet 1/2 ton 283 V8 Last edited by silvertip67; 04-16-2011 at 09:27 AM. |
04-18-2011, 12:39 PM | #377 |
Still plays with trucks
Stock 4x4's are so rare around here I never noticed the wheel placement problem.
I put them where they looked right when I set up my 67 4x4 conversion.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
04-21-2011, 10:49 PM | #378 |
I am not a real expert in matters like tire sizes etc...I did a slight suspension lift ...as mentioned before...I have 235 X16" on the truck now(as pictured)...how big can I go?? 265 or 285's??
just looking for a bigger tire to ride on the beach...and of course a bit cooler ride/look...well at least I am honest...LOL...walmart has the goodyears (ATV) in those sizes...and there is a wal mart about 25 miles from here...about 800 bucks for a set...what do you think???
ted cruisin in my '67 K-20 '67 Custom Sport Truck '55 Chevrolet 3100 w/ 235 il6(Powermaster) '63 Chevrolet 1/2 ton 250 il6 '65 Chevrolet 1/2 ton 283 V8 |
04-22-2011, 11:19 AM | #379 | |
It should fit your truck with the lift you have. It will be just under 32" tall. The tires on my 67 in the above pic are 32x11.50-15's for reference.
04-22-2011, 06:19 PM | #380 |
thats the same tread I was talking about...and the price is good too!
thanks for the reply...
04-22-2011, 09:52 PM | #381 |
285's might work.... they are like a 33
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
04-22-2011, 10:54 PM | #382 |
I run a 255x85x16 on my dually it is a narrow 33 would look really good on a stock type wheel.
04-23-2011, 10:05 PM | #383 |
Here's mine.
04-23-2011, 11:09 PM | #384 |
like that elk proof bumper!
04-25-2011, 03:36 PM | #386 |
sorry. Double Post
build Threads: Nasty 68 C10. My lil hotrod Leftovers 68 C20 D-Ranged Ford Ranger on steroids Semper Fi Last edited by RatRod68; 04-25-2011 at 03:36 PM. |
04-25-2011, 03:54 PM | #387 |
nice truck...my wife wants me to get a pair of those stirrups so she can get in easier...what kind of shock is that going across the front end??
04-25-2011, 04:02 PM | #388 |
no clue. i bought it pretty much like this. i just added the grille and lights
04-27-2011, 12:13 PM | #389 |
fixing rear cab mounts
I have two rubber mounts that are shot( the rear ones under the seat) I made up some solid rubber "hockey pucks" to put in the place of the sag...and ideas out there on removing the nut/bolt that holds them in place...
have dosed the spots up good w/ liquid wrench...anyone out there fixed this before...any have a heads up on any possible problems...thanks...t ones side droops about 1 " the other maybe 3/4"...probably not a big deal...but it does drive me crazy...
04-27-2011, 11:04 PM | #390 |
Yaeh back when I was in college (ie broke) I made some by cutiing up litttle squares out of an old tire and they worked good to level everything backout. I am from texas so I have never touched a Hockey puck but it sounds like a goood fix as long as its not to hard (stiff). As far as the botls you will have to have a back up inside the cab and you may have to remove your seat. May try an impact wrench 1st just to see if it would bust then off before taking you seat out but I doubt it will. Probably a good time to go ahead and replace the bolts and nuts as well. I always use grade 8 bolts for this.
Preserving American History one truck at a time. |
04-28-2011, 08:32 AM | #391 |
thanks for the info...I was trying to avoid taking out the seat...will do as you suggested...am I to understand that the threads are not a stud? but goes through the lower cab? w/ a nut underneath...so a box wrench or similar has to be attached under the seat ( to hold bolt)to get it loose if an impact alone does not work on the lower nut?
I have looked at drawings in the LMC catalog and its not that clear how it is attached... thanks again...t
ted cruisin in my '67 K-20 '67 Custom Sport Truck '55 Chevrolet 3100 w/ 235 il6(Powermaster) '63 Chevrolet 1/2 ton 250 il6 '65 Chevrolet 1/2 ton 283 V8 Last edited by silvertip67; 04-28-2011 at 09:10 PM. |
05-20-2011, 12:06 PM | #392 |
07-25-2011, 08:36 PM | #394 |
07-26-2011, 11:52 PM | #395 | |
07-27-2011, 02:37 PM | #396 | |
6>8 Plugless........
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-27-2011, 04:59 PM | #397 |
Chevy Enthusiast
Even on my gmc (central texas truck) the bolt was froze in the nut witch spun around in the retainer. It was just a bad design.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
07-27-2011, 06:45 PM | #398 | |
It is definitely a poor design. I guess you could convert it to a thru bolt design like the front cab mount if it twists in place or breaks off.
07-27-2011, 07:45 PM | #399 |
Well at least they aren't like the 73-87's. You have to cut the floor of the cab to access the nut whet it spins in the retainer.
07-27-2011, 08:11 PM | #400 |
Chevy Enthusiast
I just cut a little hole in the rear cab support right behind the nut with a cutoff tool then welded it solid.
