02-09-2013, 11:34 AM | #401 |
Re: 1972 Chevy p/u NewType Build
rocker arm was ruined as you can see and the push rod was bent. Stud looks fine I havent gone futher than the valve cover being off I drive it daily and can't afford to tear into the motor so I'm going to replace the parts I have that are damaged that I can see and try and tighten these rockers as best as I can. I'm no genius when it comes to motors though
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
02-09-2013, 11:57 AM | #402 |
C/10 junkie
I imagine it was running rough and ticking? Should be able to replace those parts and hopefully be good.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
02-09-2013, 12:08 PM | #403 |
It doesn't look severe so far just tryin to find a rocker arm in town this morning my pushrod is downtown if I want it at oreillys and my rocker arm is in Ceres. Oh yeah no transportation perfect scenario right? Checking napa three blocks from me by walking right now
02-09-2013, 12:13 PM | #404 |
Sorry Dylan. Saw this on fb...are you thinking what I think you are thinking? LSx swap?
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
02-09-2013, 12:36 PM | #405 |
All good walking to the lazy gfs house to use her car. And not an LSX just a simple ls3 that looks carbureted. I don't have Leon money
02-09-2013, 06:00 PM | #406 |
Finally got some parts gotta get this thing together before 4 or so I hope whats an easy way to do these valves quick?
02-09-2013, 06:39 PM | #407 |
C/10 junkie
Do you need to adjust them all or just the one?
02-09-2013, 07:05 PM | #408 |
All just for safe measure postponed till tmrw I just have way too little knowledge to ruin this motor
02-09-2013, 11:26 PM | #409 |
Well first let me start by saying that push rods don't just do that. There has got to be a reason. If you remember my build, I had the exact same issue at the Brothers show and shine. Mine was the exhaust valve so the fuel would get in but could not get out and was back firing through the carb. Yours must be on the intake side and no fuel can get into that cylinder. It might run a little rough on 7 cylinders but the big issue is WHY?
Mine was a flat cam shaft that could not maintain valve spring pressure. The shreaded lobes were distributed throughout my entire engine and it had to be rebuilt. If you do not want to tear it apart then you will need to get a long rod and insert it through the push rod hole and on top of the lifter. Then rotate the engine once and measure the lift. You will need to know the specs of your cam to know how much it should be lifting. Remember that this is going to only be an approximation because the hydraulic lifters change size when there is oil pressure. Mine were almost round so there was very little lift if any. Also check your oil for metal shavings with a magnet. Either way a bent rod is evidence of a far worse issue. Posted via Mobile Device
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
02-10-2013, 12:07 AM | #410 |
C/10 junkie
You bring up a good point Mike
02-10-2013, 01:04 AM | #411 |
very valid points Mike and very helpful insight my current motor tuner and I deduced that the rocker arm simply failed and the way it fell led to bend the push rod.
I went ahead and made sure I found all metal chippings on the top of the head and double checked both sides adjustment looks like I'll need to have him do it one more time it puffin a lil smoke right now but it could be just cold out tonight. got the new rocker on and had him adjust it correctly since we had to replace cylinder 2's rocker arm's completely since they were loose or fell like this one did. Went ahead and clean her all up put her together and ran her around a little bit tonight I may do a longer run tomorrow sometime and use the sea foam treatment in the gas tank see if she'll run a tick better (I know it doesnt have anything to do with the valves but it was a treatment i wanted to try ) So final conclusion she runs and I hate that she was even down for 24 hours
02-10-2013, 10:05 AM | #412 |
C/10 junkie
Try being without for 3 days while the tranny shop drives her by your window at work
Hopefully that all that was the matter and she is good to go.
02-10-2013, 11:32 AM | #413 | |
Well lets hope that that is all it was, hate to see an engine fail because of this. Get a mag plug for your oil drain plug. .
02-10-2013, 01:52 PM | #414 | |
And what exactly is a mag plug? Never heard that term before. And Shawn that musta been so hard knowing youre getting a B.A. Tranny installed :P Posted via Mobile Device
02-11-2013, 03:34 PM | #415 |
Well it's first show of the year week and it starts early so Thursday is my 2013 biggest show schedule I've done so far tour lol. So the Sacramento Autorama is my destination this weekend via invite by the great group over at Arc Audio can't thank them enough for the support of me and this truck. I'm no showstopper yet but I am very proud to have this truck among the beautiful cara that I will be joining this weekend so I'm pretty darn stoked about that. So now it's checklist time to be prepared.
