![]() ![]() ![]() Join Date: Jan 2018
Re: New 64 Stepper Project
Almost
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Moderator
![]() ![]() Join Date: Aug 2011
Progress is progress. The list just seems to grow the closer you get.
that list never seems to stop!! Whatever you do, if you track your parts, DO NOT DO A TOTAL!! LOL
John 3:16 - Saved me... God Bless |
Moderator
Working on the bed wood. Few more coats to do
What product did you use?
Moderator
Epiphanes.
Have you had experience with that product before?
Moderator
in marine use yes. Takes some work and time to make it right. Not for the get it done fast crowd.
How does it hold up to the sun and rain? I did a 2 part marine varnish from por-15 and it didn’t work vary well at all. I am hesitant about trying it again with another product.
Moderator
So if your hesitant, what would you use?
This is a real marine product, it's what they specialize in. Being in the sun and sea. I'm doubting my weekend at a car show will cause it harm. Years ago i used varithane or deftane and i cant remember which, was peirside with that truck for a couple years (daily driver) and was stationed in las vegas a couple years. I never saw a wrinkle in that finish. Used white oak then too.
I’m sorry. I meant I’m hesitant to use it myself. My truck is always exposed to the elements. It is probably a really good product. I am hesitant to use anything.
#13 |
Moderator
Bed and wood getting close.
#14 |
Is that a stock rear bumper? Can we get a pic if not?
#15 |
Moderator
I posted here earlier in the thread, not stock. Next generation - https://67-72chevytrucks.com/vboard/...&postcount=142
#16 |
Moderator
Tank view.
#17 |
Vary nice. it tucks in nicely.
#18 |
Moderator
Got it started today on April fools day.
Forgot to tighten a heater hose clamp on the heater core. Fixed that. Timed per Blueprint engines to 15 degrees BTDC (they say 12-16 degrees) vacuum plugged. Topped off trans, power steering and radiator. Started right back up, good sign.
#19 |
![]() ![]() Join Date: Aug 2013
As mentioned that bumper really sets it off....did you fab the brackets or stock ones worked?
Congrats on the first fire up |
#20 |
Am I correct in assuming it’s a stepside bumper?
#21 | |
Moderator
1972 stepside bumper, used the 72 brackets also.
#22 |
Nice touch....
#23 |
Moderator
Thanks Joe.
#24 |
Wow- first start up, that’s great! Always an inspiration for continued momentum. Those Blueprint engines tend to be pretty good right outta the box. Congratulations on your milestone! I looked back to the first posting on this thread and it was April 6, 2015. A long road you have wandered since then.
-JDH Insomnia is a terrible thing to waste https://www.youtube.com/watch?v=jWYVs7widI0 (Misanthropic curmudgeon attempts starting old truck in house at 2AM) |
#25 | |
Moderator
