Old 05-31-2009, 07:24 PM   #401
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
Holy sh!t that is bad arse.....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-31-2009, 07:31 PM   #402
Chlsnk
Chlsnk's Avatar
Love how you built your innerfenderwells I may have to steal your idea if you dont mind.
Chlsnk is offline   Reply With Quote
Old 05-31-2009, 10:21 PM   #403
LooseCannon
Oh man the engine compartment looks awesome!
How did you role the inner fender and what did you use for cutting?
LooseCannon is offline   Reply With Quote
Old 05-31-2009, 10:41 PM   #404
68 short step
thanks everyone....i used a 4.25" OD roller on one radius of the fender and a 3" OD roller on the other (lower) radius.....the fan shroud, i used a brake.....
i used a combo of cutting tools, one was a plasma cutter and the other was a cut-off wheel
68 short step is offline   Reply With Quote
Old 05-31-2009, 11:44 PM   #405
Rokcrln
Rokcrln's Avatar
What kind of a roller do you use, Got any pics?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-01-2009, 12:34 AM   #406
Big J'72 GMC
wow, that is some of the nicest fab work I've ever seen, could be my weak spot for these trucks, but yours is what will be fillin my dreams tonight lol
Big J'72 GMC is offline   Reply With Quote
Old 06-02-2009, 11:11 AM   #407
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
Nice work under the hood ...
72 SHORTBED 7.0 is offline   Reply With Quote
Old 06-03-2009, 08:41 AM   #408
sandking
.....I am working on it.....
sandking's Avatar
WOW!! Awesome build!!
Couple of questions that I may have missed:
1. What headers are you using?
2. Please explain to me the parts used for your lines to and from your power steering box and the pump. I like the braided lines.
Nice work man!!
View my build thread HERE
sandking is offline   Reply With Quote
Old 06-14-2009, 08:56 AM   #409
68 short step
the headers are for a 99-02 firebird/camaro........
im working on the bed, i had to raise the bed floor 4" to clear the notch.....also we're converting it to a wood floor..... started by clearancing the rear most crossmember, and raiseing it 4".....then i bent up some new angles, measures up 4" from the bed floor, made my cuts, trimmed my angle to fit, clekoed angle in place, and repeated the same process for the other side.......once that was done i started with raseing my bed mounts..... i made a simple raised mount, that happened to turn out looking like alabama......then i welded my alabama bracket in place.......thinking my alabama bracket looked to plain/square (altho i doubt this would easily be seen), i added a few curves for the other bed mount bracket, further up on the frame.....this bracket came out looking like the lockness monster head comeing outta the water (so i was happy with this one)
then i welded the lockness monster in place, then proceeded to make alabama look like lockness, so they would match......the rear tubs are in the design process, and will be more of a round design, rather then the stock 'square-ish' design..
Old 06-14-2009, 08:57 AM   #410
68 short step
Old 06-14-2009, 08:57 AM   #411
68 short step
Old 07-01-2009, 10:13 AM   #412
ChevyChad
I'm diggin the Loch Ness brackets!
ChevyChad is offline   Reply With Quote
Old 07-01-2009, 10:55 AM   #413
72 SHORTBED 7.0
Looks good ...6 in right ,you would think some one would make a kits to do this by now..good job D
Old 07-03-2009, 05:54 PM   #414
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Wow, that was a lot of reading. Now let me go take it all in
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 07-03-2009, 09:08 PM   #415
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Wow, that is some amazing work you have done there. Keep it up!
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 07-04-2009, 12:04 PM   #416
ERASER5
ERASER5's Avatar
Cool project.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-12-2009, 09:58 PM   #417
68 short step
makeing some progress on the bed.... its starting to look like a bed again.....since we narrowed the rear end, we had to tub it....since the dash is round and the stock tubs wouldnt match anything
( they are square-ish) we desided to do a round tub..... at first we wanted 'BIGGEST' tubs, but after makeing them 24" wide, it really subtracted from the rest of the bed....all you focused on was how wide they were, and didnt notice anything else......so they were trimmed down (16.5" wide) till they were finally 'BIG' but less of a distraction, and more of a complament to the rest of the bed.......here is the process, trial fit them in there, notch the bottom for axle clearence, trim to make it fit flush with the inner bed side, build a mounting flange, weld it on, and temperally cleco it in place.....and lastly for looks i sat the wood in there....of coarse some peices of wood will need to be specially cut/ fitted, but you kinda get the picture....sorry first pic is so fuzzzzy
Old 07-12-2009, 09:58 PM   #418
68 short step
Old 07-12-2009, 10:06 PM   #419
72 SHORTBED 7.0
Looks good D Nice work
Old 07-12-2009, 10:22 PM   #420
killer71
killer71's Avatar
sum of the wood is already warped.
Nice Update!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-13-2009, 01:05 AM   #421
Blitz
Mr. Thread Killer
I know I've probably asked TOO much now but any progress on the gauges? Only asking because I need to know what I'll need to do to get it to work in my fuuuuture project. If you want to PM me that's fine too. I know some of the details are still under wraps.
Blitz is offline   Reply With Quote
Old 07-19-2009, 03:55 PM   #422
68 short step
bliitz- ill have to let hulk71 feild that ? for ya...
got the wood cut to go around the new tubs.....also got the tubs to be 'bolt on'....i drilled some holes for where the bolts will go, then made some nutplates, drilled smaller holes around mounting hole (so i could plug weld the nutplate), plug welded them in place, then grind down the welds...
Old 07-19-2009, 03:56 PM   #423
68 short step
after the fenders were mounted, they needed some flanges to cover the edge of the wood. so i made some flanges and welded them on...
Old 07-19-2009, 03:56 PM   #424
68 short step
after i welded the flanges on i had a little gap (between the fender and flange)..... after looking at it, it started to bug me....and i thought it would look better if it was smooth (no gap)... so i welded in the gap and smoothed it over....also note, that i rounded the sharp edges where the flanges came together...and finally the end result.
Old 07-19-2009, 04:10 PM   #425
VA72C10
VA72C10
VA72C10's Avatar
Those look great. Nice job!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
