#401 |
![]() Join Date: Jun 2002
Re: Previous owner '68
Getting the bottom all tied up. Still waiting on speedo gears to get the speedometer right for the rear end and tire size. Also waiting for a new modulator.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#402 |
Got the intake glued down and tried the valve covers for fit. They need painted but it won't quit raining!
#403 |
This is the book I'm using. Could not have gotten through it without it!
#404 |
Having said that, I was in the garage waiting for paint to dry so I went over the disassembly and assembly sequence in the book. Uh oh, on pg. 52 fig. 3 it shows the governor filter here.
#405 |
But on pg. 106 fig. 9 it shows it going into a different hole...
#406 |
Does it make a difference??? Not sure, that Cliff is a smart guy, but I started thinking it should be in the pg.52 fig 3 location. So I got even more experience and took it back apart and put it where I think it goes.
I did find a page that said chevy's use one filter and BOP use 2 (one in each of the locations shown). Not sure if this is correct but I guess I'll find out when I rebuild the pontiac tranny.
#407 |
Paint drying...
#408 |
Location of the pcv valve in the intake. Don't worry, it has a baffled grommet.
#409 |
Cliffs phone number 740-397-2921 He may not be working this week...
So what kind of a crank case breather are you going to use? |
#410 | |
I won't install it until after I put the engine in the frame. Less for me to break with the cherry picker!
#411 |
Well, I screwed up the valve covers by sanding out defects and then painting too heavy and early. It wrinkled badly. So, since I'm waiting on parts for other things, I decided to tear into my alternator. Its a 10si series Delco Remy so nothing special.
Glad I tore into it, the front bearing is shot and the brushes are pretty short. So now I'm waiting on yet more parts!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 11-27-2024 at 06:50 PM. |
#412 |
Cleaned-up the housing.
#413 | |
My 1970 C10 ChassisFab LWB to SWB Build Thread |
#414 |
I pretty much emulated (copied is such a dirty word...) you and Zicc! I really like the vintage 283 look.
#415 |
![]() Join Date: Mar 2011
send me that housing ill powder coat that baby for you
![]() now seriously even at my age with very little to lose In the way of embarrassment I have never taken one apart to P coat it I will try now that I see your pics
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#416 |
They come apart pretty easy as long as they haven't been close to salt water. If they have you'll break the 4 skinny bolts! I broke a bunch in the Navy!
#417 |
The speedo gears came in and I got them installed. I have a 3.73 rear end with 28.9" tall tires, so I ended up with an 8 tooth drive gear and a 21 tooth driven gear. Also installed a new transmission mount.
I also put on a new modulator. I used the red stripe, but may have been better off with the black stripe.
#418 |
Also got new motor mounts while I was at it.
#419 |
I had bought a 73 up transmission cross-member knowing I would have to do some welding to get it to fit. I think it is going to work.
#420 |
Put in the new parts for the alternator. Need to get some spray insulator to spray the windings before I put it together.
#421 |
Finally got a decent coat on the valve covers. I'm waiting on decals for the Chevrolet script. I'm not trying to paint them again.
#422 |
I’m really impressed with your skills, everything is coming together well.
#423 |
Thanks! but it's not so much skill as it is determination. I tend to overthink things and that can sometimes slow me down. Sometimes I have to tell myself to stop building it in my head and get something done.
#424 |
![]() Join Date: Oct 2012
Great progress, RG! Determination helps create the skills.
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#425 |
Thanks Scott!
| Bookmarks |
