Old 11-06-2016, 09:00 AM   #376
Lieferson
Lieferson's Avatar
Re: Installed FiTech EFI and Fuel Command Center
Originally Posted by Mick54615 View Post
Installed EFI on my 1970 K5 with 396.
OOOHHHH let us know how you like it! I love the idea of modern fuel injection but maintaining that classic carburetor look
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 11-07-2016, 10:46 PM   #377
Mick54615
Re: What did you do to your Blazer/Jimmy today?
Well, everything went well with a couple short test drives yesterday. Took it to work today and got stranded twice on the way home. They have not corrected their issue with the fuel command center overheating and boiling the fuel.I mounted it where the heater and fan motor used to be, which I feel should be far enough away from heat sources as you can get in the engine compartment. Called Fitech and talked to Bryce since I had time to kill on the side of the road. He said that location isn't good even though the literature that comes with it suggests this location. Just keep kickin' the can....
Mick54615 is offline   Reply With Quote
Old 11-08-2016, 07:51 PM   #378
1972 Jimmy
1972 Jimmy's Avatar
Got some parts back from getting zinc coated. They turned out great! Thanks DeadheadNM for the lead. Had some extra parts plated as well. Will be posting some for sale soon: )
1972 Jimmy is offline   Reply With Quote
Old 11-15-2016, 06:31 PM   #379
mister.freeze
mister.freeze's Avatar
New steps!
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 11-15-2016, 11:50 PM   #380
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice!! So worth it.
Old 11-19-2016, 12:12 AM   #381
SoCoC10
SoCoC10's Avatar
Took some stuff to my media blaster so I had him sand blast a set of Rallys for my CST. Matched the two like new Wild Country All Terrains. Two new tires, four Rally wheels and a coat of paint. Not bad for $300.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 11-19-2016, 06:16 AM   #382
Chulisohombre
Chulisohombre's Avatar
Those should look real Nice with some new trim rings and center caps.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 11-19-2016, 08:12 AM   #383
Guana
Guana's Avatar
Drove it around town running errands and taking my wife out to lunch....
Guana is offline   Reply With Quote
Old 11-20-2016, 08:53 PM   #384
solo72
solo72's Avatar
Picked up a roll bar for the Jimmy!
solo72 is offline   Reply With Quote
Old 11-20-2016, 09:15 PM   #385
SoCoC10
SoCoC10's Avatar
Bought a set of four brand new center caps for the rims from a member. Two open and two closed with the "4X4" stickers. Unfortunately, the caps are plastic so I'll just use the rears and keep my metal ones on the front.
I don't like running trim rings for a couple reasons. They scratch up my freshly painted rims; they seem to fall off from time to time and I think the rim looks larger without the trim rings so don't run them.
Old 11-20-2016, 09:37 PM   #386
LuckyScott
LuckyScott's Avatar
Mounted the rear seat.
Finished the wiring for my twin fans on the radiator.
LuckyScott is offline   Reply With Quote
Old 11-21-2016, 10:04 AM   #387
dirish
dirish's Avatar
Added a new transfer case shifter ring. Biller aluminum, made by fellow member Mcbassin.
Not the best picture, and not cleaned up, but a very nice product! Thanks Mike
dirish is offline   Reply With Quote
Old 11-22-2016, 02:16 AM   #388
Slick67
Sofa King Crazy!!
Slick67's Avatar
I finished making my faux boxed frame panels. They are to hide all the wires and lines. Did the whole frame, bead-rolled and dimple-die as well. Name:  20161119_160822.jpg
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 11-22-2016, 10:41 AM   #389
colgad
colgad's Avatar
Originally Posted by Slick67 View Post
I finished making my faux boxed frame panels. They are to hide all the wires and lines. Did the whole frame, bead-rolled and dimple-die as well. Attachment 1592440
Wow that took more than a minute! How are you attaching them?
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 11-22-2016, 09:11 PM   #390
LuckyScott
LuckyScott's Avatar
Yesterday I installed a seat belt on the drivers side. Then I bolted down the center console.
Today, I installed a new set of hood hinge springs. My Blazer had hinges but no springs. For twenty bucks and a half hour of work my hood opens and closes easily now. Plus, I learned a new trick on installing the springs that made the job really easy.
Old 11-22-2016, 09:49 PM   #391
SoCoC10
SoCoC10's Avatar
Got an update from my metal guy on my CST. Front cab support, inner rocker and floor repairs are done on the passenger side. "A" and "B" pillars are almost done and a final figment of the outer rocker is going on now.
Old 11-24-2016, 02:57 AM   #392
Beau2a
Beau2a's Avatar
New Coys today. Still waiting on the rears to ship.
Beau2a is offline   Reply With Quote
Old 11-24-2016, 09:13 AM   #393
dirish
dirish's Avatar
Very nice! Great looking Blazer!
Old 11-25-2016, 02:57 AM   #394
Beau2a
Beau2a's Avatar
Thanks dirish
Old 11-25-2016, 09:39 PM   #395
truckster
truckster's Avatar
I put it on vehicle dollies so I can move it around until it can move itself around.
truckster is offline   Reply With Quote
Old 11-25-2016, 10:46 PM   #396
TonyJohnson
TonyJohnson's Avatar
Those wheels look great. Really nice Blazer. Love the 67/68 front clip. That's what I want eventually. Wish at least one year of Blazers had been delivered with that look. I love them all, but that's the best look. IMO...
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 11-26-2016, 08:53 AM   #397
Big Block
Big Block
Big Block's Avatar
Put new gas tank on my 71 2 wheel drive Jimmy.. Aftermarket tank with short filler neck. That was a real treat. 5 hours later and a lot of cursing it's on and the gas gage works but bounces around while driving it. Why didn't they just use a stock filler neck? I know it can be used for other applications but it would be a lot easier to cut it to fit rather than being short and ending up hitting the top edge of the frame rail. What a pain. Finally got the frame rail modified enough to clear the neck.
Big Block is offline   Reply With Quote
Old 11-26-2016, 08:57 PM   #398
LuckyScott
LuckyScott's Avatar
They had a sale at the local Truck shop in Orange. Wife and I blew our monthly budget today, LOL.
New front grill kit includes inner and outer grill and headlight trim.
Rear bumper kit includes new rear bumper, and all the hardware, license plate mount and brackets. A bunch of new emblems for the fenders and glovebox and dash. Wife really wanted to fix up the center console I mounted recently so we got all new trim parts. Picked up a new set of front seat belts.
Our '72 4x4 will be looking sharp soon.
Old 12-03-2016, 04:57 PM   #399
LuckyScott
LuckyScott's Avatar
Had a great day working on the Blazer. Installed the new rear bumper, lic plate and plate holder and plate light. I got lucky and the wire I hooked the lite up to was the right one and worked like a champ.
Then I installed new arm rests, and some trim parts around the center console.
I also bought a bracket from one of the guys here in New York. It is the part that the front folding forward bucket locks into. Got it, painted it up and installed it and now the seat is nice and secure. It was nice of him to include the factory bolts too.
The seat had no seat belts so I installed a set of lap belts too.
Old 12-05-2016, 02:09 PM   #400
OldBalls
OldBalls's Avatar
Small stuff....Painted the grill black (ordered new emblem), replaced blinker lenses and side markers. Then added tailgate band.
OldBalls is offline   Reply With Quote
