07-30-2018, 04:24 PM | #401 |
C10 CLUB Y QUE!
Re: Power Brake Booster Adapter Bracket
Send me a pm 61 suburban
07-30-2018, 11:17 PM | #402 | |
60-66 Nut
I assume GM went with the bellcrank assembly to change the pedal ratio to one better suited to power brakes.
Yes you will have to remove the bolts attaching the pedal bracket to the firewall since my booster brackets use all of those attachment points just as GM designed it to be. This is a very important criteria that many people overlook or don't seem to care about. Automotive brakes is not a place to cut corners. If you connect the pushrod to the original manual brake pushrod hole in your brake pedal arm, your brakes may be touchy. If so, just drill another hole in the brake pedal arm 1" lower and try that. Quote:
08-18-2018, 07:31 PM | #403 |
John, I received my bracket today. Beautiful part. Thanks again
Brett
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
08-19-2018, 12:49 AM | #404 |
60-66 Nut
Thanks for the compliment and the purchase Brett
09-08-2018, 10:47 PM | #405 |
John, just sent PM. It’s going on my 64. Brake Booster only in BLACK. Thanks, Tony
09-08-2018, 11:47 PM | #406 |
60-66 Nut
PM received as well as payment. I replied to your PM.
10-02-2018, 01:21 AM | #407 |
Hello, Going to the junkyard to gather the rest of my parts for my 65 C20 disk brake swap from a 78 C20. Will the booster and master cylinder work with your bracket? Or should I get a 88-98 1/2T booster and use the 78 master cylinder. Thank you for all the help you provide to everyone!!
65 C20 "Marilyn" 65 VW Bug "Daisy" 95 4Runner "JoJo" 15 Tacoma "Taco" Check out my Intsagram https://www.instagram.com/patpetrey/ |
10-02-2018, 11:29 PM | #408 | |
60-66 Nut
None of the '73-'87 boosters are compatible with any of my booster brackets. They have the factory mounting brackets welded to them. That is why they are not on the list of compatible boosters. Yes you can use your '78 master cylinder as long as you use a booster that has the same length intermediate pushrod as the '78 booster. It should be the short one, but I would suggest checking.
11-08-2018, 04:26 PM | #409 |
Captain Fab,
I sent you a PM as well and I need to get a bracket ordered ASAP. Can you reply and give me a call if you have a minute please. Thanks very much! |
11-09-2018, 12:34 AM | #410 |
60-66 Nut
I replied to your PM. I have time to be here on the forum only once a day after I get home from my 11-12 hour workday.
12-08-2018, 06:08 PM | #411 |
Captinfab what can I use for my 1963 P10 step van I need a power booster but I have no room or a hood.
12-09-2018, 12:26 AM | #412 |
60-66 Nut
I am not that familiar with the P series vans' firewall. Can you post a pic either here or email to captainfab454@hotmail.com ? You might be able to use a booster and master from either an Astro/Safari or full size G series van.
12-09-2018, 12:39 AM | #413 | |
12-09-2018, 12:44 AM | #414 |
60-66 Nut
Well for starters, that has the hydraulic clutch as the '60-'62 Chevy's and '60-'63 GMC's do. So you would need my '60-'62 booster bracket to start with. Is that some sort of brace I see directly in front of the master cylinder? There are a couple of P series vans here on the forum in the '60-'66 projects and builds section. I do not remember what they used for a booster/master assembly
12-09-2018, 12:53 AM | #415 | |
12-09-2018, 12:57 AM | #416 |
60-66 Nut
I make the '60-'62 booster brackets for use with an auto trans. Here is that for sale thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=357542 Here is one of the build threads that I was talking about. http://www.67-72chevytrucks.com/vboa...ighlight=P+van
12-18-2018, 01:36 PM | #417 |
I will take one
12-19-2018, 12:38 AM | #418 |
60-66 Nut
12-22-2018, 01:04 AM | #419 |
60-66 Nut
bowties11 your PM inbox is full and I can not reply to your PM's
05-03-2019, 04:41 PM | #420 |
Hey Captain,
I am kinda new to this site. I just picked up a 63 Suburban. I will be installing front and rear Wilwood disks on a new chassis along with a Caddy 472/TH400 combo to replace the stock 6 cylinder. Attached is a photo of my current firewall/MC, I just want to verify that I am ordering the correct MC adapter of yours. Also, do I just PayPal you for it? I apologize if you have all this info in this thread, but I'm going through 17 pages and trying to work!!! * And one more "Also" - Do I need to lengthen the pushrod for the install? EDIT: I just saw your email address and sent you an email also. Thanks for your time, Eric.
Sent by the random thoughts from the voices in my head... Last edited by EricU; 05-03-2019 at 04:52 PM. |
05-03-2019, 11:07 PM | #421 |
60-66 Nut
I replied to your email, payment received. Thank you
09-11-2019, 10:53 PM | #422 |
I'm needing a pb mount and a couple of ps brackets for a 65
09-11-2019, 11:13 PM | #423 |
60-66 Nut
I'll send you a PM with ordering and payment info.
09-14-2019, 12:22 AM | #424 |
09-14-2019, 12:36 AM | #425 |
60-66 Nut
Here are a couple pics that are more up to date than in post #1. The price is Exactly the same as in post #1. The only options available are satin black powder coating or if you need the hydraulic clutch conversion.
