08-25-2009, 11:20 AM | #401 |
Next project: 1970 K10
Re: Glock's new project: "Fred"
Budget = telling your money what to do, instead of wondering where it went. Try it, you might find you have more than you think!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-25-2009, 11:39 AM | #402 |
Im working on that.. slowly but surely.. spent two months unwanted vacation this summer.. just trying to catch back up no. got two jobs hehe.. keepin my head up though
08-25-2009, 12:13 PM | #403 |
ya, without our monthly budget our money would be who knows where... mine always comes the last of the month usually. what ever is left over from the mortgage and cars goes right to the build/savings. granted sometimes things come up and we have to skip a month but it works out good for the most part.
were planning our vaca for the end of sept. so theres nothing happening for the the build or savings next month COLORFUL COLORADO HERE WE COME!!! (as long as school doesnt get in the way)
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 08-25-2009 at 12:15 PM. |
08-25-2009, 12:18 PM | #404 |
Hmmm, we are planning a Colorado get-together/BBQ on Sept 27th, maybe you will be here for that? That would be awesome! Take a look at the "August Get Together" thread in the Colorado section. Yeah, it started out to be August, but got bumped to September.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 08-25-2009 at 12:20 PM. |
08-25-2009, 12:42 PM | #405 |
i'm grinning ear to ear!! i just talked it over w/ Amy and she just has to check her class syllabus for that week but it is looking good!!
i'll put in my request off today for week of sept. 27th. if it works out we'll get friday saturday before off and we can take our time getting there. if not i'll drive straight through sat. night after work!!!! woooo whoooo! oh yea, i'll check out the thread for time and what to bring. bummer i wont be in the truck...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 08-25-2009 at 12:43 PM. |
08-25-2009, 01:36 PM | #406 |
Harness and PCM are here! WOOHOO!!! Now, I'm going to note every connection that they left in the harness so when I go to put a 5.3L in Goldie I can do this myself and save a few $$$.
08-25-2009, 01:53 PM | #407 |
yep! and post all that wonderous info that you are so famous for glock!
08-25-2009, 01:56 PM | #408 |
Oh, you can count on that!!
08-25-2009, 03:22 PM | #409 |
Yeah that whole budget thing is why I haven't done anything to the truck. Started off good, then got the bill for the engine. Bye bye money saved for truck. Now it's slowly building back up.
08-25-2009, 03:34 PM | #410 | |
'Debt' and 'credit cards' are words not found in our vocabulary at our house. If we don't have the , we don't buy until we do. That, and a budget, has made life much easier. And better.
08-25-2009, 04:21 PM | #412 |
Still Learning
we need pics of the harness!
08-25-2009, 04:28 PM | #413 |
I need to find my camera first!
No seriously, I have no idea where it's at...... So this will have to do for now: 2006 Silverado harness, starting at PCM connectors and moving out from the PCM - BARE WIRES: White - To tach, 4cyl signal Green/White - To fuel pump relay control, 12v + Green/White - AC cycling switch White - To brake light switch, cruise Green/White - AC clutch enable relay control Purple - To brake switch, for TCC Green/White - VSS, to speedo Green - To OBD II connector, in vehicle Brown/White - To SES light 3 Red wires - Each to a 12v key-on fused power source 1 Orange wire - To a 12v battery fused power source 1 Purple wire - To starter solenoid (tie trucks starter wire to this one, or leave it alone and use trucks wire to the starter) CONNECTORS: • Electric fans (high and low, I will have to supply the ground) • TAC module • Wires for cruise: Dark Blue, Gray/Black, Gray • DS coil packs • DS injectors • Alternator • Coolant temp sensor (front of left head, for PCM) • Ground • AC compressor [probably won't need/use] • AC pressure switch (on AC line) [probably won't need/use] • Starter solenoid (see “1 Purple wire” above) • Crank sensor • Oil level switch (in oil pan) MAIN HARNESS SPLITS IN TWO HERE: One: • MAP sensor • Passenger side O2 sensor, front • MAF • PS coil packs • Ground • PS Injectors • Throttle body Two: • Knock sensor harness on intake manifold • Oil PSI switch (behind intake manifold, for PCM) • Cam sensor • Ground • Driver side O2 sensor, front • Transmission, drivers side • Transmission, VSS, tailhousing • Transmission, passenger side
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 08-25-2009 at 04:51 PM. |
08-25-2009, 04:53 PM | #414 |
So Dennis.... if you are going to crash our Colorado Get Together, I suppose that means Fred needs to be on Gen III power by September 27th?????
08-25-2009, 05:13 PM | #415 |
or at least ready for the 1st fire up by then! that would be a sweet welcoming!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-26-2009, 09:54 PM | #416 |
Hmmm, I thought I had posted a before pic of the harness. I'll have to look on my computer at work tomorrow. But here is one of the reworked harness. And A pic of the problem with the rear end. grrrr.....
08-27-2009, 12:01 PM | #418 |
new/reworked harness looks great Bob. now which rearend is that?
08-27-2009, 12:06 PM | #419 |
It's the one out of the burb. For some reason, the tape measure I used to measure Fred's rearend has an error on it somewhere, because Fred's rear is wider than I thought. Damn cheap tape measures!
The are actually the same width, so I will just put the ring and pinion out of the burb rear end into Fred's.
08-27-2009, 12:15 PM | #420 |
cool, so you'll end up w/ the final gearing you wanted... 3.42's!
looks like your hitting it pretty hard trying to make that deadline i hate it when the numbers arent in the right order on those cheapo tapes!
08-27-2009, 12:21 PM | #421 |
It was at least an inch and a half shorter than all the others!
Yup, 3.42 is what I wanted all along. With the 275/60's, it will put me a 2250rpm at 78mph. Perfect!
08-27-2009, 01:55 PM | #422 |
yea, I thought all the rearend widths were in the same size catagory for those years.. now the 88-98 are wider in the trucks, but the spring perches are in different locations. something to consider tho
08-27-2009, 02:55 PM | #423 |
I ended up putting a '96 rearend in my truck. I had to cut off the perches and shock mounts and weld them back on (wish I had thought that through as I am now wanting to do a flip), but it is a 30 spline, with an Eaton Posi, and 3.42 gears so it accomplished all of my goals at the time.
08-27-2009, 03:11 PM | #424 |
Mid 90', eh? 5 lug.... do you remember how much difference, if any, in the width? U-joint the same?
08-27-2009, 03:59 PM | #425 |
if I am not mistaken it puts the rear width right in line with the front. the one I used on my 84 4wd evened them out
