Old 09-04-2014, 01:01 AM   #401
RockTonka
RockTonka's Avatar
Re: 1958 Apache 38 Dually Dump Project
Originally Posted by Advanced Design View Post
That came out really nice and the skim coat would maybe be a hint of some filler, if that.
Thanks AD, I was thinking about powder coating that piece with a silver vein black...probably just back up and paint it white like the rest.
Originally Posted by Kim57 View Post
I love the dimples you're doing. Looks real good.
Kim
Yea, I can't look at a flat piece of metal without thinking...damn, that needs some holes in it!
Originally Posted by _Ogre View Post
panel looks good rocktonka
Thanks Ogre!
I don't think these trucks came with radiator support rods??, but the core support had some angled holes at the upper, outer edge that started me thinking.
They really don't need the support, but I've always thought they looked kinda cool.
Sooo, I cut down and dimpled a piece of 2" angle for a firewall plate, welded a couple Al. tie rods together, and bolted them into those holes on the core support...straight bolts at the core support and heims at the firewall.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 09-04-2014, 09:53 AM   #402
Kim57
Kim57's Avatar
Those rods are a nice detail.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-04-2014, 12:32 PM   #403
_Ogre
_Ogre's Avatar
they do look good.
my 59 3800 1 ton has them, i thought they were standard on 1 ton and up.
all the core supports are the same and have the angled holes for the rods.
i believe the engine hump has dimples in the cab where they were drilled out when making a 1 ton
shop air compressor timer
Old 09-05-2014, 01:57 AM   #404
RockTonka
RockTonka's Avatar
Kim
Thanks...makes me want to run without a hood!
they do look good.
There ya go, I searched and googled trying to find pics or references to rad support rods...nothing. Thank for the insight!
My build thread
Old 09-05-2014, 11:19 AM   #405
_Ogre
_Ogre's Avatar
now i'm curious
look at your engine hump and see if yours is dimpled for the rods
iicr i filled the dimples on truk
Old 09-05-2014, 08:53 PM   #406
apache200
apache200's Avatar
My 58 1/2 ton has core support rods factory. I dont have any pics of them on the truck. It is tore apart
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 09-06-2014, 09:39 PM   #407
RockTonka
RockTonka's Avatar
now i'm curious
Sure nuff, Ogre! Our firewall is dimpled, but not drilled out.
Interesting, I wonder why some got em, and others didn't??
My build thread
Old 09-14-2014, 03:37 AM   #408
RockTonka
RockTonka's Avatar
Not getting much done, but still knocking out little things here and there...finished out the firewall/pedal/column mount support and fit in a engine oil cooler up front.
My build thread
Old 09-14-2014, 08:31 AM   #409
Advanced Design
Advanced Design's Avatar
The support looks really good! What dimension steel is that?
Advanced Design is offline   Reply With Quote
Old 09-14-2014, 11:32 AM   #410
Kim57
Kim57's Avatar
Very nice stuff.
Kim
My build thread
Old 09-14-2014, 01:33 PM   #411
RockTonka
RockTonka's Avatar
Thanks AD! We used some 1 1/2" x 1/8" angle for the support.
Very nice stuff.
Kim
Appreciate it Kim!!
My build thread
Old 09-14-2014, 02:06 PM   #412
Advanced Design
Thanks Rocktonka. Do you use dimple dies similar to these?
http://www.mittlerbros.com/mittler-b...mple-dies.html
Old 09-14-2014, 03:31 PM   #413
RockTonka
RockTonka's Avatar
Similar AD, but I use this set from Barbed Wire Offroad in TX...4140 material with a center hole so you can use a bolt instead of press if needed.
http://www.shop.barbedwireoffroad.co...3-4-2-8001.htm
Compare the pricing...bang for the buck, it's hard to beat!
My build thread
Old 09-14-2014, 06:23 PM   #414
Advanced Design
Thanks for the link RockTonka! Yet more tools I want....good value for their set.
Old 09-15-2014, 12:06 AM   #415
RockTonka
RockTonka's Avatar
We were kinda struggling with where to dump the exhaust and came up with this approach.
Cut up a section of 4" tubing, slash cut the front and capped off on the back, welded some brackets to them that bolt up high on the rear of the box.
We'll run the exhaust between the frame and box into holes cut at the rear of the "tips".
My build thread
Old 09-15-2014, 10:09 AM   #416
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 09-17-2014, 03:01 AM   #417
RockTonka
RockTonka's Avatar
Thanks again Kim!
My boy and I both like a tach up on the dash but the matching one to our gauges only came in a 3 1/8" OD. There's only one dash mount cup made for that size tach and it's plastic and expensive.
Soooo, we had a local exhaust shop stretch a section of 3" tubing out to 3 1/8" ID...nice, slight, press fit for the tach.
We pie cut the back side of the tubing, hammered it into shape over a ball hitch, welded it up, and smoothed it a bit.
My build thread
Old 09-17-2014, 03:15 AM   #418
RockTonka
RockTonka's Avatar
Our original plan was to smooth all the welds and make a nice, perfect, little, round, end to the cup (it's going to be powder coated a black silver vein...all the interior pieces we're making will be), but then it would look like we just bought it somewhere.
We decided to leave the seam welds exposed so that you knew it was homemade. If I would have figured that part out initially, I would have laid prettier beads!
Anyway, made a simple mount for the cup and bolted it to the top of the dash.
My build thread
Old 09-17-2014, 06:42 AM   #419
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Outstanding!
ChuckDriver is offline   Reply With Quote
Old 09-17-2014, 07:13 AM   #420
6BT 56
6BT 56's Avatar
Man that big block sure likes to rev ,for a work truck that is. Lol. Looking good . As usual.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 09-17-2014, 08:38 AM   #421
Kim57
Kim57's Avatar
That's great looking.
Kim
My build thread
Old 09-17-2014, 07:29 PM   #422
Advanced Design
Major cool! Very well done! Great idea too...love your welds.
Old 09-18-2014, 01:49 AM   #423
RockTonka
RockTonka's Avatar
Originally Posted by ChuckDriver View Post
Outstanding!
Thanks CD!
Thanks 6BT! We're gonna try and keep it from getting that rapped out!
Kim
! Thanks Kim!
Appreciate that AD!!
My build thread
Old 09-18-2014, 09:24 AM   #424
Jeff La
You never cease to amaze me with this truck.
Jeff La is offline   Reply With Quote
Old 10-01-2014, 01:46 AM   #425
RockTonka
RockTonka's Avatar
Thanks Jeff!
Not much to add, pulled the bumper to add some traction details for when we've got to climb up and check the oil or something
My build thread
