Old 01-06-2015, 05:29 PM   #401
rusty76
rusty76's Avatar
Re: "Project Orangepeel" 52 A.D
You got it goin on dude.!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-06-2015, 08:35 PM   #402
reaper71
reaper71's Avatar
99 and rusty76 thanks again!!
reaper71 is offline   Reply With Quote
Old 01-07-2015, 10:54 AM   #403
reaper71
reaper71's Avatar
This is the idea I have for the arm...
After a few attempts of trying to get a shape I liked this is what was the result.
2nd pic is a shot up in place..
Old 01-07-2015, 11:01 AM   #404
reaper71
reaper71's Avatar
Pic #1. After the layout of piece,scribe and finally drilled and chamfer the holes. (went with 7 holes rather than 5) I used 3/16" plate for the arm to make it Beefy looking..
Pic #2. After the cutting and cleanup was done..
Till next time.
Mark..
Old 01-07-2015, 01:50 PM   #405
Advanced Design
Advanced Design's Avatar
That flows nicely! What did you use to cut out the shape?
Advanced Design is offline   Reply With Quote
Old 01-07-2015, 05:41 PM   #406
RockinKees
RockinKees's Avatar
You have great ideas!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-07-2015, 11:15 PM   #407
reaper71
reaper71's Avatar
A.D and Kees thank's guys!!
To cut the shape I used the Band saw. followed by a carbide bit and then belt sander...
Old 01-08-2015, 10:19 AM   #408
roushinator
roushinator's Avatar
Nice Work!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 01-08-2015, 10:58 AM   #409
reaper71
reaper71's Avatar
Thank You!!
Originally Posted by roushinator View Post
Nice Work!
Old 01-08-2015, 11:20 AM   #410
reaper71
reaper71's Avatar
Here are a couple shots of the arm again..
1. side, you get an idea of the thickness of metal..
2. Fitting the arm..
Old 01-08-2015, 06:04 PM   #411
rusty76
rusty76's Avatar
That looks great.
My build thread
Crossmembers CC
Old 01-09-2015, 10:30 AM   #412
reaper71
reaper71's Avatar
Thank's rusty76
Old 01-09-2015, 10:37 AM   #413
reaper71
reaper71's Avatar
Here are 2 more shots of the mirror arm..
These were taken after Tig welding was done.
and 1 more a bit closer. (had small amount of perosity that needed fixing)
Old 01-09-2015, 10:45 AM   #414
reaper71
reaper71's Avatar
Last 2 shots...
1st of arm after some clean up and mounted in place.
2nd of the mockup mirror. (still have to figure out the mount for mirror to arm)
This build will slow way down do to customer projects I will be pulling into the shop. (Mine will go to basement) for the time being...
I will post some small things as I get them done to share with you Guys...
I will also be starting a new Build thread for the 67 GMC stepside I'm working on for a costomer...
Mark...
Old 01-09-2015, 11:17 AM   #415
Advanced Design
Mirror arm looks really good! Really glad you have customers... though their projects will get in the way of updates on this cool project.
Looking forward to the 67 build...please put the link in your signature line.
Old 01-09-2015, 02:41 PM   #416
lower50's
lower50's's Avatar
WOW amazing metal work!! The fit and finish work go way beyond what a 52 ever had. Great work
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-09-2015, 08:27 PM   #417
reaper71
reaper71's Avatar
Thank you very much...It is a long ways from from but it's those small details that take Forever!!!
Old 01-09-2015, 08:57 PM   #418
reaper71
reaper71's Avatar
Here is the link to the new build I have started..http://67-72chevytrucks.com/vboard/showthread.php?t=655780 Blake's 67 GMC stepside build..
A.D. You ask and you shall receive lol Thank's again on the compliments!!
Last edited by reaper71; 01-09-2015 at 09:03 PM. Reason: forgot to give a shout out
Old 01-11-2015, 09:36 PM   #419
reaper71
reaper71's Avatar
Here is a small update on the arm and mirror...
I ordered a new mirror from LMC and was kinda bummed out when it showed up.
(it has this black plastic ring around the mirror) If you remove the plastic their is a gap all around the case and mirror (and super sharp)
Anyways Enough
Pic #1. Is of a connector nut 10-24 and An Acorn nut that I Tig welded together
Pic #2. After it was all welded..
This is what will become the mount for the new mirror to screw into..
Old 01-11-2015, 09:41 PM   #420
reaper71
reaper71's Avatar
Pic #1. I started to shape it some to give it kinda a "bullet" look...
Pic #2. After some sanding,smoothing etc...
Old 01-11-2015, 09:46 PM   #421
reaper71
reaper71's Avatar
Here is two pics of the piece welded to the arm...
Some may notice the arm's shape is different, It had to be shortened 1 1/2" do to it hanging to low in the windshield, so it's not as cool looking as before but still something different!!!
Old 01-12-2015, 09:16 AM   #422
hotrodelrod
hotrodelrod's Avatar
Creative and slick!
hotrodelrod is offline   Reply With Quote
Old 01-12-2015, 08:46 PM   #423
reaper71
reaper71's Avatar
Here is a few last shots of mirror/arm project..
I still am not completely sold on the plastic ring around the mirror!!
(if removed it reveals a gap and VERY sharp edge)
Thoughts?
Old 01-12-2015, 09:00 PM   #424
Advanced Design
The bullet mounts looks really good. Nice idea and work.
Don't know the plastic ring will be that noticable once the glass is in. Metal rounded edge would look better...match the color of the dash maybe?
Old 01-12-2015, 09:01 PM   #425
ratty 46
Now if you'd done it in stainless .... you could have polished it up to a "mirror" like finish ...
Either way nicely done.
ratty 46 is offline   Reply With Quote
