Old 05-18-2017, 05:02 PM   #376
tinydb84
tinydb84's Avatar
Re: Used Parts Build
Also... Ordered these!
They should fit really well. I made my notch too high initially and want to bring it down. Got them from Applied Racing Technologies. They are 2x3x.120 and a bit lighter duty than I want but I will tie them to my four link cross member with some 1.5x.120 tube. The rear of the frame only supports half the bed and the fuel tank. I think it will be fine. Plus each rail weighs significantly less than each of my damn over built notches.
David
Instagram: myfabguy
Old 06-19-2017, 07:08 PM   #377
tinydb84
tinydb84's Avatar
I took a day off and worked through the weekend to try to get some work done to it. Ended up being really hot so I didn't get as much done as I wanted. Here are the pics:
Pushed my brother's Nova out, cleaned the garage, and pushed mine it. The differential is all jacked up and it took 4 people to push it up the driveway...
Old backhalf
Cutting the old backhalf off and found a wasp nest. Holy **** there were tons!
David
Instagram: myfabguy
Old 06-19-2017, 07:09 PM   #378
tinydb84
tinydb84's Avatar
Laying out the new rails
David
Instagram: myfabguy
Old 06-19-2017, 07:09 PM   #379
tinydb84
tinydb84's Avatar
Had to trim them down a bit to fit
Mock up
David
Instagram: myfabguy
Old 06-19-2017, 07:10 PM   #380
tinydb84
tinydb84's Avatar
Capped the ends
Removed everything to make it easer to weld in
Lovely temp to work in...
David
Instagram: myfabguy
Old 06-19-2017, 07:11 PM   #381
tinydb84
tinydb84's Avatar
Weldable primer for all the parts that will be sandwiched together.
Started tacking
I feel like I forget to mig weld since I have been tigging everything lately
Laid out!
David
Instagram: myfabguy
Old 06-19-2017, 07:12 PM   #382
tinydb84
tinydb84's Avatar
A pic with my gf for height reference.
Did it all in 3 days. Need to do all the tube work now. The front has 3 2x4's under the cross member because I need to swap out the oil pan still.
David
Instagram: myfabguy
Old 06-19-2017, 08:30 PM   #383
rip2174
Love the fab work. Wish I could weld like that!
rip2174 is offline   Reply With Quote
Old 06-19-2017, 10:59 PM   #384
daddyjeep
daddyjeep's Avatar
The new rails look great. Glad to see you are back at it.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 06-26-2017, 01:44 PM   #385
tinydb84
tinydb84's Avatar
Thanks guys. You know that stuff life stuff always gets in the way...
David
Instagram: myfabguy
Old 06-26-2017, 01:45 PM   #386
tinydb84
tinydb84's Avatar
Still trying to figure out the tube work in the back. I don't have the funds to buy a tube bender at the moment so I am stuck with either the 90 degree bends I have or straight tube. Any input? I'd like to tie the bag mounts to each other across the center.
Burned in the back cross member:
Its just a bit too tight to fit the blazer tank (thing is huge). I can raise it up thought and likely fit it under the bed floor still.
David
Instagram: myfabguy
Old 07-17-2017, 04:35 PM   #387
tinydb84
tinydb84's Avatar
Screw photobucket.
Took another Chop/Metal Shaping class.
Still working on my backhalf. Got it all tied in.
Base for the gas tank in. Need to figure out my shocks and how to mount the gas tank next.
Watts link in
[url=https://flic.kr/p/WLzYEC]
David
Instagram: myfabguy
Old 07-17-2017, 07:23 PM   #388
Joe Pass
Joe Pass's Avatar
Some nice work....very cool
Joe Pass is offline   Reply With Quote
Old 07-19-2017, 08:23 PM   #389
rusty76
rusty76's Avatar
Cool looking fab work. Was the class at Skoty Chops? I need to do a class like that.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-24-2017, 07:32 PM   #390
tinydb84
tinydb84's Avatar
Thank you Joe
Thank you. Yeah it was at Skoty's place. Jesse Miller has some travelling classes he does and did this one there. Its a great class. You would benefit more from knowing basics but its a ton of info either way.
And since every post should have a picture...here is a stainless steel exhaust I did for my buddy's race car on Saturday. You can see the original muffler next to it.
David
Instagram: myfabguy
Old 07-25-2017, 06:02 PM   #391
rusty76
rusty76's Avatar
Cool
My build thread
Crossmembers CC
Old 07-31-2017, 12:50 PM   #392
tinydb84
tinydb84's Avatar
Got the bed assembled and squared on the frame. Going to build the rear mounts next. Aired it out for some quick pictures. Need to pull the engine and change the oil pan to get it all the way down.
[url=https://flic.kr/p/X39EAw]
David
Instagram: myfabguy
Old 07-31-2017, 04:02 PM   #393
rip2174
Nice!!
Old 08-07-2017, 01:27 PM   #394
tinydb84
tinydb84's Avatar
Nice!!
Thank you sir.
Remade my rear bed mounts:
Bed is on. Need to do one more set of mounts mid bed. Then doing some frame tubing and figure out the shock mounting.
David
Instagram: myfabguy
Old 08-07-2017, 06:47 PM   #395
Joe Pass
Joe Pass's Avatar
Sweet......
Old 08-14-2017, 04:06 PM   #396
tinydb84
tinydb84's Avatar
Finished all the bed mounts.
Started playing with the hotside for my turbo set up. Getting tired of working on the frame and suspension at the moment. Luckily I have a ton of work to do...
David
Instagram: myfabguy
Old 08-21-2017, 03:16 PM   #397
tinydb84
tinydb84's Avatar
Got some parts and started working on the merge.
I don't have enough hands to hold it in place for the picture but it lines up. Need to tack it together and grind the bottom flush. Then I'll port the flange a bit and weld it all up. I bought a second tank of argon and flow meter because it was cheaper than buying a dual flow meter.
David
Instagram: myfabguy
Old 08-25-2017, 03:49 PM   #398
tinydb84
tinydb84's Avatar
Got some more of my hotside done
David
Instagram: myfabguy
Old 08-29-2017, 07:03 PM   #399
tinydb84
tinydb84's Avatar
Welded the cast iron to the stainless. Thought it came out good. There is tiny crack in along the edge of part of the weld. Going to grind it out and do it again.
Used the other half to keep it hot in between welding
David
Instagram: myfabguy
Old 08-31-2017, 05:12 PM   #400
tinydb84
tinydb84's Avatar
Got both sides welded up. Ground out the area that looked liked it cracked on the first manifold. Not sure it was actually cracked once I ground it all back. Used the oven this time and preheated the manifolds to 450. Welded it up, then put it right back in the oven. Slowly lowered the heat over the next few hours. I used my infrared thermometer to make sure each side (cast vs stainless) was at the same temp before lowing the oven by 75 degrees each time. I looked them over this morning before work and didn't see any cracking.
Ordered a VS Racing 44mm wastegate, bellow, and a schedule 10 2'' to 1.5'' reducer to mount it with.
David
Instagram: myfabguy
