Old 01-25-2020, 08:47 PM   #4151
Johns327
Johns327's Avatar
Re: What did you do with your truck today, Part 3
I went to the LA roadster show at Pomona. If you live in So. Cal. This has got to be something you should do. Last year there wasn’t that many AD or TF trucks there, but this year they had quite a few. I realize that most of these never see real driving, but wow there were some beauties. Oh yeah, there were other nice cars there as well, but if it’s not a truck, why own it.
Here are a couple of them.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
Old 01-25-2020, 11:39 PM   #4152
evilokc
I started the metal work to install the nos inner fenders on ifs. its going well. im glad to be putting everything back together again
evilokc is offline   Reply With Quote
Old 01-26-2020, 10:27 AM   #4153
62 Barnfind
62 Barnfind's Avatar
Welded up the front seams.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-26-2020, 11:26 AM   #4154
mick53
I'm 2 1/2 years into my project and seldom do I get to put something together for the last time. Mostly I mock up. I kept everything super clean. I put a small amount of blue Loctite on the studs but it didn't call for it. The Loctite people at PRI told my that blue Loctite also works as an anti-seize. The lugs were torqued at 77 ft lbs. The hat bolts called for red Loctite and 155 in lbs. I like to put a piece of tape on the part and mark it when I have to torque bolts in a cross pattern so I don't lose track on my sequence. I still have to put safety wire on the hat bolts. I checked all mating surfaces and put a thin coat of assembly lube on the bearings but didn't pack them because they will still have to come off many times. Now I have to figure out how to make it steer and how to mount the calipers. Easy right?
mick53 is offline   Reply With Quote
Old 01-26-2020, 01:27 PM   #4155
vintovka
vintovka's Avatar
Went to garage. Started truck up, backed out, drove to town and watched the ocean waves the whole way and a few boats too, got honks and thumbs up on 101. More complements at the Post Office and grocery store. More honks, thumbs up and headlight flashes on way home. Pulled into garage. closed door. Mission accomplished.
vintovka is offline   Reply With Quote
Old 01-26-2020, 08:54 PM   #4156
MiraclePieCo
MiraclePieCo's Avatar
Let me know when the rhododendrons start blooming. We'll come over your way, probably Shore Acres.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 01-26-2020, 09:12 PM   #4157
vintovka
vintovka's Avatar
Shore acres is flat amazing. About 70 miles north of us near Coos Bay. Was last there in December for the Xmas light garden display, Went early to see the massive waves crash into the rocks. If coming to Ophir give us a weeks heads up to get beer ready. We are close to Honey Bear Campground
Some folks get shore acres confused with shore pines. The latter is a nursing home.
Old 01-26-2020, 11:38 PM   #4158
evilokc
of course you got honks and thumbs up. that thing is awesome.
Old 01-26-2020, 11:39 PM   #4159
evilokc
finished the cutting to fit the fender. looks good. going to dress the metal a little more and start mounting it for good.
Old 01-27-2020, 12:43 AM   #4160
mick53
I put stainless pipe plugs in the oil pump supply passage and the bypass passage. I doesn't look like much but took 6 hours. It would have been easier to plug the oil pump passage in the crankcase but I didn't want a chance it could come out and land inside the crankcase. I had already plugged the dipstick hole. Now I need and AN fitting in the center and plug the distributor hole. Then I worked on installing the winch in the race car trailer for a change of pace.
Old 01-27-2020, 10:05 PM   #4161
MiraclePieCo
That's my problem: I've been to Shore Acres many times for the Christmas light show at night, but never actually seen it during the day.
