Old 08-18-2012, 11:06 AM   #376
made2drag
made2drag's Avatar
Re: 86 squarebody made2drag
i will continue working on it in the fall....i am working a little here and there on the 78 blazer right now
made2drag is offline   Reply With Quote
Old 12-03-2012, 10:33 PM   #377
made2drag
made2drag's Avatar
Old 12-03-2012, 10:39 PM   #378
91Subbed
Looking good! Good job man!
91Subbed is offline   Reply With Quote
Old 12-04-2012, 12:18 AM   #379
3r!c84
Badass
3r!c84's Avatar
plan on keeping it aol ?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-04-2012, 10:04 AM   #380
made2drag
made2drag's Avatar
thanks
Old 12-04-2012, 10:14 AM   #381
made2drag
made2drag's Avatar
yup. i havent driven it yet, but i wanted the rear to carry the load between the axle and frame instead of front of the leafsprings. i know i'll lose alittle ride but for peace of mind that i can carry anything and also be able to change or work on my rear bags anytime will be worth it. i may be moving the air tank to the bed and maybe the rear valves behind the seat. i am working towards never having to take the bed off again. it will be easier to drain the tank when its in the bed and i plan on adding another compressor or 2. i also want to finally add shocks which was another reason i built the bag brackets and relocated them up high so i can weld some tabs and mount the shocks. i did keep the area between the notches empty, so i can air up and as long as my pumpkin is lower than the bed floor....i can still lay stuff flat like a filing cabinet or furniture......in fact, ive got stuff to move right now and im trying to get my bed back on soon, so i can move it
Old 12-04-2012, 12:26 PM   #382
3r!c84
Badass
3r!c84's Avatar
How is it as far as wheel hop and the axle wanting to twist? Could you put like.caltac's with that set up maybe? I want to go bags now but don't have a welder nor do I know how too..
-00 Saturn 5spd
1/4:13:90
Old 12-04-2012, 12:39 PM   #383
watahyahknow
watahyahknow's Avatar
there 2 3 4 link kits available that are bolt on and work with bags , they solve all those issues
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 12-04-2012, 01:30 PM   #384
truckzilla
truckzilla's Avatar
Thumbs up Re: 86 squarebody made2drag
Originally Posted by 91subbed View Post
looking good! Good job man!
posted via mobile device
x2!
truckzilla is offline   Reply With Quote
Old 12-04-2012, 05:10 PM   #385
made2drag
made2drag's Avatar
before with no bags and no shocks and no add-on leafs and with the bed off...if i floored my 4.3 it would wheel hop bad, if i drove it normal...no problems. i havent driven it in the current set up yet but im thinking with my shocks im going to do soon and the bags aired a little and keeping the add-on leafs...i shouldnt have any wheel hop. my add-on leafs are from autozone. not sure how caltac's would be.
get a bolt on 2 link from ekstensive for a couple hundred bucks and you'll be done in the rear...bolt a c-notch in then get a welder at a muffler shop to weld it...then for the front, buy the bolt in brackets for the front bags
Old 12-04-2012, 05:11 PM   #386
made2drag
made2drag's Avatar
Originally Posted by truckzilla View Post
x2!
thanks!
Old 12-05-2012, 10:24 AM   #387
luifer76
luifer76's Avatar
looking good bro.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 12-05-2012, 10:31 AM   #388
aggie91
I'm just glad to be here!
aggie91's Avatar
Bag mount look good.
Do you have a build thread on the Blazer?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-05-2012, 10:44 AM   #389
luifer76
luifer76's Avatar
when you gonna Z this thing?
Old 12-05-2012, 01:12 PM   #390
made2drag
made2drag's Avatar
thanks....
yes, there is a link in my "signature".
Old 12-05-2012, 01:17 PM   #391
made2drag
made2drag's Avatar
probably wont. i do have an extra 73-87 crossmember and control arms and disc's that i might put on my 56. if i do, i'll have to narrow the crossmember and section it, then z the front near the firewall because i wouldnt have any clearance at all if i didnt. the 73-87 is supposed to almost bolt up but the width it puts the wheels is too wide and it also hangs too low if you leave it stock. all this if i cant find a 78-79 subframe to weld to the 56's frame.
Old 12-05-2012, 01:21 PM   #392
made2drag
made2drag's Avatar
i also have an extra (2ND) set of lca's. i want to do the "Luifer76 lca mod" to those for the 86 so i can run my Dominator 2600's up front
Old 12-05-2012, 01:42 PM   #393
luifer76
luifer76's Avatar
cool post some pics when you do....
Old 12-05-2012, 01:44 PM   #394
luifer76
luifer76's Avatar
im gonna be cupping the ones on my 73 here shortly once i start the bodydrop.
Old 12-05-2012, 03:53 PM   #395
made2drag
made2drag's Avatar
Old 12-06-2012, 10:32 AM   #396
made2drag
made2drag's Avatar
i started on my shock mounts....ran out of welding wire right after i tacked one of the top mounts on the driver side...just my luck...
Old 12-06-2012, 10:44 AM   #397
truckzilla
truckzilla's Avatar
You couldn't just run down to your local 24 welding supply house?
Old 12-06-2012, 03:24 PM   #398
made2drag
made2drag's Avatar
lol.
Old 12-19-2012, 09:44 PM   #399
made2drag
made2drag's Avatar
ok, so 15 bucks worth of wood and 2 bucks worth of bolts, washers and nuts...i built this tonight and still have to do some diagonal bracing from 4x4's to 2x10's and diagonals from 2x8 to 4x4's. my plan is to lift the bed so that the lowest part of my bed is 30 inches...then drive under and lower it into position by myself
Old 12-19-2012, 10:19 PM   #400
3r!c84
Badass
3r!c84's Avatar
a case of beer and some buddys would be cheaper and faster... haha
-00 Saturn 5spd
1/4:13:90
