Old 07-26-2014, 10:31 PM   #401
66Submarine
66Submarine's Avatar
Re: Project two tone.
Don't see the LPG pistons listed by Clifford; their prices seemed scary enough to make me plug the old ones back in, anyhow!
A '64 wouldn't have had the blue head gasket from the factory. Might have just had the head off before, but old rebuilds are always suspect this far in the future; 85,500 might actually be 185,500 with a little freshening up done at some point. Should be a super nice truck/engine if it really only has 85,500 on it since new, though!
I'm sure you'll be able to make something work, but it's always a very good idea to wait and disassemble/inspect/measure before buying stuff. My 292 had ate the cam (I think it was because of oil dilution), but it was a recent .030 rebuild with the crosshatching still visible; just a new set of moly rings + quick touch-up with a hone and it should be good. No sense paying someone to bore it out and buying new pistons for fun!
You can also save a lot of money in other ways by doing that; the 250 in my truck right now is a pretty recent rebuild (no oil consumption, good leakdown numbers, etc), but the oil pressure is a little lower than what I'd like to see; probably has some wear on the crank and would need to be ground undersized to be "right". But I got another "scrap" 250 full of water for free, and that one had a beautiful standard sized crank in it! A new set of rings/bearings along with the crank out of the scrap engine, and it should be great engine again--and for almost no money.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-26-2014, 11:36 PM   #402
TJ's Chevy
TJ's Chevy's Avatar
Well...compression was around 120 pounds in all cylinders...so I think it has 85,500 on it...if it was to have 185,500 and have that same compression I'd say that was one pampered engine! LOL! If it was bored .030 over then all I have to do is have it bored .010. LOL! That'd be a waist....well..i'll figure outta way to measure the cylinders. One of those blocks outta work anyhow! lol!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-27-2014, 12:51 AM   #403
66Submarine
I actually have some really tired/borderline "WTF?!" stuff that makes really decent numbers with a comp. tester. "Tighter" engines will supposedly make the pressure with less revolutions/cycles or whatever, but I don't think it's really a good way to determine engine condition beyond a very basic "nothing terminally FUBAR"; the leakdown test is what you want to check for ring condition/wear.
I don't think it's at all unlikely that it might have 185,500 if it's a little tired--especially if the head has been off and it's been worked on or potentially rebuilt. The 250 in one of my trucks has several hundred thousand on the clock with bad cam lobes, smoking, extreme oil consumption, rolling down slight hills in first gear, etc., and it still made nearly the same numbers as my nice 250 using the compression tester; it also somehow still lights right up and runs great, despite all that. The leakdown test didn't lie, though; something like 20% for the good one, and IIRC something insane like 65-80% for the tired one (did I mention it's somewhat tired? ).
The problem with it already being previously rebuilt at .030 is that there's a good chance it won't clean up at 0.040 and you will need to bore it out more than that to clean the cylinders up. Not a big deal if you have another block that will go 0.040 and clean up, but it's just unnecessary potential BS IMO. I don't really see any potential benefit to ordering parts before it's even apart.
FWIW, I'll attach a picture of the 98,500 mile 307 in the '68 Impala I just bought. It's borderline unusually clean (besides the milky oil from a botched intake install), but it illustrates that 98,500 ain't a whole lot for close to five decades. This engine seems to have great compression (tight), lights right up and runs like brand new, is super quiet (no lifter noise, etc), doesn't have a bunch of blowby, and seems to have good leakdown numbers like it should. The car is also pretty much like new mechanically, with no play in the door hinges, no leaky pinion seal, gouged up/replaced brake drums, etc. The 350 with something like 100,000 on it in my father's truck is also still very nice. I think most people really underestimate how many miles the odometer in their truck has really counted off in the years past...
Old 08-02-2014, 06:33 PM   #404
TJ's Chevy
TJ's Chevy's Avatar
Washed the truck today after moving some crap...also installed this...