Old 01-28-2020, 12:25 AM   #4162
oldman3
oldman3's Avatar
OK fellow and gals, only 5 days left to vote on TOTM, only 143 votes total so far. If you haven't voted here's the link http://67-72chevytrucks.com/vboard/s...d.php?t=800072 Thanks...Jim
oldman3 is offline   Reply With Quote
Old 01-28-2020, 01:32 AM   #4163
joedoh
joedoh's Avatar
YES everyone vote! every time I log in I see 10-20 people browsing this forum, and only a few repeating usernames!
thanks for the pictures, got any more of this one? I like the 56 car trim but I am wondering what the bedside looks like.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-28-2020, 11:35 AM   #4164
Johns327
Johns327's Avatar
Joedoh,
Yes I have a few more. It was a beauty. Notice the glass had no rubber seal.
John
Old 01-29-2020, 12:42 AM   #4165
mick53
Object of the game is to put this AN fitting in the water pump. This is a Flowkooler high flow water pump. They are the only ones I could find that make a high flow for a 292. I still have some smoothin to do. I cut it off reamed it out and ran a 3/4" pipe tap in it. This goes to my Ron Davis drag radiator between the frame rails with electric fan and electric water pump. This radiators prime function is to cool the engine after it is shut off with override in case I get caught in traffic in death valley. I have Dakota HDX gauges that control 2 fans with individual speed and temp cutout and will run for up to 6 minutes after shut down. If I am posting too often or too many pictures please let me know. Thank you for your time.
Old 01-29-2020, 01:47 AM   #4166
NorCalGal
NorCalGal's Avatar
Mick, there’s no such thing as too many posts or too many pictures.
Jan's 53
NorCalGal is offline   Reply With Quote
Old 01-29-2020, 01:48 AM   #4167
joedoh
joedoh's Avatar
Joedoh,
John
thanks, I was wondering what he did about the spears and it looks like he just removed them.
that rear glass probably cost more than childbirth.
Old 01-29-2020, 10:15 AM   #4168
oldman3
oldman3's Avatar
X2 keep them coming...Jim
Old 01-29-2020, 12:21 PM   #4169
DransportGarage
DransportGarage's Avatar
X3. At some point you'll do something that isn't over my pay grade! That's some neat stuff!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 01-29-2020, 12:47 PM   #4170
dsraven
nice work.
just curious if the AN fitting will restrict the flow of the pump due to the necked down inside diameter.
I am sure you have that covered
Old 01-29-2020, 12:59 PM   #4171
DransportGarage
[QUOTE=dsraven;8668345]<snip> ...just curious if the AN fitting will restrict the flow of the pump due to the necked down inside diameter... <snip>/QUOTE]
I hope not. These are -AN10...
Bob
Old 01-29-2020, 01:27 PM   #4172
vintovka
vintovka's Avatar
Go at 4PM and see the waves then stay for the light show and the free hot cider and cookies in the Gardens Victorian house. Don't stand too close to the wall overlook as we watched some folks really get splooshed/knocked down by a wave top.
Old 01-29-2020, 01:48 PM   #4173
mick53
Originally Posted by dsraven View Post
nice work.
Should be fine. If I didn't have the extra inlet I would have tee'd it off the heater hoses. It's an aux radiator. The electric pump has the same fittings.
Old 01-29-2020, 06:56 PM   #4174
mick53
I got my complete ignition system last night. I bought 2 extra coils. It has sensors for manifold air pressure and air temp. Coolant temp, knock sensor and exhaust gas. It has continuous spark for 60 deg. rotation on the power stroke. It has multiple soft rev. limiters. You can store multiple ignition programs. That gets me through page 8 of 134 in the manual. It has a valet mode where you can limit the rpm's and the speed. Don't think I'll need that. My racing team that cost $28 to set up saved me $277.
Old 01-30-2020, 01:25 PM   #4175
mick53
I put the safety wire on the front rotors. This was not fun or quick. Here are a couple of things I learned. This follows the general rule that the hole you need is in the worst spot. This is .032" stainless wire, when you cut it it is hypo sharp. The $25 for the twisting/locking pliers is money well spent. Always cut the wire at a 90 deg. angle and deburr it with sandpaper. It only takes a few seconds and will save you much pain. Bend over the ends and point them down when you are done. Pick up your scrap. Thank you for your time.
