Closed Thread
Old 11-15-2011, 09:06 PM   #4226
losthope
losthope's Avatar
Re: What did you do to your truck today?
Installed blue dots in my lens did a step by step how i did it in my build thread:
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 11-15-2011, 09:42 PM   #4227
Oldgearz
Oldgearz's Avatar
Bolted trans body cover back on, had to cut it up for the muncie hurst shifter to fit, cleaned out metal flooring, started removing weatherstripping on inside of cab, door sills removed, revealing rust underneath. (Prepping cab for paint w/new carpeting and sills.)
1962 GMC 1/2 ton stepside longbed, 305 V6, Muncie 3spd HD tranny, stock rear end, rolling resto!
Oldgearz is offline
Old 11-17-2011, 02:36 AM   #4228
Touchdown67
Touchdown67's Avatar
Drove my truck today for the first time in 19 months. Frame off rebuild, new paint, new SB 400 What a feeling.
Touchdown67 is offline
Old 11-17-2011, 03:17 AM   #4229
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Congrats!
fryer1979 is offline
Old 11-17-2011, 10:54 AM   #4230
markeb01
Senior Enthusiast
markeb01's Avatar
Glad you found a new home for them. The combination makes for a nice presentation. Those and the 1960 passenger car caps are my two all time favorites.
Originally Posted by Revoh View Post
I did something truck-related to my '96 Impala SS. I normally run chrome-plated stock Impala wheels on it, but thought I'd do something else for the winter.
My '63 Chevy truck had '63 Chevy car hubcaps on it when I bought it, but I replaced them with the correct truck hubcaps. So I found some ol' deep steel Chevy truck wheels and used those with the hubcaps to go for sort of a '63 Biscayne look on my Impala.
Something different, anyway.
markeb01 is offline
Old 11-17-2011, 04:31 PM   #4231
Revoh
Revoh's Avatar
Thanks!
1963 C-10
My car blog, for your reading pleasure.
Revoh is offline
Old 11-17-2011, 09:11 PM   #4232
PORKY
PORKY's Avatar
We finally got the hood and the bed primed. We applied the primer heavy to get the wet look. It really makes the imperfections easy to find. It’s close but we have some more blocking to do and at least one more primer application, and blocking before paint.
PORKY is offline
Old 11-17-2011, 09:28 PM   #4233
samuellg1977
samuellg1977's Avatar
That looks good, PORKY!! Man, I wish i had a fleetside bed!!
Sam
samuellg1977 is offline
Old 11-17-2011, 09:35 PM   #4234
E911manager
Finally got clearance from the eye doctor to go back to welding and grinding. Got 2 pieces of steel in my eye on Sunday. Doc drilled it out on Tuesday. That was a hundred bucks I could have spent on Eli... Anyway, more cab mount creations, cutting, welding and grinding...
E911manager is offline
Old 11-17-2011, 09:41 PM   #4235
Bardahl
Belts,wiper blades, and a thermostat !, and picked up some missing trip parts from a buddy (had to spring for Pizza for 7 pieces of 68 Long bd trim !) was well worth the 19.10, thanks Lawerence and Steve !!
Bardahl is offline
Old 11-18-2011, 08:04 AM   #4236
tincan1966
tincan1966's Avatar
well, unfortunately a broken harmonic balancer on my "69 C-30 has derailed progress on the 'Burb for a few days. Got engine out, figured good time to seal all the leaks and clean things up a bit. Putting engine back in on sat, got to have for work on Monday.
tincan1966 is offline
Old 11-18-2011, 11:58 AM   #4237
Rich 5150 69
Rich 5150 69's Avatar
Did mine about two years ago..have`nt been stopped yet....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 11-18-2011, 02:09 PM   #4238
MisterC
MisterC's Avatar
I needed to have my tires balanced, so while I was at it, I had the installers turn the tires around so that the raised white letters were out. The PO liked the blackwalls and I prefer the RWL. Some 0000 steel wool to the smoothies and the setup now looks good enough for me to move the "new wheels" item way down on my list of needs.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline
Old 11-19-2011, 08:46 AM   #4239
chevytrucknut61
chevytrucknut61's Avatar
Pulling my engine and tranny out to put back the cleaned up and resealed 350 and the rebuilt tranny.Nothing like chirping the tires when shifting into second. Will post pics later.
chevytrucknut61 is offline
Old 11-19-2011, 03:25 PM   #4240
kenmel
kenmel's Avatar
changed the radiator cap and new thermostat to take care of the coolant leak coming out the overflow... Oh and turned it around...
kenmel is offline
Old 11-19-2011, 03:55 PM   #4241
MOJO1963GMC
MOJO1963GMC's Avatar
Working on the grill for my truck. Bodywork
MOJO1963GMC is offline
Old 11-19-2011, 07:56 PM   #4242
Andyboy
Andyboy's Avatar
bought a lock button for my driver door handle and that bracket that goes from the bed to the frame, from the local junk yard.
Andyboy is offline
Old 11-19-2011, 10:27 PM   #4243
niterider65
niterider65's Avatar
Cool Re: What did you do to your truck today?
Did a little cleaning and opened up parts boxes and putting stuff in order after restoring them to get ready for putting on later.. finally getting back
on the truck after playing @ nascar and vegas for 5 days...
niterider65 is offline
Old 11-19-2011, 10:53 PM   #4244
niterider65
Just a few more picks off the rear veiw mirror in paint gun metal grey
base clear and the linkade for the carb and power steering pump
Old 11-19-2011, 11:22 PM   #4245
niterider65
last ones
Old 11-19-2011, 11:50 PM   #4246
chevyrestoguy
chevyrestoguy's Avatar
Spent all day under the truck in 45 degree weather and 30 mph winds. Got the trailing arms blasted and painted, installed the new polyurethane bushings, painted a section of the chassis, installed the new 5" dropped rear coils, and the shock relocators.
Tomorrow, I plan on getting the pinion angle set and welding on the rear saddles. If it's not too windy, I'll paint the rear end and install it. I'm anxious to see the truck on it's wheels.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline
Old 11-20-2011, 01:11 AM   #4247
firefighter736
firefighter736's Avatar
Finally got the truck road worthy last night and was asked to participate in a photo shoot. Got some really awesome shots of the truck in Roanoke, VA tonight.
firefighter736 is offline
Old 11-20-2011, 01:35 AM   #4248
KroAutomotiveInc
KroAutomotiveInc's Avatar
new paint on the wheel
KroAutomotiveInc is offline
Old 11-20-2011, 08:50 AM   #4249
tincan1966
tincan1966's Avatar
Well the project on the '69 proved more than expected. New rings,brgs and cam and lifters. Installed gear drive,Milodon 8qt pan. Engine is back in, waiting on new headers on Tuesday. Tahing vacation to finish up over the Turkey day weekend.
Old 11-20-2011, 09:16 AM   #4250
duallyjams
duallyjams's Avatar
installed plaid valve coversName:  IMG_0162.jpg
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline
Closed Thread
