12-27-2021, 07:49 AM | #401 |
Proprietor of Dale's Corner
Re: '72 Cheyenne K10
At least you had a rack for the conoe...lol. How did you do on gas?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
12-27-2021, 10:54 AM | #402 |
About 10mpg
12-27-2021, 12:34 PM | #403 |
12-31-2021, 12:01 AM | #404 |
After my trip I noticed the coolant leak around the thermostat housing has gotten worse. It has been on my to-do list for a while, and it made me think it's time to check a few more things off. Here's what's coming up:
- New thermostat housing and radiator hoses - Rebuild and swap in the extra steering column I have - Get horn working - Replace wiper motor, washer pump hoses, and switch - Upgrade to hydroboost brake booster - Rebuild rear driveline - Clean out cowl and install debris screen |
12-31-2021, 12:23 PM | #405 |
Sounds like you're gonna be busy.
01-01-2022, 10:27 PM | #406 |
No turning back now (no turning at all now). Today I removed the vacuum brake booster and the steering column. I also replaced the thermostat housing.
01-02-2022, 07:59 AM | #407 |
Yeah, I'd say you're pretty much committed now. I hope the hydroboost goes easy. Are you going tilt wheel on the column?
01-02-2022, 03:51 PM | #408 |
No tilt. I picked up a cheap used column that was the same color a while back. I took it apart the other day and ordered parts to rebuild it. About $150 total cost for parts (horn parts, signal parts, bearings, shift indicator and optic cable).
01-02-2022, 05:21 PM | #409 |
Great build and info here Jim, I missed the reason you went to a twin shifter setup on the TC, your truck is a lot like my 71, tia
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
01-02-2022, 09:49 PM | #410 |
Thanks. The twin shifter has easier shifting and it gives you RWD high/low, FWD high/low, and 4WD high/low.
01-02-2022, 10:38 PM | #411 |
Thanks Jim, that's very interesting, great build man.
01-04-2022, 05:38 PM | #412 |
The Hydroboost bracket from CaptainFab showed up yesterday so I worked on fitting everything to the truck today. The bracket interferes with the steering column firewall bracket a bit so both parts needed grinding. The knurl on the Hydroboost studs did not quite fit through the holes in the new bracket so I drilled those holes out to 1/2". And the studs were about a half inch too long so I cut them down.
01-04-2022, 05:41 PM | #413 |
I am still not sure how I am going to fabricate the brake pedal linkage. Having the steering out is sure a big help though.
01-09-2022, 03:49 AM | #414 |
I pulled the rear driveline out and took it up to High Angle Driveline in Paradise. He told me to change the u-joints and grease the slip joint. I have a lot of respect for a business that will turn away a customer and not charge for unnecessary work.
01-09-2022, 07:32 AM | #415 |
That should smooth out some vibration..Nice shop to give advise.
01-11-2022, 07:20 PM | #416 |
LMC order showed up, so I got my steering column all put back together.
01-12-2022, 09:35 AM | #417 |
Nice!
01-12-2022, 07:07 PM | #418 |
Got some more done today:
- Reinstalled rear driveshaft - Cleaned leaves and dirt out of the cowl - Replaced burnt windshield washer hoses - Replaced windshield wiper switch (much improved!) - Tested windshield washer pump (no good) - Worked on Hydroboost brake pedal linkage |
01-14-2022, 09:32 PM | #419 |
I think I have almost everything I need to finish up the Hydroboost. My friend that works at a local hydraulic shop made pressure lines for me, and I have a piece of return line that will work. I just need to get a "T" for the return line.
I also had my custom brake pedal adapter welded today and gave it a quick sandblast and paint. It bolts on so any future booster r&r won't require fabrication. (I made a few extra ) |
01-14-2022, 11:04 PM | #420 |
Amazing truck - it looks good as it is. I like what you've done...
We have a 72 K 4sp and will watch what you do. i'll start a build post one of these days. Curious of the lift removal (i will have mine stock), so wondering about tire size (thinking 31 x 10.5) with stock leaves at both ends. Curious about the internal gas tank and it's future. also, wondering how deep into the bones of the truck to go. I can remove the cab, take all the suspension off, the engine/tranny/diffs... and end up with a bare frame to start upwards. how necessary is this? Also, are you rebuilding diffs, t-case, tranny, or hoping 50 years of age still holds true? Trying not to make a 5 year project, but wanting a solid runner. I see function before fashion. Maybe you too. |
01-15-2022, 12:03 AM | #421 |
whoa. Nice to see but didn't see that there are 17 pages of updates. I'm so behind now...But like the color, eh?
01-15-2022, 03:46 AM | #422 | |
Yes, this thread is a very long read. I started with a truck that needed everything fixed after a decade of sitting. Ochre is definitely my favorite paint color, it suits the era so well. I will watch for your build! Cheers! |
01-15-2022, 09:37 AM | #423 | |
01-16-2022, 05:44 PM | #424 |
More progress today putting together the Hydroboost system. Sort of a pain to take the inner fender off, but I had to trim it back where the pressure line goes into the steering gearbox. Bonus - it will make installing the steering column easier.
01-16-2022, 06:46 PM | #425 |
It looks like it belongs there. Nice!
Tags |
ochre |