Motor: Decent no major oil leaks has small lower rad hose leak though shouldn't be too bad Tranny: Solid but messy Rear end: Solid Suspension: Has that Chevy lean but oh we'll bags in future maybe Paint: Needs a good hand polish this week before the show will do that Wednesday night Wheels: ^^ Same except Tuesday Interior: Vaccum and shine Wednesday night Needs a display rug: to go underneath the truck at show. Door panel inserts: Should be dry and installed today with newly polished trim ring/pics tonight Purchasing a bunch of microfiber cloths to use for drying and cleaning Purchasing more cleaners for truck Polish the front window trim to restore its shine (original and beat to hell) Tighten any loose bolts in bed Reglue trim rings on deluxe marker lights (repop junk) Waiting for inner grill to be painted so I can re install and finish the front end Waiting for tail gate to hopefully at least have bodywork done and white sealer applied possibly red to match May add others as I go but there's the big ticket items so far that need to be done by Wednesday night gotta love crunch time Posted via Mobile Device
02-12-2013, 12:24 AM | #416 |
Well as we speak my inner grille is drying from the silver being laid down hoping to have it tmrw night for assembly.
Also the inside of the tailgate is getting a little love on the ding of a trailer that backed into my lowered tailgate at the time so hoping shell be nice and straight. Primer to be laid tonight. and hopefully some sealer tmrw night if all work out well. then assembly either Wednesday night or early Thursday morning on the way to the show nailbitter I know but I have faith in my father and he always pulls through for me so I gotta love him for that. Door panel inserts turned out like poopy so I'm respraying them one last time before I give up on them to look good. Grabbed up some metal polish and new bulbs for my dash going to run 194's since they run MUCH brighter than my tired old 168's and they WON'T burn up anything and just sitting here polishing away now getting really excited
02-12-2013, 03:16 AM | #417 |
Rephrase that about the bulbs in my dash I'll be running 168's instead of 194's got em mixed up a bit..
Good news from my father the tailgate got it's last skim coat and is in primer tonight with good progress he should have it in white sealer by tmrw at lunch time. He also sprayed down the silver mettalic to my inner grille that I'll pick up tmrw to finish my grille install when I drop off the Red centari for a hopeful last minute spray that night. We'll see how it all goes tomorrow will be very busy it seems.
02-12-2013, 07:55 AM | #418 |
C/10 junkie
With all this stuff going on, we need some pics The engine still running ok?
02-12-2013, 11:05 AM | #419 |
Most of what's going on where I'm at isn't pic worthy shoo this may be my first page without pictures but I should be able to get some paint progress pictures tonight when I grab up my inner grille.
Motor is fine so far not tryin to stress it any till after the weekend Posted via Mobile Device
02-12-2013, 11:53 AM | #420 |
C/10 junkie
Thats good news
02-12-2013, 12:14 PM | #421 |
Proprietor of Dale's Corner
So I gather you'll be displaying in the Arc Audio Building? If so I'll be looking for your truck
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
02-12-2013, 12:30 PM | #422 |
A mag plug is a magnetic oil plug, if there was damaged parts or shavings that got into your oil the magnet will hold onto them until the next oil change.
Mike
02-12-2013, 02:07 PM | #423 | |
And Ol Blue absolutely ill be there Thursday at noon for a couple hours and then possibly Saturday unsure yet but for sure ill be there Sunday all day the Arc Audio booth will be packed with some great looking and sounding cars Posted via Mobile Device
02-12-2013, 02:21 PM | #424 |
Cool, my buddies grandson always is in there with Arc you're going to luv it. I'll be thru there not sure what day but I'll be lookin' for your truck
02-12-2013, 02:24 PM | #425 |
Who's your buddies grandson I've known the group over there for the past three years now maybe I've seen him
Tags |
1972 chevy c10, cheyenne super, rebuild, restoration, showtruck |
