Closed Thread
Old 07-18-2012, 07:33 PM   #1
shopking72
shopking72's Avatar
Re: What did you do to your truck today!
Changed out my crappy stock fan for a nicer one. Cleaned my K&N air filter and recharged it. Clean the truck up and drove it to a car show.
Over 100* and the truck was not liking it lol.
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 07-19-2012, 09:22 AM   #2
54belair
54belair's Avatar
Shopking72,
Love the look man, what size are youre wheels and tires? tnx
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline
Old 07-19-2012, 12:27 PM   #3
shopking72
shopking72's Avatar
Originally Posted by 54belair View Post
Shopking72,
Thank you. They are 18x8 with 255/40/18 in the fronts and 20x10 with 295/35/20. Nitto Invos.
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 07-19-2012, 07:56 PM   #4
OJ1988
Just a car guy
OJ1988's Avatar
Ordered seatbelts
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline
Old 07-19-2012, 08:17 PM   #5
jmdemon55
jmdemon55's Avatar
put some fresh gas in the freshly cleaned gas tank. threw a new filter on and started it up. its running like crap. guess the carb got a big drink of the black mess that was in the tank. the new accelerator pump diaphragm was stuck from the mess in the squirter circuit. it wont idle as im sure that circuit is all gunked up to. guess ill be pulling the carb and giving it a soak and a rebuild. this stinks because it was running great for the first 20 minutes till the goo got sucked up. guess its my own fault for not cleaning out the tank. who knows how long this truck sat before we got it. found the power steering setup we just got put on isnt working either. think the used pump is kaput. so today i cursed at the truck and myself, repeatedly! lol! o well tommorow is another day and is supposed to be a bit cooler.
jmdemon55 is offline
Old 07-24-2012, 10:38 PM   #6
denz72
denz72's Avatar
Nice longbed and very clean
denz72 is offline
Old 07-24-2012, 10:53 PM   #7
ole dollor
ole dollor's Avatar
sjarrett71 : if you are home stay there, if you are a little ways from home drive real slow and go home....if the u joint did not want to go together , you let a needle bearing fall down into the cup and it want go together....pull it back apart and see how many needle brg, are broken inside the cup. if you have a few old good ones you can put it back together and get a good clip...or go get a new one, and put it in....the secret is put a some grease in the cup with the needle brg. to hold them in place while you install them, best to use a vice to start both ,then and socket,the right size....to get them in all the way ..checking while you do this for alinement and if its binding up....hope this helps.
ole dollor is offline
Old 07-24-2012, 11:08 PM   #8
70' 396 Stepside
70' 396 Stepside's Avatar
Ran all over town buying a new set of wheels & tires (at least new to me) for my ride and then getting them mounted, balanced then cleaned up. Also bought new shocks and a new set of gauges for my weekend project.
I will try to add a pic with the new rubber...not sure how to do that from my phone though...
70' 396 Stepside is offline
Old 07-24-2012, 11:09 PM   #9
sjarrett71
sjarrett71's Avatar
I appreciate the info but the u-joint is in correctly, no out of place needle bearings or anything. My problem is the outer edge of the yoke broke off so I can't install the retaining clip. I was trying to get just a little more space to install the clip and pressed too hard, snapping off that outer ring.
-Scott-
sjarrett71 is offline
Old 07-24-2012, 11:18 PM   #10
midniteblues
midniteblues's Avatar
better get a new/differnt yoke it can/will back out
After what seemed like a long wait I got back some of my parts all done!
a tac,vac and a 80# oil pressure guage in a nicely patina'd but perfect 67-78 bezel.
and my mirrors all for my 67 stepper
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 07-18-2012, 09:00 PM   #11
sjarrett71
sjarrett71's Avatar
Shopking, that is a sweet looking truck! Love the color, love the stance!
-Scott-
Old 07-18-2012, 11:33 PM   #12
shopking72
shopking72's Avatar
Thanks!!
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 07-18-2012, 11:43 PM   #13
Jarwood
Jarwood's Avatar
Absolutely beautiful man!
