02-16-2012, 10:24 AM | #376 |
I'm just glad to be here!
Re: No Limit's "K-10"
Rob, That's looking real good. I dig the little extra you had the water jet do on your rack mount. The No Limit name right there in FRONT.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-16-2012, 01:17 PM | #377 |
nice. great progress.
Doug Looking for a 67-72 short bed driver..... |
02-17-2012, 08:36 PM | #378 |
Yep, have to raise the rear openings too. I need to be able to pull a tire without to much work. I make the wheel opening lips in three pieces, well actually seven, but in three layers. The flat lip, and two for the radius edges.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-17-2012 at 11:14 PM. |
02-17-2012, 08:39 PM | #379 |
PROJECT 7DEUCE
More updates **** I got to go get a beer...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-17-2012, 08:47 PM | #380 |
here it is with the OE openings cut out, and the new shape in place.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-17-2012 at 11:16 PM. |
02-17-2012, 08:49 PM | #381 |
this is the hard part to fit. I made a tape template first to get the shape, the trimmed the metal to fit.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-17-2012 at 11:18 PM. |
02-17-2012, 08:54 PM | #382 |
I'm not even done working and I just had a beer.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-17-2012, 08:58 PM | #383 |
Sounds good I think I'll grab me a beer.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-17-2012, 10:18 PM | #384 |
67cheby
Wow looking cool
Posted via Mobile Device |
02-17-2012, 11:11 PM | #385 |
Cool....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-17-2012, 11:44 PM | #386 |
Still plays with trucks
Very nice. I like how you make the flares blend into the stock body lines. It really helps the flares not look tacked on like many do. Great work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-18-2012, 06:21 PM | #387 |
Newbee
It just keeps getting better!
Hurry up, Goodguys Scottsdale is Mar 9! The schedule says autocross. |
02-20-2012, 08:38 PM | #388 |
this is the finished pass side, only one left to do. The drivers side uncut. Drivers side opening with the lip on it.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-20-2012 at 09:08 PM. |
02-20-2012, 08:40 PM | #389 |
Oops, another shot of the pass side rear. And with the tire in it at ride height. here is a shot of the goofy panhard rod set up, passing through the torque arm.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-20-2012 at 09:10 PM. |
02-20-2012, 08:41 PM | #390 |
The axle mount for the panhard rod, this is my first real quichchange build, and it does add to the difficulty. The front mount of the torque arm has five positions to mount the link. When I assemble it for real, I'll put all the bearings and bushings in place, so that tuning will be easier.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-20-2012 at 09:13 PM. |
02-20-2012, 08:43 PM | #391 |
This is the beggining of the fuel tank. Lots of baffles and traps. This is one of those parts that has to do many things. As well as the fuel tank, this has to act as an air deflector for the radiator, and allow access for the rear quickchange cover to swap gears.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-20-2012 at 09:19 PM. |
02-20-2012, 08:52 PM | #392 |
67cheby
This thing is crazy cool
02-20-2012, 09:28 PM | #393 |
very cool!
02-21-2012, 12:03 PM | #394 |
I can not wait to see this truck on the track!
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
02-23-2012, 12:22 AM | #395 |
Any updates on the hood?
02-23-2012, 01:23 AM | #396 |
Still Learning
Crazy metal fab skills! I'm loving all the cool designs. It would be cool to see what equipment you use to form and shape your metal. Tools I obviously don't have....
02-23-2012, 03:47 AM | #397 |
Did you switch to Winters hubs?
02-23-2012, 11:17 AM | #398 |
the front hubs are Wilwood, the rears are Speedway Eng.
02-26-2012, 07:21 PM | #399 |
Hang on to your hats, new picts coming. Saturday we re-assembleb most of the big parts. This was the last fit up. With everything together it was time to start the finish work. Tabs for everything, holes for everthing, mounting spots for everything....... this stuff moves pretty quick, but after a few full days of it, it still looks the same. Finally, we pulled it off of the build rack and set it on the ground. All I can say is, WOW!!!!
02-26-2012, 07:24 PM | #400 |
can't wait....make it soon...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
