06-15-2021, 08:59 PM | #376 |
Re: Orson the 49 GMC ~ Chris C.
I think we are finally good with the dash
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
06-16-2021, 07:34 AM | #377 |
she's comin together and lookin good! i can't wait to be far enough along to be getting bumpers on.
06-16-2021, 08:37 AM | #378 |
Thank you
06-16-2021, 10:30 AM | #379 |
Looking good!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-16-2021, 07:53 PM | #380 |
We got the dash in paint today and I’m not happy with it, so we cut it back down
Put the steering column back together today
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-17-2021 at 09:52 AM. |
06-16-2021, 07:55 PM | #381 |
Got the back bumper situated today and welded the brackets
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-17-2021 at 09:53 AM. |
06-16-2021, 07:57 PM | #382 |
Figured out the headlights today too. Those are LED's!
06-17-2021, 10:26 PM | #383 |
One of my guys spent pretty much all day messing with the headlights. Chris is lucky, since I’m relatively sure that this is the last set I’ll ever do!
My other guy finished up your dash and changed the U Joints. tomorrow we measure how much the front Shaft needs to be shortened, put in the column, start putting in the engine harness, and start putting the dash back together.
06-18-2021, 08:22 AM | #384 |
If those are a Hagen frenched light kit I bet they dot have many repeat customers. The light adjustability (or lack there of) of those lights is garbage with their plastic retaining rings and flimsy springs. I never got my set to properly adjust my lights. I too would never spend $$ on a set.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
06-18-2021, 10:53 AM | #385 |
I was thinking the same thing
06-18-2021, 08:52 PM | #386 |
We finished the headlights
Got the steering column installed and the steering linkage correct Got the front half of the Driveshaft measured for shortening
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-20-2021 at 11:16 AM. |
06-18-2021, 08:54 PM | #387 |
Got the wiper motor installed
Monday we work on That engine harness and getting the dash back together. We’re also doing a parts run on Monday.
06-21-2021, 08:47 PM | #388 |
we wired the headlight switch
Wired the dimmer Put in the headlight switch and ignition switch And primed the radio plate also without pictures, we finished welding up the firewall (near the column) and started installing your new engine harness
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-22-2021 at 09:46 AM. |
06-22-2021, 08:11 PM | #389 |
got the column wired, all that’s left are the gauges and heat/AC.
We spent the day putting in the engine harness and Christian spent the day re making the radio panel (he made the hole for the dual USB port too big)
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-23-2021 at 09:37 AM. |
06-23-2021, 09:57 PM | #390 |
we remade your radio plate
And mounted the dual USB we also finished with the engine harness install and should be doing initial start up tomorrow
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-24-2021 at 09:38 AM. |
06-24-2021, 06:59 PM | #391 |
haha did she fire up?
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
06-24-2021, 07:34 PM | #392 |
we did get the truck running today. Unfortunately it only seems to run in the start position, as soon as you let go of the key it quits! We bought a new ignition switch tonight. We will continue diagnostics tomorrow. any ideas?
We also got the rear speaker boxes fabbed up, paint tomorrow
06-25-2021, 09:09 PM | #393 |
We got the AC condenser mounted today complete with custom brackets
we finally got her running today! https://www.facebook.com/olesargecus...19184862809216
06-28-2021, 08:54 PM | #394 |
Busy day today. We started out by finalizing the Electric wiper install (I’ve ordered some billet knobs for the wiper and headlight switches s
Next we tacked the transmission tunnel in place Then we created the flip down center grill
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 06-29-2021 at 09:09 AM. |
06-28-2021, 08:58 PM | #395 |
I had Wyatt start hanging the vintage air
we also installed the Transmission cooler today then Christian primed and painted the speaker boxes
06-29-2021, 08:45 PM | #396 |
We finished putting in the AC evaporator today
Installed the two note trumpet air horn
06-29-2021, 08:46 PM | #397 |
And finished and installed the 6x9 boxes
06-30-2021, 09:31 PM | #398 |
The knobs for the interior came in today
We ran the heater hoses and used a bracket from a newer Silverado to attach it to the inner We started building AC lines also
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 07-01-2021 at 05:28 PM. |
07-01-2021, 08:17 AM | #399 |
Good progress! Is that Silverado bracket some sort of bolt-on pass-thru for big hoses?
07-01-2021, 09:26 AM | #400 |
It’s a bolt on heater hose bracket
