Old 07-06-2013, 07:37 PM   #401
shadow1967
shadow1967's Avatar
Re: 1959 Fleetside REBORN
Originally Posted by ChuckDriver View Post
WOW, you've been busy! Nice work!!
Thanks Chuck.
Well we got the shifter to work, 4L60 to work on a 6L90 transmission. Not hard, just a lot of adjustments and making your own bracket. Added 2 pieces of 1/8" plate to the bottom of the tunnel to stiffen the tunnel from flexing.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 07-07-2013, 08:57 AM   #402
wsurf4me
wsurf4me's Avatar
Looks great, that dash is awesome.
58 Fleetside
71 Cheyenne
wsurf4me is offline   Reply With Quote
Old 07-07-2013, 11:55 AM   #403
shadow1967
shadow1967's Avatar
Thanks Wsurf4me.
Old 07-07-2013, 01:49 PM   #404
apache200
apache200's Avatar
Shadow where did you cut your dash down to make it fit in your cab? I have the same dash I want to install in my 58 project. Thanks for any info Tony
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 07-07-2013, 03:16 PM   #405
shadow1967
shadow1967's Avatar
Tony, I started the dash mods on page 4. You can start there and if you have questions still. Please ask, Mike. There is also a link on page 4 for ChuckDrivers 1957 he put in the impala dash also.
Old 07-11-2013, 08:08 PM   #406
shadow1967
shadow1967's Avatar
We started the steering linkage today and we need to move the brake pedal 2" to the left. Has anyone bent there Master cylinder brake lever before? If so, HOW?
Old 07-15-2013, 07:53 PM   #407
shadow1967
shadow1967's Avatar
Small UPDATE 2 things done this weekend.......steering linkage and trans cable unkinked, slides smoooooth now. Had to do a few adjustments, don't mind all the holes. Needs a trim, a cut, a weld and a grind.
Old 07-15-2013, 10:13 PM   #408
Kim57
Kim57's Avatar
That came out nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-21-2013, 12:18 PM   #409
shadow1967
shadow1967's Avatar
Originally Posted by Kim57 View Post
That came out nice.
Kim
Thanks Kim57.
I finished and cleaned up the trans cable mount. Started hanging sheet metal, cut fender wells to clear A arms.
Old 07-31-2013, 07:11 PM   #410
shadow1967
shadow1967's Avatar
Well we started Hanging sheet metal, the wire harness placement and started the cutting of the doors.
Old 07-31-2013, 07:13 PM   #411
shadow1967
shadow1967's Avatar
Last one...
Old 07-31-2013, 07:33 PM   #412
Kabwe
Certified Car Nut
Kabwe's Avatar
Everything is looking great. Nice work
Kabwe is offline   Reply With Quote
Old 07-31-2013, 07:45 PM   #413
wsurf4me
wsurf4me's Avatar
Any special reason for putting the fuse panel in the rear corner of the cab? I don't think I've seen anyone put it there before.
58 Fleetside
71 Cheyenne
Old 07-31-2013, 07:46 PM   #414
waybad
waybad's Avatar
me likey
waybad is offline   Reply With Quote
Old 07-31-2013, 07:56 PM   #415
shadow1967
shadow1967's Avatar
Just wanted to make room for the engine computer. There are 2 big bundles of wires and large connectors and a small fuse panel with relays.
Old 08-01-2013, 01:14 AM   #416
Kim57
Kim57's Avatar
This is going to look real slick when done.
Kim
My build thread
Old 08-02-2013, 09:03 PM   #417
shadow1967
shadow1967's Avatar
Originally Posted by waybad View Post
me likey
Kim
Thanks guys.
Here are some shots of the reassembly.
Old 08-03-2013, 02:13 AM   #418
Kim57
Kim57's Avatar
Looks nice.
Kim
My build thread
Old 08-03-2013, 09:19 AM   #419
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Sweet!
ChuckDriver is offline   Reply With Quote
Old 08-03-2013, 07:22 PM   #420
shadow1967
shadow1967's Avatar
Looks nice.
Kim
Sweet!
Thanks guys!
We put the fuse panel for light, mirrors, doors and accessories in the cab corner. The engine computer, engine harness and engine fuse box with relays under the dash, with gauges from the OBD2 port. That was enough stuff under the dash.
Old 08-04-2013, 10:01 AM   #421
_Ogre
_Ogre's Avatar
the stretch is coming along nicely
shop air compressor timer
Old 08-05-2013, 06:25 PM   #422
shadow1967
shadow1967's Avatar
We started Saturday off hanging the driver door, getting the gap at the leading edge. Also a lot of measurements. After I got the nerve to cut on 2 good doors, no rot at the bottom of doors. First door cut, then the second. Then came two hours of tap, measure, grind and repeat.
Old 08-05-2013, 06:33 PM   #423
shadow1967
shadow1967's Avatar
After bunch for Dad and a Bike ride for me. We continued the tap, measure, grind and repeat. Till we got the fit dad wanted. Then he tacked it.
Old 08-05-2013, 06:37 PM   #424
shadow1967
shadow1967's Avatar
And by late Sunday night we had a set of doors.
Old 08-11-2013, 09:27 PM   #425
shadow1967
shadow1967's Avatar
Well this weekend was loads of fun. Wires and wires everywhere.