Old 08-04-2014, 10:11 PM   #405
Dean'smeanmachine
Dean'smeanmachine's Avatar
nice sticker!
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 08-04-2014, 10:51 PM   #406
Ta2Don
Ta2Don's Avatar
X2...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 08-15-2014, 09:55 PM   #407
TJ's Chevy
TJ's Chevy's Avatar
Alright ya'all! This is the LAST update on the engine until its done..which should be sometime in the next few months or so...waiting on my machinist. But..seeing the pistons and these should give you a perrty good idea of what I have in store for this engine. Anyway...so NO updates on it till its complete...there'll be small updates on the truck..but nothing on the engine...that's gonna be the big surprise. Enjoy!!!
Old 08-15-2014, 10:05 PM   #408
Dean'smeanmachine
nice! your the 6 banger man
Dean
in God we Trust
Old 08-15-2014, 10:23 PM   #409
Ta2Don
Ta2Don's Avatar
Too Cool!!!
DON
Proverbs 27:17
Old 08-16-2014, 06:01 AM   #410
Very Nice!
Old 08-16-2014, 08:54 AM   #411
1963c-10
1963c-10's Avatar
Side plates look great tj
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-16-2014, 09:37 AM   #412
TJ's Chevy
TJ's Chevy's Avatar
LOL! Thanks bud!
Originally Posted by Ta2Don View Post
Too Cool!!!
Thanks brotha!
Very Nice!
Thanks!
Thanks man, getting excited..slowly but surely.
Old 08-20-2014, 11:56 PM   #413
TJ's Chevy
TJ's Chevy's Avatar
Just letting ya'all know I went through a name change.
Old 08-21-2014, 09:03 AM   #414
jcramsey
jcramsey's Avatar
I like those side covers! Cant wait to see the engine when it's done!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 08-21-2014, 09:13 AM   #415
1963c-10
1963c-10's Avatar
You have to hate the wait.....I know I did. Looking forward to pics of the completed engine.
Old 08-21-2014, 04:58 PM   #416
rusty76
rusty76's Avatar
You know I thought something looked different....
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-23-2014, 04:54 PM   #417
TJ's Chevy
TJ's Chevy's Avatar
Thank bud!!! I'm like cray excited to! lol!
I'm looking forward to THE completed engine. lol
lol! Got ya.
Old 09-11-2014, 05:31 PM   #418
TJ's Chevy
TJ's Chevy's Avatar
WOOOOHOOO!!!! My NOS unity spotlight came today!!!! Brand spankin new NOS beauty!!! Can't wait for my mounting bracket kit to arrive!!!
Old 09-11-2014, 05:53 PM   #419
Very Nice!
Old 09-11-2014, 09:42 PM   #420
TJ's Chevy
TJ's Chevy's Avatar
Very Nice!
Thanks!
Old 09-12-2014, 08:18 AM   #421
1963c-10
1963c-10's Avatar
Nice!!!!
Old 09-12-2014, 09:01 AM   #422
Ta2Don
Ta2Don's Avatar
Finally checking in Brotha!
Spotlight is Spot On!!!! All joking aside, Very Nice!!!
How come it's not installed yet?
DON
Proverbs 27:17
Old 09-12-2014, 12:44 PM   #423
Dean'smeanmachine
im digging the spot light
Dean
in God we Trust
Old 09-12-2014, 12:58 PM   #424
jcramsey
jcramsey's Avatar
That's gonna look good on your truck TJ! Just don't come back telling us how the law man caught you poaching deer off the side of the road with your spotlight
The Egg Hauler
The Government Mule
Old 09-12-2014, 01:26 PM   #425
TJ's Chevy
TJ's Chevy's Avatar
Nice!!!!
Thanks!
LOL! Thanks brotha! Spotlight ain't installed cause some company called Unity USA obviously ain't in a hurry to send me my brackets!!! Oh the drama! lol!
Thanks man!
I'll make sure not to use it when the law man is around!
