Closed Thread
Old 06-24-2012, 04:45 AM   #4251
RINC
RINC's Avatar
Re: What did you do to your truck today!
I drove mine on the freeway for the 3rd time ! Longest trip yet.
Speedo is off but it made the 45 mile round trip to a buddies for the UFC fights.
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 06-24-2012, 11:12 PM   #4252
ItsRandy
ItsRandy's Avatar
I got both fenders hung and adjusted (had to take one off and touch-up both on the inside), readjusted the driver's door, installed parking brake assembly with cable, wired and installed the side marker lights, installed the tail light and back-up light lenses, installed the hood hinges and hood latch, installed and adjusted the hood (the hood still needs some fine tuning).
ItsRandy is offline
Old 06-25-2012, 08:08 AM   #4253
Bennett68C10
Bennett68C10's Avatar
Looks awesome ItsRandy, and I love the 502
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 06-25-2012, 10:27 AM   #4254
big_al_71
big_al_71's Avatar
Greased it, changed oil and filter. Wiped it down...Pouring raining for the last three days..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 06-26-2012, 01:01 PM   #4255
Clrussell
Clrussell's Avatar
brought it to town!!!! i got one u bolt plate on and have to make a different one for the passengerside.. but its finally back to town instead of 20 miles away.. got a window tint ticket on the way to pick it up.. tonight im hoping to finish up the other u bolt plate, hook up the brakes, tighten all the bolts up and spray a little black paint on the frame.. got a couple pics of it outside the shop
61 apache
Clrussell is offline
Old 06-26-2012, 01:03 PM   #4256
Clrussell
Clrussell's Avatar
not really sure why the pics are sideways?
61 apache
Old 06-26-2012, 01:19 PM   #4257
Rob H.
Rob H.'s Avatar
Blew it up. Yesterday actually, started pulling the sheet metal off the front of the 67 and gonna pull the 327 and put in the 72. But it's snowballing, I'm gonna go ahead and put in the rockers and cab supports and add power steering and detail the front frame and the engine and under the hood 67 front end going back on it! So yea it'll be down for a bit.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 06-26-2012, 04:17 PM   #4258
Jimbabwe
Jimbabwe's Avatar
Hit the paint supply place and had them match the color and mix a couple of cans to spray my auto column and grant removable hub.
Turned out to be Holly Green. A '72 f@#d truck color.
Jimbabwe is offline
Old 06-27-2012, 11:38 AM   #4259
Rob H.
Rob H.'s Avatar
I got this far on my 67 tear down.
I've got alot of cleaning to do on the 327 and gonna replace pan and valve cover gaskets and front and rear seal. This engine only has 89K on it.
Rob
48 Willys CJ2A
Rob H. is offline
Old 06-27-2012, 11:45 AM   #4260
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Great truck!!!!
Well, maybe they can be turned this way:
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 06-27-2012, 12:28 PM   #4261
Beersnob
Patched a hole behind the door.
Beersnob is offline
Old 06-27-2012, 12:30 PM   #4262
Dunenutt
Newbee
Dunenutt's Avatar
Originally Posted by magwakeenercew2jh View Post
Great truck!!!!
Now I REALY want to find a truck to cut up! That thing is awesome!
Dunenutt is offline
Old 06-27-2012, 02:45 PM   #4263
Andy4639
Old member
Andy4639's Avatar
Nothing fance just pressured washed the underside. I try and clean it 2 a year it was nice out so I gave it a good cleaning. Well best I could in the drive way.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 06-28-2012, 12:35 AM   #4264
snj8198
snj8198's Avatar
I don't see a gun rack in the rear window, so... how did that happen?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline
Old 06-28-2012, 08:54 AM   #4265
zellway
zellway's Avatar
I was just thinking the same thing.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 06-28-2012, 11:21 AM   #4266
Clrussell
Clrussell's Avatar
Thanks for turning the pics! And for the comments! Almost finished It last night, but our awesome parts store doesn't carry brake hoses for older chevy trucks apparently.. And I broke a bolt off and the bolt getting place was closed when I got there.. So first thing this morning I got a bolt and rolled it back out of the shop.. Maybe tomorrow it'll be finished
61 apache
Old 06-28-2012, 11:47 PM   #4267
magwakeenercew2jh
Worst build day ever...But it's over.
It's a personal thang...I hate screwing around with the windows. I was gone on a road trip for about four weeks. Almost every night I thought about that passenger window that I left with
unfinished electric window wiring and mechanism install. They were good thoughts. Today, I got a chance to go to the shop at 8:15. I was going to "beat the heat".
When I figured out the nuances of the install when I put in the driver's side, I figured I'd do the same thing on the passenger's side in about an hour.
After pulling everything out of the door (except the door opening hardware), I found out that I was going to have to come in from the top with the window
glass and "carrier" in order to hook on the three "slider buttons". Not so with the first door. Maybe it was me, being a right-hander and left-brainer.
All's well that ends well, I guess. At 2:30, though. I guess it was 85 degrees F.....Felt like 120.
Still have to do the final wiring and the passenger door panel. BTW, great quality on this electric window kit from ECE. It was a present.
But I think it was about five bills. I definitely paid the price today.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-01-2012, 01:32 AM   #4268
ItsRandy
ItsRandy's Avatar
Got my back glass and my passengers side door glass, with power, installed. I like the way it looks.
ItsRandy is offline
Old 07-01-2012, 01:37 AM   #4269
magwakeenercew2jh
Nice. You're moving right along.....
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-01-2012, 01:52 AM   #4270
68C20 CST
68C20 CST's Avatar
Got all the sidemarker wiring fixed and now working.
68C20 CST is offline
Old 07-01-2012, 04:54 PM   #4271
magwakeenercew2jh
I must be getting SOMEWHERE....I now have a list!!!!
Today, it was:
Finish wiring the electric windows; Cut and install kick panel(s) carpet; Install both door panels.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-01-2012, 06:51 PM   #4272
dhaymaker
dhaymaker's Avatar
When you get to the "punch card", you're well on your way! I've been watching your build and it's really nice to see you working towards the ultimate realization of your plans and dreams. All too often people give up on their projects...doesn't look like that's happening here. Keep after it, we are watching and you are providing a lot of motivation for some of the other builders. Thanks, and good luck. It won't be long now! don
don
"The DRBMan"
2014 Audi A4 (The Wife's Daily Driver)
2017 HD Ultra (The Cruiser)
2003 HD Fatboy (The Ride)
2001 Chevy Suburban (Another back up!!)
For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!!
dhaymaker is offline
Old 07-01-2012, 06:58 PM   #4273
magwakeenercew2jh
Originally Posted by dhaymaker View Post
When you get to the "punch card", you're well on your way! ....snip... Thanks, and good luck. It won't be long now! don
That was really nice....And motivating.
My "Thanks" to YOU!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-01-2012, 08:31 PM   #4274
elf w/capital T
spent the day with the wife, first day off in 15 days, but i touched up my rear window rust repair a bit. glad thats done :-)
elf w/capital T is offline
Old 07-01-2012, 09:07 PM   #4275
jmdemon55
jmdemon55's Avatar
Finished up the brake system overhaul,(it has brakes again!!)and replaced the front wheel bearings and seals why we were at it.
jmdemon55 is offline
Closed Thread
