02-06-2010, 10:14 PM | #401 |
Re: Surf Blue
wow, this truck looks I really like the improved look with the new shoes....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
02-07-2010, 08:38 AM | #402 |
Re: Surf Blue
Truck looks sick now with the new hoops, the riv and truck look amazing sitting there together! Nice choice.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-07-2010, 08:07 PM | #403 | ||
Re: Surf Blue
THANKS
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
02-07-2010, 08:13 PM | #404 |
Re: Surf Blue
I'll have some more pics to post in a few days of the brake upgrade I ordered. I got some drilled and slotted rotors, dual piston Wilwood calipers, and steel braided hoses that I'm waiting on.
02-09-2010, 01:08 PM | #405 |
Junior Member
Re: Surf Blue
Hey Danny,
I just took a look at the entire build and you have done a fantastic job. It is hard to beleive we were next door neighbors at one time. It was good seeing you again and keep up the good work. Kevin
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-13-2010, 08:32 PM | #406 |
Re: Surf Blue
Got a little more done. I finally got my brake upgrade which consisted of Wilwood D52 calipers, steel braided hoses, and drilled and slotted rotors. The install went pretty smooth especially since it was all direct OEM replacement parts.
I've got a few issues that I'm not real happy with that came from some decisions I made 3 years ago on this truck and the time has come to have them addressed. First off I ordered some dual electric fans with a nice aluminum fan shroud from a place called Entropy radiator. These are going to replace the current single Corvette elec. fan that I have now. I'll post pics when I get it all installed. Since I'm changing the fan and shroud I'm getting away from the zip-tie mounting things that some of that stuff came with. I decided to make a permanent mount for my trans. cooler as well since it used those zip-tie things also. Pic enclosed. The engine swap I've been talking about is closer than ever and may become a reality real soon. Leaning a big block of some sorts ,but still unsure as to which one I'm going to do yet. That's all for now I'll post more when I get more done.
02-13-2010, 08:33 PM | #407 |
Re: Surf Blue
One more
02-13-2010, 09:39 PM | #408 |
Truck and auto performance nut
Re: Surf Blue
Big block? I thought you were going to go with an LS motor? If you want big block power you can get it with a big c.i. LS small block. Get the iron LSX sportsman block and 454ci is no problem... with something like 500ci being the high end.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
02-13-2010, 10:20 PM | #409 |
Still Learning
Re: Surf Blue
those new wheels look great~!
02-13-2010, 10:38 PM | #410 |
Re: Surf Blue
The LS motor was one of the choices I was considering but the big block seems to be the easiest way for me to go.
02-28-2010, 12:20 AM | #411 |
Re: Surf Blue
Got some new stuff in and started installing all of it. First off I got some stainless steel brake lines that I'm going to be plumbing up in few days. Sold the billet grille that was on the truck and got a stock '72 grille to replace it. I'd have it done but they gave me two right side brackets instead of a left and right , go figure. I also received my new fans and shroud from Entropy and got them installed ,still waiting on some wiring to show up for that to get finished. I'm kind of stuck until more parts show up so this is it for now.
The last pic is how some of us rednecks get rid of big bulky boxes that new parts come in.
02-28-2010, 12:21 AM | #412 |
Re: Surf Blue
The redneck pic.
02-28-2010, 12:58 AM | #413 |
67-72 parts collector,…
Re: Surf Blue
I REALLY like the stock grille on your truck!
Super clean. I'm also watching your "brake issue" thread.
03-01-2010, 12:06 AM | #414 | |
Re: Surf Blue
I think the stock grille looks alot cleaner. I'll post more pics after I get it all put back together.
03-01-2010, 01:26 AM | #415 |
Still Learning
Re: Surf Blue
We do that here with big boxes too.
03-01-2010, 08:52 AM | #416 |
Under Construction
Re: Surf Blue
looking good.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-02-2010, 08:46 PM | #417 |
Tot Roddin'
Re: Surf Blue
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-07-2010, 11:16 AM | #418 |
Re: Surf Blue
Finished the fan and grille install ,still have some small detail stuff to do on the grille (paint rivets) but for the most part it's done. I wish I would have wired my fans up with a thermoswitch a long time ago , it's way more effecient than the way I had them wired up previously. I haven't had time to re-plumb the brake lines yet ,I think I'm going to order a nice MC and then plumb them. That's all for now enjoy the pics.
03-07-2010, 11:22 AM | #419 |
Re: Surf Blue
Nice!!!
03-07-2010, 11:24 AM | #420 |
Re: Surf Blue
killer!!!!!
bogey5 |
03-07-2010, 11:02 PM | #421 |
Re: Surf Blue
My new favorite truck
03-08-2010, 02:38 AM | #422 |
Re: Surf Blue
great looking as usual, let me now what you think of those calipers, I am currently looking at a set.
03-08-2010, 09:03 AM | #423 |
Re: Surf Blue
The grill completely changed your truck in my mind.
Looks Sweet!
03-08-2010, 10:17 AM | #424 |
Under Construction
Re: Surf Blue
very nice..
03-08-2010, 10:25 AM | #425 |
VA72C10
Re: Surf Blue
Looking great as usual!!!
Looking for a 67-72 swb or blazer project in or around VA. |
