Old 10-19-2015, 12:02 AM   #401
66ChevyMax
66ChevyMax's Avatar
Re: Mesquite 1966 C10 - LS3 W/Air Ride
Took her for a little test drive yesterday. Motor is mean, clutch is smooth, tranny shifts like a dream, air ride is very nice.
Had a front wheel that wasn't set on the hub, you can see the passenger side wiggle when I pull back in the driveway. Did not get above 2nd gear for this first ride so just barley noticed the wobble.
https://youtu.be/iCYLlEY2438
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 10-19-2015, 08:18 AM   #402
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Always nice to see them run.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 10-19-2015, 11:08 PM   #403
66ChevyMax
66ChevyMax's Avatar
Got a brake question, I have bled the brakes starting with closest, depress pedal and open bleed valve and fluid shoots out with plenty of force.
Pedal never tightens up, brakes only work when almost to the floor. No leaks, I'm thinking master is bad? Is there something with the master I can check or am I SOL?
Thanks,
Craig
Old 10-19-2015, 11:08 PM   #404
likaroc13
Rollin' Old Skool
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-20-2015, 12:34 AM   #405
Figuarus
Figuarus's Avatar
I've always been told that you're supposed to start with the longest line first. usually you do passenger side rear, driver side rear, passenger side front and then driver side front. if you haven't already double check to make sure you don't have air in the master cylinder. if it wasn't bench bled properly, you'll have air in there that won't escape. once you have that figured out, bleed the lines and the order outlined above. let us know what happens
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-21-2015, 10:39 PM   #406
66ChevyMax
66ChevyMax's Avatar
move the hole down 3/4", extended push rod about 1/4", SUCCESS
Craig
Old 10-22-2015, 09:26 AM   #407
Dubnova
Good for you! It's great to see them run. I used the same engine in my build and I am close to a test drive as well. I can't wait much longer it's kinda like Christmas. Good work and nice job.
Dubnova is offline   Reply With Quote
Old 10-22-2015, 09:59 AM   #408
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looking good man !!
How does the brake assist feel with that small booster and the LS ?
Most of our customers complain about crappy brakes.
Small booster and low vacuum from the LS add to that.
Needless to say, we have been doing a lot of HydroBoost swaps lately ...
Again, great work !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-22-2015, 11:49 AM   #409
66ChevyMax
66ChevyMax's Avatar
This is my first engine over 400hp and it's all I need, this will be a fun truck for sure. That first test drive is exciting and nerve racking at the same time, took two beers after to bring my nerves down
Thanks for the comments!
Craig
Old 10-22-2015, 11:51 AM   #410
66ChevyMax
66ChevyMax's Avatar
It's was raining like crazy yesterday so I did not get to drive it. I will let you know, I'm not expecting a huge boost but should be 10x's better than the old drums.
Originally Posted by ChiefRocka View Post
Looking good man !!
Craig
Old 10-25-2015, 11:51 PM   #411
66ChevyMax
66ChevyMax's Avatar
Have taken her on 5 or 6 test drives now, get a little braver with each one.
Engine really come to life at 5,000rpms
Got the Dakota Digital Gauge Speedometer adjusted.
Test mounted the doors, these after market body parts are going to require more attention than they should.
Craig
Old 10-25-2015, 11:53 PM   #412
66ChevyMax
66ChevyMax's Avatar
This is what the Cab looks like during a test drive
Craig
Old 10-29-2015, 10:37 PM   #413
66ChevyMax
66ChevyMax's Avatar
Got the Electric E-Brake installed tonight.
Had a few more test drives and no issues so far
Craig
Old 10-29-2015, 11:09 PM   #414
66ChevyMax
66ChevyMax's Avatar
Another test drive vid:
Craig
Old 10-31-2015, 01:44 PM   #415
chad64chevy
chad64chevy's Avatar
quick question about your e-stop! how did you run the cables from the rear end to the box? some extra pics would help thanks! I'm thinking of buying the one with the key flop, in the next couple weeks! truck looks great!!
chad64chevy is offline   Reply With Quote
Old 10-31-2015, 11:18 PM   #416
66ChevyMax
66ChevyMax's Avatar
Right now I just have the drivers side set up, I think that will be plenty but haven't tested it yet.
Craig
Old 11-01-2015, 08:37 PM   #417
66ChevyMax
66ChevyMax's Avatar
Came across this shifter last week, moves the stick about 2" closer which is nice.
Craig
Old 11-01-2015, 08:40 PM   #418
66ChevyMax
66ChevyMax's Avatar
Got everything fitted, some small minor stuff left but I'm happy with it!
Craig
Old 11-01-2015, 10:00 PM   #419
likaroc13
Rollin' Old Skool
Lookin' good!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 11-01-2015, 11:55 PM   #420
66ChevyMax
66ChevyMax's Avatar
Thanks Phillip, need to test fit the bed, widen the wheel tubs, do some firewall repair and cab repair then send her to the painter.
Long time coming, I'm very excited to be this close!
Lookin' good!
Craig
Old 11-02-2015, 01:46 AM   #421
Bomp
Bomp's Avatar
Truck is really moving along, sounds healthy too.
Bomp is offline   Reply With Quote
Old 11-04-2015, 03:38 PM   #422
66ChevyMax
66ChevyMax's Avatar
Thanks Bomp, she's fun to drive!
Craig
Old 11-04-2015, 05:16 PM   #423
greg65
greg65's Avatar
subscribed
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 11-05-2015, 12:20 AM   #424
tune_1
Looking good, glad to see the work that you have done.
Dwight
tune_1 is offline   Reply With Quote
Old 11-05-2015, 12:30 AM   #425
66ChevyMax
66ChevyMax's Avatar
1,462 day later, I took over 2 years off
November 3, 2011
November 4, 2015
Craig
