Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-13-2015, 11:13 AM   #376
7dee2
7dee2's Avatar
Re: 71 4X4 Frame off Restoration
Really great work I agree on the details so cool!
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-13-2015, 06:04 PM   #377
DWilbur
I got some work done over the week end I finish up the D60 and installed it under the frame. I started to prep the engine to install it Sunday but I was missing 3 bolts 1 for the flywheel and 2 for the pressure plate. I found the blot for the flywheel after cleaning up my work bench but I had to buy 2 bolts of the pressure plate from Chevy this morning. so next week end I can install some wheel the motor, tranny and T-case. I would post picture but they are still working on my house repairing the water damage. so I could not get to my computer all week end.
DWilbur is offline   Reply With Quote
Old 04-14-2015, 01:18 AM   #378
swamp rat
swamp rat's Avatar
Well, we'll forgive you for not posting a pic.... this time...
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-14-2015, 02:58 PM   #379
DWilbur
I was able to get to my computer to post pictures of installing my D60, I media blasted my valve cover and clear coated them. the issues with installing the steering brace from ORD I have the frame that it does not fit at all. I will cut it up and make it fit.
Old 04-14-2015, 03:20 PM   #380
First c10
First c10's Avatar
So your ord steering mount fits the crossmember just not the steering box mount area? That is opposite from mine. All the faith you will get it. It's looking good!!!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-14-2015, 06:23 PM   #381
DWilbur
It don't fit the cross member either I just lined it up that way. the holes don't line up either top or bottom side to side. I will cut the bracket up and make it fit. A good cut off wheel and mig welder will do the trick.
Old 04-16-2015, 03:21 PM   #382
DWilbur
Pictures of the steering gear brace after I cut it apart to fit my frame. I'm going to wait until I install the engine so I can check clearance for the fan and shroud.
Old 04-17-2015, 02:31 PM   #383
First c10
First c10's Avatar
You are right, mine did fit better. Do you think you will have a problem with clearance with the motor? Now I am a little worried.
GO GO!!!
Old 04-17-2015, 03:36 PM   #384
DWilbur
I should know after this week end. I'm installing the engine, trans and T-case. then install the core support, radiator and shroud to see how things fit.
Old 04-19-2015, 06:52 PM   #385
DWilbur
Had a good week end got some work done installed the wheels and tires so I can roll it in and out of the garage. Installed the engine, transmission and T-case Saturday with some help from my nephew. Then we went to his shop and got my 1973 Plymouth Satellite running after 3 week not having spark we finally got spark. The engine still would not start. It ended up being I installed the spark plug wires on the distributor the wrong direction. fixed the wires and it fired up. Then after 2 minutes and 34 second of run time the transmission was puking oil we shut it down went and had some dinner came back a pulled the trans and it was the torque converter shaft was trashed where the oil seal rides. so I will call TCI Monday to see what can be done. Sunday I worked on the truck and installed the intake manifold, some brackets, headers and crossover steering link. I had to cut the front tube on both side of the headers so I can bolt them up and plan how to fix the front tubes. I was not able to find the body mounts in the attic so I was not able to work on the steering brace much.
Old 04-20-2015, 12:47 AM   #386
First c10
First c10's Avatar
Looking good. Too bad you had to cut the headers!!! Ouch I don't like to cut on expensive parts. Will the cab clear the engine and exaust where you have it?
I was wondering if you could measure from the front of the frame somewhere to the engine block? I want to get my crossmember installed but not sure of the exact measurement front to back.
GO GO!!!
Old 04-20-2015, 01:47 PM   #387
DWilbur
From the right cylinder head to the front edge of the frame is 29-1/4". I did install my engine with the cab in place.
Old 04-20-2015, 01:55 PM   #388
First c10
First c10's Avatar
Sorry to ask but do you have from the engine mount on the frame to the front core support hole?
Old 04-20-2015, 02:25 PM   #389
DWilbur
Center of core support mounting hole on frame to front of Dirty Dingo mount is 21-5/8". from the engine block under the water pump is 18-1/8". from center of hole to first bolt on engine motor mount is 24".
Old 04-20-2015, 02:38 PM   #390
First c10
First c10's Avatar
That's awesome thank you. You have any pictures of the cab and motor installed???!
Old 04-20-2015, 04:22 PM   #391
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That stinks to hear about your trans seal issue in the Satellite. Hopefully they send you a new seal and there isn't an issue in the TC. Keep at it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-20-2015, 04:36 PM   #392
DWilbur
See post 162 with the cab and engine.
Old 04-20-2015, 04:41 PM   #393
DWilbur
I have been sending TCI info this morning several time as the ask question. the front of the trans has 2 splines one larger and the smaller one at the front of the main shave. the TC only has the smaller spline. the back of the TC shows metal grinding inside and the larger spline on the main shaft shows grinding on the splines. it looks like they sent me the wrong TC. I bought it as a package deal even came with oil cooler and 3 gallons of oil.
Old 04-20-2015, 04:49 PM   #394
Dieselwrencher
Yeah, that definitely sounds like not a good deal. Hopefully they get you fixed up in short order.
Ryan
Old 04-25-2015, 05:41 PM   #395
First c10
First c10's Avatar
Hey David
Was wondering what rear shocks you have? I have tough countries and they look long. Not to much travel installed. I have TC 61301.
GO GO!!!
Old 04-25-2015, 08:11 PM   #396
DWilbur
They are sending me a new TC and front seal. should have it next week.
Old 04-25-2015, 08:13 PM   #397
DWilbur
Hey David
I have Sky Jacker shocks and I don't like them. I'm going to order some bilstein shocks like I have no my 98 Dodge they are way better.
Old 04-25-2015, 08:17 PM   #398
DWilbur
Finally got the steering brace in order welded up painted and installed. The stock fan does not fit it clears the brace by 1/8". I will be going with electric fan set up now. I started on the headers this afternoon.
Old 04-25-2015, 11:49 PM   #399
Dieselwrencher
That stinks about the fan clearance, but oh well. It should be fine with an electric fan.
Ryan
Old 04-26-2015, 02:05 AM   #400
First c10
First c10's Avatar
My shocks look good but I think they are way too long.
I probably should have ordered bilsteins also I have them in my 2008gmc 1 ton crew cab and love them.
The brace looks good. I am going to put electric fans also. My swap motor had electric fans from the factory.
GO GO!!!
