#401 |
Re: No Limit's "K-10"
Nice........
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
#402 |
6>8 Plugless........
![]() Join Date: Sep 2007
This is going to be sweet!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#403 |
![]() Join Date: Jul 2010
Yes, the dash is wierd. Two big guages, and three warning lights front and center. The rest of the guages will be in the center console. The steering column parts came fromFlaming River and Speedway. It lays in WAY different than a nomal C-10.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 02-27-2012 at 10:11 PM. |
#404 |
1. for the floor mount/lower column bearing, i fit a small peice of tube with a 3/4" I.D. spherical bearing. this solved two problems at once. 2. a shot of the wheel and tire in the reshaped fender. this is at ride height. 3. in the passenger side foot well there was enough room for the ECU.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 02-27-2012 at 10:15 PM. |
#405 |
1. looking at the passenger side footwell with the cover in place. yes, I have a small gap to fill, that will be a lot easier when the mock up motor is out. 2. from the front you can see the two bars I added to brace the front inner fenders. they're light, 1" x .065" tube 3. remember when I said that Owen was going crazy on the inside of the hood?
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 02-27-2012 at 10:18 PM. |
#406 |
1. This is in the back of the truck. I was all proud of the inlet/outlet tubing, - then i talked to Meziere about a pump, and now I have to do it over.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 02-27-2012 at 10:22 PM. |
#407 |
FINALLY!!! It's really sitting on skates, but it is at ride height. It looks totallt different down on the ground. with the seats in, getting in is like getting in a 'vette. you step down and in. I was worried about some of the rear weight being too high, like the tank and rad., but not any more. The proportions look good. we set on a stock winshield for a look, looks like an easy 2" cut. The front roll pan is from Mar-K. I think I need to make a splitter. The bottom of the rockers is at 5 1/2" off the ground, even with all of the lower tubes. Ground clearance is good. OK, I'll admit it, this thing looks a lot more bad ass than I thought it would.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 02-27-2012 at 10:30 PM. |
#408 |
Wow!!!!!!!!!!!!!!!!!!!!!!!!!!
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
#409 |
Oh man, that is freaking awesome! Great work Rob and crew! One quick question for you. Are you going to finish weld all the areas that have multiple tack welds, or is this another way to save weight? Nice work, I love the stance ot the truck!
#410 |
OH SHHHHHHHHHHHHHHHHHHHHHHHHHHHHH it, THAT IS SO SICK!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
#411 |
![]() Join Date: Aug 2007
Scotts72C10 |
#412 |
![]() Join Date: Mar 2010
Picaso......sweet vision and follow thru.
#413 |
looks good Rob
Justin |
#414 |
Hey man, how's yours comin? You need to come down to AMP on March 29th for the So Cal Challenge. let me know if you want to get involved. www.socalchallenge.com
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#415 |
![]() Join Date: Apr 2005
Yep.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#416 |
Man this is crazy the proportions of the chop are sik!!!
Posted via Mobile Device |
#417 |
67cheby
![]() Join Date: Sep 2008
This is what nastruck should look like !! In freakin believable !!
#418 |
![]() Join Date: Mar 2011
Killer.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#419 |
![]() Join Date: Dec 2007
I can't believe how good the wide 5's look! Stunning.
#420 |
Fun Stuff
![]() Join Date: Jan 2010
Looks awesome, good job.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
#421 |
amazing
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#422 |
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#423 |
![]() Join Date: Dec 2006
Wow truck looks awesome
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#424 |
GEARHEAD
Looks great all together. Maybe I just found plans for that other blazer project I have sitting at the farm. Splicing a cab roof and back wall into it seems doable. Then take the info you passed on in the "make it handle" and "no limit C-10" threads and I've got a rockstar trazer.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#425 |
Thanks for the support. Now, as I start to take it apart one more time, we go through and finish each section and part. We won't be fully welding everything, all of the tubing and intersections will be welded, but a lot of the sheet metal will stay tacked at the seams, it's plenty stromg, and doesn't rattle. I went through the books last night, and money wise we're just under 8k - not counting the wheels (I have about 800 in the wheels so far) The biggest $$ spent was the rear axle. The shocker was the hour count, at a bit over 400 hrs so far. As we close up on the fab work and go to paint and powder the hour count will slow up a bit, but the $$ will start to flow. We have about a month to hit our goal, and we're behind the ball, I hope we make it. It may be a week before there are more picts.
