03-24-2015, 11:26 AM | #376 |
Re: Cheap trick patina 70
Thank you working to get her done. I ran into a road block last night. I figured I would have to have the rear end narrowed and I do so I will be taking it out and cutting it down. Sucks to be me lol. But other then that it's goig smooth. Motor and trans are in. Going to put air ride tanks and compressors on tonight.
03-24-2015, 12:02 PM | #377 |
How much do you have to narrow the rear end?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
03-24-2015, 01:03 PM | #378 |
I am in love with that engine!!!!!!!!!!!!!
03-24-2015, 02:26 PM | #379 |
2 inches each side for a total of 4 inches
thank you |
03-24-2015, 05:42 PM | #380 |
can we get a little close up pic of the rear bag set up and watts link?
03-24-2015, 05:43 PM | #381 |
Sure can I will get one tonight.
03-24-2015, 05:44 PM | #382 |
thanks.
03-24-2015, 05:49 PM | #383 |
no problem
03-24-2015, 07:15 PM | #384 |
Is the rearend the 71-72 width? I guess even the 67-70 width would be to wide too though. What's the width/BS on the wheels?
03-25-2015, 09:33 AM | #385 |
03-25-2015, 11:12 AM | #386 |
Awesome rolling chassis
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
03-25-2015, 11:20 AM | #387 |
looking great Eric
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
03-25-2015, 12:43 PM | #388 |
I changed it to the older one already. I knew with the lip of the rim it would never fit but I had to try. I appreciate the info.
03-25-2015, 12:56 PM | #389 |
Thank you glad you like it.
Thank you same to you full width offset. 4.75 back space on a 10 inch wheel. I have a 68 rear end under it right now. |
03-25-2015, 01:00 PM | #390 |
03-25-2015, 03:48 PM | #391 |
Man Eric the watts link and forward inner bag mount setup looks awesome and that new style inner frame stiffener sure looks stout
03-25-2015, 04:30 PM | #392 |
Shiny bits!
03-25-2015, 07:01 PM | #393 |
that'll work! thanks Eric.
03-25-2015, 09:48 PM | #394 |
Hey Eric. How does that watts rear piece work? What exactly is it ? Build look great man
03-26-2015, 09:54 AM | #395 |
The upper and lower bars that go from the frame rail to the center pivot are not installed yet they are what center the rearend as the rear moves up and down the center pivot makes up for the difference in length as the bars travel threw there arc. here is a pic to give you an idea.
03-27-2015, 11:41 AM | #396 |
03-27-2015, 02:11 PM | #397 |
That makes sense on the watts link..last time I saw one was on a Camaro, and it was preloaded at 45-degrees..wouldn't that cause a little stepping out?
03-27-2015, 09:06 PM | #398 |
Such an amazing build! Frame looks great.
03-27-2015, 09:52 PM | #399 |
Everything is looking awesome - the motor is mean looking...sick!
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
03-29-2015, 12:44 PM | #400 |
A guy with a truck
Great looking, beefy setup. What's the plan for exhaust?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
