08-09-2015, 09:08 AM | #376 |
Re: Meet Homer (the motor home)
Thanks Mike. I appreciate that.
"Life is too short to drive a boring vehicle". Later, Wayne |
08-10-2015, 04:36 PM | #377 |
No pics yet, but this past weekend I re-wired the underhood portion of Homer. No more long length wiring with power going into the cab thru a switch back out to the end user. Soo much more efficient with direct wired power source thru a relay with the switch only being used to activate the relay. Very cool. Course it took me wayyyyyyyyyyyyyyy longer than it should have, but it's in and done now. Time to drop the distributor, plugs, plug wires, rad and make smoke pretty soon. Will post some pics when I get the time.
08-10-2015, 05:42 PM | #378 |
Great news ,cant wait for more updates .
08-10-2015, 07:21 PM | #379 |
Wow just wow,this truck is obviously in good hands. Can't wait to see it come together
08-11-2015, 01:24 PM | #380 |
I will keep you all posted. Got the distributor, plugs, and plug wires in last night after work.
Thanks for the encouragement. I too can't wait to see this dude back together. Hoping to be there by the end of September.
08-11-2015, 01:28 PM | #381 |
The 60-66 GMC/Pontiac guy....
Nice job Wayne.. :-) I'll try to get time to get by there.. I'd really like to see your progress
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
08-11-2015, 01:31 PM | #382 |
Thanks Chris. Might be running by Friday evening. Stop by when you get a chance.
08-11-2015, 09:07 PM | #383 |
Your truck is really starting to come together, nice work.
Scott |
08-11-2015, 11:55 PM | #384 |
I have found... the quickest way to dis assemble a motor home....and dispose of the waste by products, is to simply park it in tornado ally during the season and comback a few hours later.
08-12-2015, 10:08 AM | #385 | |
"WORKS-DO NOT REMOVE". He swore it worked like a charm. He would show up the next day and it would be gone like the wind. If he put a sign on it that said "Free" they would think it was a P.O.S. and leave it alone.
"Life is too short to drive a boring vehicle". Later, Wayne Last edited by cooperhw; 08-12-2015 at 03:53 PM. Reason: addition |
08-15-2015, 09:26 AM | #386 |
Nothing much to take pictures of, but yesterday I got the radiator in, the power steering lines hooked up, changed oil and filter, & the transmission cooler lines. (doesn't sound like much but took all day). Poured gas in the carb and she fired right up. Had the dizzy out to install the motor. Still gotta lot to do, but was pleased the timing was close.
I will take some pics later today, but until I start adding more parts or wheels, not too much to look at. It hit a high of 117* yesterday and I have an outdoors shop set up. Low this morning is over 90*. Trying to get motivated to get out there is tough. Progress is progress though, so I'll take it when I can get it.
"Life is too short to drive a boring vehicle". Later, Wayne Last edited by cooperhw; 08-15-2015 at 09:27 AM. Reason: error |
08-15-2015, 09:31 AM | #387 |
Wow, bet that was an exhausting day in 117 heat. Good progress under tough conditions!
08-15-2015, 09:35 AM | #388 |
It was definitely warm yesterday Wayne.
Got a new job bud.. this one is a perm. position.. Less time to work on my own stuff.. but now money to spend on parts.. :-)
08-16-2015, 10:25 AM | #389 | |
Good news on the new job Chris. Hopefully you can now spend time on your projects other than customer stuff.
08-16-2015, 10:50 AM | #390 |
Woo! Hoo! Us arthritics love this weather..
I feel 40 again... Bwaahahaha
08-16-2015, 03:29 PM | #391 |
Wee once again no pics. Not hardly worth the effort. I did get the radiator & power steering all filled up. Got the timing close. Hit the key & he fires right up. Uncapped headers sounds good.
Posted via Mobile Device |
08-20-2015, 11:52 AM | #392 |
Well, wish me luck boys. I have got old Homer where he will start up so this coming weekend my goals are to bleed/hookup/configure all brake lines to it will be able to stop. Next I want to install some shocks which will include installing/fabricating shock towers. Then I need to install the door seals and latch mechanizims do the doors will stay shut. Then, hopefully, I will be able to put Homer in gear and actually have him move on his own power. I started this project last December and to date he's never moved on his own yet. Hopefully (should) this weekend he goes into the truck category and out of the project category. My thought is that it's got to be able to start, drive to the corner, turn around and drive back on it's own to make the switch.
Should not be a problem to make it, but it's never as easy as it sounds.
08-20-2015, 11:54 AM | #393 |
Thanks Mike. I just saw your post. I appreciate the compliment. I think old Homer is "gonna clean up just fine".
08-20-2015, 12:01 PM | #394 |
Good luck!cant wait to see the bed on.
08-20-2015, 12:04 PM | #395 |
Good work Wayne. Working on mine today in the heat.
I really like the colors you chose.. I'm almost ready to build my fab rack for the extended/crew cab. You blew me out of the water on getting yours done. .
08-20-2015, 12:04 PM | #396 |
Yeah, you and me both Pat. Only thing holding me back now is the brake line and shock mounts. So much easier to get to.
Heck, might even be able to start assembling the bed too. Ha. I always want to get 10 things done, and only get 4 but you gotta keep moving forward.
08-20-2015, 12:14 PM | #397 | |
I might stop by this weekend if I go out for parts over your way. Good excuse to cool off in the trucks AC. Like to check out your project anyway.
08-20-2015, 12:26 PM | #398 | |
08-20-2015, 12:50 PM | #399 |
08-20-2015, 07:37 PM | #400 |
This is my favorite dually thread ,keep it coming .
