#4051 |
Re: What did you do to your truck today? Chapter II
Fixing up this foam for new covers. Dodge buddies I bought last year.
http://67-72chevytrucks.com/vboard/a...1&d=1469985197 |
#4052 |
![]() Join Date: Dec 2012
Finished my inner fender install today. Both painted body color. Now on to getting the bed finished this coming weekend.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#4053 |
![]() Join Date: Feb 2009
My stepdad threw an open pair of sheers "too me" yesterday morning. He's not quite right anymore (85, Marine Lt. Col.). I was backed up against a ledge at the time adjusting sprinklers. Anyway, it was my hand or upper chest, so off to the doc. tomorrow for a stab wound on the palm..................But I had prior arrangements (ha!), so I tore down the bed. Today was get organized day and I cleaned up the reverse housings...........Man, the rubber on three of four pieces were a mess. I realized today it's not corrosion, or at least mine weren't. The dirt came of with oil, rubber cleaner and a wire brush on a low setting. Took some patience like most everything else, but they turned out nice.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-01-2016 at 12:26 AM. |
#4054 |
![]() Join Date: Mar 2005
I got new shocks at each corner put on and replace the upper A-Arm bushings on the drivers side. Big improvement!
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#4055 |
I bought 3M strip caulk and NAPA's version of "RTV silicon" and I've been playing around with how to get the heater box back together. Right now I await info on whether or not my rivets are the right length and I am having trouble getting the screws back into the wire-like brackets that hold the heater core over to the side.
#4056 |
#4057 |
sorry, didn't mean to post 2x
#4058 |
My mother burned her leg on the tailpipe of her 1975 Pontiac Bonneville badly once. Careful around hot things!
I forgot to mention earlier that I cleaned my heater motor's fan with about 100 Q tips. I couldn't get it off the motor shaft and was too afraid to force it. I cleaned it pretty well though, even used and old toothbrush. |
#4059 |
#4060 |
Best thing for burns I've found is aloe vera, and lots of it. I once grabbed the exhaust pipe on a rotor till. It nailed me pretty good, instant blister. I caked aloe on and the next day....nothing.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#4061 |
I sprayed it with unburn, it doesn't hurt, I didn't get it on quick enough it had started to blister before I could get it on. Last year I was tilling up a part of my yard, the tiller quit because something caught in the tines, so I kneeled down and placed my hand on the top for balance, what was on the top? - the muffler! I heard the sizzling, and the heat on my palm, jerked my hand back to see a wet hand print sizzle away, my wife was screaming, I jumped back shaking my hand, I could feel the heat, looked at my hand and nothing, heat was going away, I couldn't believe it! I had enough sweat on my hand that it protected my hand, you talk about having a guardian angle! It took a while to get my wife calmed down.
#4062 |
Active Member
![]() Join Date: Jun 2016
Well bros I got my truck running. Got a new tank from Autozone, Spectra brand, fits like a charm. Fuel line plumbed, new fuel pressure regulator added, vent system hooked up. And I'm cruising. This is basically the first time I've been able to drive it since I drove it home in late June, and that was just an hour and a half on the freeway. Now that I drive it, the giant hole on one of the headers sounds terrible, the steering is really sloppy, and the brakes pull pretty hard left. And it was getting overheated a bit while I was putting around town, but it was 105 outside. But I've got plans for all of it! Woohoo!
David Larsen 1970 Chevrolet C-10 |
#4063 |
#4064 |
![]() Join Date: Oct 2014
I spent yesterday and today doing the CLR bath treatment then used polishing compound and finally Mothers Cleaner Wax. She's ready for the Nats!
#4065 |
#4066 |
New diy door panels to finish up the interior. I used license plate plastic threaded clips in the missing weld nut locations for the door panels. They fit perfect.
#4067 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Move them outside for a wash and new shoes on the blazer
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#4068 | |
![]() Join Date: Dec 2013
and when you get flash burns to your eyes when speed tack welding , cut a regular potato and squeeze the potato juice into your eye it relives the burning feeling and works better than any over the counter eye medication ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 08-03-2016 at 03:51 PM. |
#4069 |
Changed the oil
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
#4070 |
I reassembled my heater box.
#4071 |
#4072 |
I put my heater core into my reassembled heater box. I had to dispense with the rectangular gasket as I just couldn't line up the screws to the brackets with it on. As I wrested the heater core around trying to, part of the gasket can un-sealed with the heater core anyway.
I also cleaned the front of the cab where it mounts and removed all the old gasket caulk. The original paint there is very pretty! |
#4073 |
I apologize but I can't for the life of me figure out how to post a question....so....I currently own a 1972 Chevy Cheyenne long bed truck, it came from Macon Georgia, on the tailgate the L in Chevrolet is upside down, does this give the truck more value? It looks like a factory mistake, but I am not sure. I would appreciate any help with this, thanks.
#4074 | |
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#4075 |
Ok, I will take a picture....but does it make it more valuable?
