Old 11-20-2012, 07:07 PM   #401
63split
63split's Avatar
Re: Dutch 1955 build
Originally Posted by OrrieG View Post
That interior is looking good. Most people will glance at it and assume all the work you did behind the seats is factory unless they know these trucks.
thanks for the compliment
have been working on some small things
installed the gas pedal and cable, run the battery cable's
and put sound deadener on floor an roof still got some places to do.
and got the door window switch in place.
63split is offline   Reply With Quote
Old 11-20-2012, 07:14 PM   #402
_Ogre
_Ogre's Avatar
great progress on your truck
putting the windshield in is easy
putting the trim in the rubber on the windshield is a bugger
looks real good
shop air compressor timer
Old 11-20-2012, 09:14 PM   #403
Kim57
Kim57's Avatar
Looking real sharp.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-20-2012, 11:06 PM   #404
oldman3
oldman3's Avatar
Sweet....Jim
oldman3 is offline   Reply With Quote
Old 11-22-2012, 05:54 PM   #405
63split
63split's Avatar
got some more painted parts ready for assembly
put in the steering column and steering wheel
and yesterday i got a call the wheels arrived and where ready for pickup
so we picked them up today and couldnt wait to put them on
when ordering the wheels i figured tire availabillity and size choice would not be a big issue
but found out we are limited to one size for the rear wheels (335/30 r18)
front's are easier (225/45 r18)
Old 11-22-2012, 05:59 PM   #406
YahamaR1
YahamaR1's Avatar
Looking very good... Nice wheels.. How wide are your frontwheels,?
Hoeveel J is dat?
YahamaR1 is offline   Reply With Quote
Old 11-22-2012, 06:05 PM   #407
99-LS1-SS
99-LS1-SS's Avatar
This is such a cool looking build! You are a great fabricator. I can't wait to see what this thing looks like finished.
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 11-22-2012, 06:15 PM   #408
63split
63split's Avatar
Hoeveel J is dat?
18x8 with a 4.5 back space (zerro offset) here a nice tool to determine tire fit
http://www.rimsntires.com/specs.jsp
Old 11-23-2012, 02:06 AM   #409
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
Old 11-23-2012, 11:24 AM   #410
Wheelie
Wheels are awesome! Wish my garage was that clean.
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 11-23-2012, 12:44 PM   #411
63split
63split's Avatar
well its standing temporary on this ''clean'' side due to the paint work and sanding dust in the workshop, when thats done it will move back there
Old 11-24-2012, 04:49 PM   #412
63split
63split's Avatar
i did some little things today, like installing the battery tray, battery and charger cable with a plug under the cab behind the cab corner
and put on the cover and then took this picture
also put on the freshly painter sun visor
and here a shiny trans cover its a shame to cover it up with carpet
Old 11-24-2012, 05:09 PM   #413
Kim57
Kim57's Avatar
Very nice fab work.
Kim
My build thread
Old 11-24-2012, 05:13 PM   #414
63split
63split's Avatar
Originally Posted by Kim57 View Post
Very nice fab work.
Kim
uhh ? its more assembly work now Thanks Kim.
Sander,
Old 11-25-2012, 01:16 AM   #415
oldman3
oldman3's Avatar
Looking really good...Jim
Old 11-25-2012, 03:40 PM   #416
63split
63split's Avatar
finished the brake lines and installed the brake pedal and master cill. and booster
also got the rear window in but still need to put the lock bead in
Old 11-25-2012, 07:05 PM   #417
Kim57
Kim57's Avatar
Looks good.
I see you have the residual pressure valves in your brake lines.
I don't think you need them because your master cylinder is higher than your wheel cylinders. I thought they were only used to keep the fluid from flowing back into the master cylinder when it is lower than the wheel cylinders.
Kim
My build thread
Old 11-26-2012, 01:09 PM   #418
63split
63split's Avatar
Looks good.
Kim
your right Kim the should not be needed, but the residual valves were in the set i had so i figured i would just put them in line
Old 11-27-2012, 06:11 PM   #419
made2drag
made2drag's Avatar
sweet build!
made2drag is offline   Reply With Quote
Old 11-27-2012, 08:18 PM   #420
ChevroletWT
ChevroletWT's Avatar
Is that gas pedal setup custom fabricated?? I really wanted to use a stock style pedal linkage that ran into the floor but could not find a way to make it work with a cable like you have!
If it was purchased, may I ask where you got it?
ChevroletWT is offline   Reply With Quote
Old 11-28-2012, 06:13 PM   #421
63split
63split's Avatar
i was just looking at your build this pedal is from lokar just like your cable setup your using
Sander,
Old 11-28-2012, 06:24 PM   #422
63split
63split's Avatar
have been fighting with rear window getting lockbead in place
and i have won !
and then done an easy job by putting the rearview mirror in place
and put in the steering column for the final time.............
because i had damaged the paint when trying to determine the correct steering wheel height.
Old 11-28-2012, 06:39 PM   #423
ChevroletWT
Sander,
Thank you! I didn't realize they made pedals like that. I just ordered one for my build!
Old 11-29-2012, 02:42 PM   #424
'55Chevylover
'55Chevylover's Avatar
I just started following your build. I must say that I am very impressed with the work you have done on this truck. I wish I would have seen this thread before I started on my truck. But, mine is almost finished and I am pretty pleased with the way it turned out. I really like everything that you have done. This is going to be one very impressive truck when it rolls out for the final showing. I just love it.
God Bless America
'55 Shortbed Stepside
'79 C10
2010 Malibu
Not too proud of: 2011 Nissan Altima, (Not American made)
'55Chevylover is offline   Reply With Quote
Old 11-29-2012, 05:59 PM   #425
63split
63split's Avatar
thank you Bill
