#4026 |
Re: What did you do to your truck today!
4l80e is ready to go. Still waiting on driveshaft. Dont want to cut original shaft in case I'll go back to th400. Picked up 2 spare wheels for $20. More parts next week.
#4027 |
Ordered my Bowtie overdrives 2004r today. Ouch/excited.
www.tomthetruck.blogspot.com <-- Aka build thread. |
#4028 |
Truck and auto performance nut
Level 3?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#4029 |
2. Engine should be putting out right at/just under 400
#4030 |
Yesterday one of my mechanics helped me out. He got all the running lights, marker an brake lights working.
![]() Got the title in my name today. Tomorow I hope to get off work early nuff to run it thru emisions again so can get it tagged an registered
Chris '69 C-20 '04 Jeep TJ |
#4031 |
Changed my grill out to get rid of the black one and used a do it yourself bedliner kit.
I kinda hate bedliners although my bed was in pretty poor shape to start with.
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
#4032 |
Exact same welder I have. You'll love it.
#4033 |
well yesterday i got my grant wood steering wheel on,today i took a break and cleaned my veloster.
#4034 |
Today, I talked to my truck nicely... VERY nicely. With a bit of sweat starting to run down my neck...
I was sitting in a line of traffic waiting to get through a stop sign... the engine was warm, but after 3 or 4 minutes... when it was my turn to get with it or get out of the way... it DIED. YIKES! I mildly panicked and prob flooded it a wee bit. Shoulda just pulled the choke- but after 30 seconds of self-cursing and 'waving' to the folks behind me (can't believe that NO ONE honked)... got it started and took my place in line. Life goes on... sometimes there's just a bit of excitement thrown in to remind you who is in charge ! (I was probably just getting reminded to drive the darn thing more frequently) Today I'm using it to haul around a sofa for someone, so maybe my attention will be rewarded... |
#4035 |
Installed the fuel filler door! Yes....
#4036 |
I've een on vacation this week so I have had plenty of time to take care of and fix quite a few things this week so far.
Changed oil and oil filter. Checked transmission oil. Replaced fuel filter. Replaced starter with a rebuilt unit. Cleaned up some electrical contacts in starting circuit. Replaced ignition switch. Repacked wheel bearings and greased up all suspension parts. Drove out to the lake to do some fishing yesterday. No luck! ![]() Going out again today! ![]() Keith |
#4037 |
RAT1968 '68 Cab/'71 Parts
All but the ignition and one ground wire done on the Vintage Air. The cables were a b*^$h. But, that's because I do them about every six years. Hahahaha!
Dropped her off of the jacks to look at some wheel rub clearances. No apparent problems. More cab work tomorrow. Short of adding fluids, and a trip to the A/C guy, I'm pretty much done under the hood....Maybe. Waiting for bumper bolts. Gotta fill the differential. adjust the e-brake. Find the brake fluid leak up front. That's the worst part of this build so far. Stainless lines. I'm having a real issue finding where the crap is coming from. I'll have to pull the a/c controls out again because I'm still doing duct work and radio, etc. Here are some pics from today: http://tinyurl.com/7fdbgm2
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#4038 |
Gave it a ride on my new to me lift.
How 'Bout them Dawgs! ![]() '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
#4039 |
I loaded the truck up and went to the Spring Willys Reunion on Friday. I had enough Jeep parts on the truck to squat it a bit LOL! This was it's longest excursion from home, 200 mile round trip.
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
#4040 |
![]() Join Date: Dec 2006
Tore my front suspension back apart and installed my porterbuilt tubular control arms and bags. Only got the driver side done, still need to do the passenger side.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#4041 |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#4042 |
Let's see...I got my steering column (with all the new parts) back in. Got my new master cylinder bolted on but still have to install the proportioning valve and hook up the brake lines. Got some more of the wiring done (safety switch, brake light switch, cigarette lighter and steering column). The 100 amp alt I got from Jeg's has a short or something, shooting sparks out the back and only charging 13.1 volts so I took it off and sending it back tomorrow. I ordered my new Dakota digital VHX gauges from Summit last week...waiting for the UPS guy.
#4043 |
Dang. All I did was bleed my brakes an passed the smog test.
Well atleast my driver is a legal driver now !
#4044 |
Old member
Got the LED front turn signals in today!
Now I have all my lights LED with a normal flasher. ![]() ![]() ![]()
#4045 |
[QUOTE=Andy4639;5393023]Got the LED front turn signals in today!
Now I have all my lights LED with a normal flasher. ![]() ![]() Beautiful lights!!! It's been busy around here. What a pain the ebrake was today. Cleaned up some of the Vintage Air wiring and temporarily "fitted" the steering wheel and glove box door. Day off the truck tomorrow for honey-doos. I'll see what happens Wed.
#4046 |
Old member
Inside the truck looks nice man! I like that wheel. Where did it come from?
#4047 |
~Rest In Peace~
i wash it
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#4048 | |
I know the mfg. started with an "M". And the guys that were selling it were a marine outfitter from Tennessee or Kentucky, if I remember correctly. But, the older I get, the more my mind's like a colander. Here's the wheel without all the wires around it.
#4049 |
Old member
I like it looks good and well made. Italain to!
#4050 |
Well got my inner/outer rockers/cab corners and new doors done and painted to match interior, seat back in again too. Also most of bodywork on front of truck, primed and painted semi black for now, getting closer to back on the street, just waiting for the new rims and tires still, a few more weeks for sure, lots of time for more bodywork.