Jarwood is offline
Old 07-18-2012, 11:44 PM   #14
POPO1984
POPO1984's Avatar
Dropped it off at the painter. Medium olive poly it will be.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline
Old 07-19-2012, 12:03 AM   #15
in deep 72
in deep 72's Avatar
Installed the transmisstion, transfer case, drive shafts, radiator, electric fans, clear side marker lights, and pulled the broken front axle shaft.....very productive evening! Tomorrow, new axle shaft, rehang the exhaust paint the bumpers and rims black. Looks like I'll make the mud run this weekend!
in deep 72 is offline
Old 07-19-2012, 09:10 AM   #16
rogergodding
rogergodding's Avatar
Took the carb off my truck and put it on my sons and scored some Sanderson headers for $225!!
rogergodding is offline
Old 07-19-2012, 08:24 PM   #17
JimZ
JimZ's Avatar
Just finished lay-out, forming, creating, and installing my A/C hoses and heater hoses, making a bulkhead plate, bracketing my drier and putting line spacers on. 40 + hours. Everything made, cut and crimped to size.
http://my65short.blogspot.com/
JimZ is offline
Old 07-19-2012, 11:12 PM   #18
PAWS 72
PAWS 72's Avatar
Washed and cleaned her up good for Saturday's show. Maybe do ok this year.
PAWS 72 is offline
Old 07-19-2012, 11:40 PM   #19
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Went to the trans shop...Trans wasn't ready. Went to Napa to have trans cooler lines made up ($106.).
Went to Manny, Mo, and Jack's for more fluids (of all kinds), a black plastic thingy that holds the fan sensor in the radiator,
an open-plenum carb gasket, some slime floor weep up stuff, and a drop light that I need to replace the one I slammed in the door ($133).
Moved the melted (my bad choice) starter wire, (re) installed the starter and flex plate.
Oh, after putting in the new freeze plugs, we put the motor back in yesterday. The trans had to be outsourced to fix more leaks than I could deal with.
Other than the trans fix in the works, it's all about re-hooking stuff now.
Speaking of hooking up, the truck's been on non-op for a couple of years. Today I got the bill for tags for 12 months. California....$212.
Went to get insurance added at State Farm. $216 for the year for no collision for now. High PL and PD coverages.
When it's painted, or even when body work progresses a little further, we'll jack the coverage up...but for now, we're self-insuring on *our side* of any loss.
I'm just glad I'm close enough to think she's ever gonna be on the road!
Here's yesterday morning:
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 07-19-2012, 11:38 PM   #20
shopking72
shopking72's Avatar
Got my DDM Tuning 6000K HID kit all hooked up. Very easy install. I need to aim my lights and I should be all set.
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 07-20-2012, 09:31 AM   #21
snj8198
snj8198's Avatar
nice looking. what wattage did you go with? at 6K calvin, does the blue burn off after warm up or do they keep their hue?
Im using a DDM kit on my '11 Rzr S and enjoy it. on lookers don't though
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline
Old 07-20-2012, 06:06 PM   #22
shopking72
shopking72's Avatar
Thanks. I went with the 35W. It doesn't look so blue after a bit. I have 55W kit on my 2010 Z1000 with 6000K, and that light is amazing.
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Old 07-20-2012, 01:42 PM   #23
OJ1988
Just a car guy
OJ1988's Avatar
Smile Re: What did you do to your truck today!
What kit did you use? Dis you upgrade the wiring too?
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline
Old 07-20-2012, 03:05 PM   #24
in deep 72
in deep 72's Avatar
The HIDs look good! Mine didn't work. Running the new lenses and H4s and they're 100 times better than stock, I could only imagine how good the HIDs are.
Old 07-20-2012, 06:10 PM   #25
shopking72
shopking72's Avatar
DDM Tuning 35W 6000K H4 kit. Yes I have upgraded wiring with my LMC harness.
1966 Caprice
2001 Tahoe LT
2010 Kawasaki Z1000
Closed Thread
